How to not seperate video and image ?
jvachez
Post Mon Sep 23, 2024 5:46 pm
Hello !
When I go on holidays I'm taking photos AND videos. So they must be played chronologically in the same time.
How can I do that ?
Post Mon Sep 23, 2024 10:52 pm
Re: How to not seperate video and image ?
I would try building a playlist that includes the files you want to play in the order you want them played. The only potential issue is if the player you use will honor the order of the files in the playlist. Roku players will keep the order. On my Android boxes using Kodi as the player they are in alphabetical order (so renaming the files alphabetically might be a way around that issue). If the player is built into the TV, then it depend on the TV if it reorders the files.
jvachez
Post Tue Sep 24, 2024 6:32 am
The order is not the problem.
The problem is serviio displays a version of the folder for photos with good order and a version of the folder for video with good order.
I want them together in the same folder with good order.
For example in the same folder
c.mp4
e.mp4
Post Tue Sep 24, 2024 12:19 pm
I don't believe it be done with the existing Serviio version. A playlist is the only way I can think of for combining different media types so they will play together. And I'll say that I've never tried it, so I'm simply making an educated guess.
