DSD support
luciano.badoe
Post Thu Dec 22, 2016 2:20 pm
DSD support
I´m using the free version of the Serviio and I have problem to streaming my DSD files (DSF, DFF extensions) to my Cambridge Audio network player 851N via Serviio.
The metadata of the file (DSF) was streamed to the 851N but is note possible player the file.
Is this some limitation of the free version?
Kind Regards.
Post Fri Dec 23, 2016 4:50 am
Re: DSD support
I don't believe there is a playback restriction of specific file types using the Free version. I'm not familiar with DSD or your player, so can't offer specific advice for that particular issue.
luciano.badoe
Post Thu Dec 29, 2016 9:34 pm
Re: DSD support
The problem just occurs with DSD files. FLAC and MP3 are played normali under Serviio.
Enviado de meu XT1635-02 usando Tapatalk
Post Mon Jan 02, 2017 8:49 am
Re: DSD support
DSF support was added in version 1.6.1. DFF has been requested - https://bitbucket.org/xnejp03/serviio/i ... -libraries and here: https://bitbucket.org/xnejp03/serviio/i ... -libraries, however given the limitations of that format I'm not sure it's going to get high priority (no metadata storage capability as I undertsand it), but that's for others to decide (vote for the bitbucket issues if you want higher priority).
There is no restriction for DLNA playback between the free and pro versions of Serviio. Check the file you are trying to stream against the specifications for your device, it could simply be that this file is not supported by your device (although it supports DSF files, there may be restrictions on the bitrate etc that is playable).
luciano.badoe
Post Fri Jan 06, 2017 2:04 am
Re: DSD support
DenyAll wrote:DSF support was added in version 1.6.1. DFF has been requested - https://bitbucket.org/xnejp03/serviio/i ... -libraries and here: https://bitbucket.org/xnejp03/serviio/i ... -libraries, however given the limitations of that format I'm not sure it's going to get high priority (no metadata storage capability as I undertsand it), but that's for others to decide (vote for the bitbucket issues if you want higher priority).
All files that I tryed to play are OK to my player. It's Works normally by the USB para and by another DLNA servers, by I like Serviio and whant to use they for it but not sucess for now.
easycube
Post Fri Mar 24, 2017 6:37 pm
Re: DSD support
Hi All, I have very similar issue ... running Serviio 1.8 free version (actually still under Evaluation License) on QNAP ... when play music on Pioneer N50A, everything is fine including DSF files ... but when try to play DSF on Sony NW-ZX2 (Android environment) I do get a message "this device cannot play this format" only. Weird, because tried serviio andoid application which can play it easy, but to be honest, that serviio app is pretty useless (except of fact it can play DSF ;-). So, something weird with this Serviio Server. Don't like it.
Post Sat Mar 25, 2017 12:50 am
Re: DSD support
easycube wrote:Hi All, I have very similar issue ... running Serviio 1.8 free version (actually still under Evaluation License) on QNAP ... when play music on Pioneer N50A, everything is fine including DSF files ... but when try to play DSF on Sony NW-ZX2 (Android environment) I do get a message "this device cannot play this format" only. Weird, because tried serviio andoid application which can play it easy, but to be honest, that serviio app is pretty useless (except of fact it can play DSF ;-). So, something weird with this Serviio Server. Don't like it.
Just because they are both Android has no bearing if a device can play something another can. It all depends on the codec support. Looking at the Sony web site (http://www.sony.com/electronics/walkman ... ifications) I don't see DSF as a supported codec. It lists AAC (Non-DRM), AIFF, ALAC, DSD, FLAC, HE-AAC, Linear PCM, MP3, WMA (Non-DRM).
I take that back, I had to see what spec DSF was, and I see it is supported by DSD, which it says is supported. What profile has Serviio selected for your player? Look on the console/status page. My guess is you should be using the generic profile, and it might have selected one of the Sony profiles in error.
vshk
Post Fri May 05, 2017 4:48 am
Re: DSD support
I have similar problem on playing dsf file. I tried another media server in the same system/music files and it works properly, so there is something wrong in the Serviio server itself or its communication with the uPnP renderer....
I would like to know if this post has been resolved and how.
Many thanks!
Post Fri May 05, 2017 3:46 pm
Re: DSD support
vshk wrote:I have similar problem on playing dsf file. I tried another media server in the same system/music files and it works properly, so there is something wrong in the Serviio server itself or its communication with the uPnP renderer....
Many thanks!
More detail needed. What are you using for a player, and what Serviio profile is assigned to that player?
vshk
Post Sat May 06, 2017 12:04 am
Re: DSD support
Many thanks!
Here are the details:
Media Server: Serviio on Mac OS
UPnP Client: BubbleUPnP
Player/Renderer: USB Dac supporting DoP + RaspberryPi running mpd+umpmdcli renderer
Serviio profile: Default Generic DLNA
Problem: Flac music files are working fine, only Dsf file cannot be decoded. Replacing the Serviio with another media server on Mac makes all file types work with the same settings.
Many thanks!
RozenbaumAE
Post Fri Aug 23, 2024 7:05 am
Re: DSD support
There is a great fearure of dff files: embedded compression scheme, which can reduce file size more than twice.
There are some metadata chuncks documented at https://www.sonicstudio.com/pdf/dsd/DSDIFF_1.5_Spec.pdf (3.7.3 and 3.7.4 for example)
xRecode3 can produce dff files with some metadata in them. That metadata can be shown by Foobar2000 and MediaInfo:
Complete name                            : D:\7\WAV\dst\08. Still Loving You.dff
Format                                   : DSDIFF
Format/Info                              : Direct Stream Digital Interchange File Format
Format version                           : Version 1.5.0.0
File size                                : 135 MiB
Duration                                 : 8 min 2 s
Overall bit rate                         : 2 346 kb/s
Album                                    : Moment Of Glory
Track name                               : Still Loving You
Track name/Position                      : 8
Performer                                : Scorpions
Publisher                                : EMI
Genre                                    : Rock Music
Recorded date                            : 2002
Cover                                    : Yes
Cover description                        : Front
Cover type                               : Cover (front)
Cover MIME                               : image/jpeg
PERFORMER                                : Scorpions
copyright                                : EMI
Conformance errors                       : 1
 0x44534420                              : Yes
  General compliance                     : Element size 141444560 is more than maximal permitted size 141444556 (offset 0x10)
Format                                   : DST
Format/Info                              : Direct Stream Transfer
Commercial name                          : DSD64
Bit rate                                 : 2 337 kb/s
Channel layout                           : L R
Sampling rate                            : 2 822 kHz
Frame rate                               : 75 FPS (37632 SPF)
Compression mode                         : Lossless
Stream size                              : 134 MiB (100%)
