Cannot connect to the server, it doesn't seem to be runnig..
klejbroda
Post Fri Dec 19, 2025 2:53 pm
I am having issues when opening the app on Mac, this happens immediately after the start and there’s no way around it. Please see the attached screenshot. This happens in both legacy and the latest versions, it just won’t open. Restarts of the app or the computer don’t help. Can you please advise on how to troubleshoot this?
Cheers
Piotr
https://imgur.com/a/Tf7U5u8
Post Sat Dec 20, 2025 1:15 am
Re: Cannot connect to the server, it doesn't seem to be runn
Have you attempted to use the web interface instead of the console app? On the computer running Serviio, just try localhost:23423/console and see if it opens. If it does, then Serviio is running. Many people have issues with the console app but can use the web version without any issues.
If the web console doesn't work, then open the Serviio log and look for error messages. The log is located within the file structure you installed Serviio to in the Logs folder.
