Sonos conflict?
NozzaC
Post Sun Mar 25, 2012 8:05 am
Sonos conflict?
I have Servvio running on my Windows 2008 Server and it's been working fine serving video to my Panasonic P42G30B TV.
However I recently bought a Sonos system and, since my media is all on this server, pointed the Sonos player at the music share on the server using a Sonos Controller app, also installed on the server. Ever since then when I look for media servers on my TV only Sonos shows up and not Serviio.
As I understand it the Sonos "server" is in fact the Sonos player and there is no media server s/w installed on the server. The Controller app is there to interact and configure the player. So I cannot see how a conflict could occur but I'm trying to figure out why Servvio has stopped working at this point. It could just be a coincidence I guess.
Any help getting Serviio back working would be much appreciated. Thanks
Post Sun Mar 25, 2012 7:08 pm
Re: Sonos conflict?
NozzaC
Post Mon Mar 26, 2012 3:47 pm
Re: Sonos conflict?
I bound the correct IP and turned off firewall - no difference. PC IP is 192.168.50.200. TV is dynamic but currently 192.168.50.11. Sonos is 50.25. TV was 50.99 and I tried Adding it manually at one point. neither serviio nor TV can see each other. Serviio only sees Sonos.
2012-03-26 16:11:23,437 INFO [MediaServer] ------------------------------------------------------------------------
2012-03-26 16:11:23,437 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-03-26 16:11:23,437 INFO [MediaServer] Petr Nejedly 2009-2011
2012-03-26 16:11:23,437 INFO [MediaServer] http://www.serviio.org
2012-03-26 16:11:23,437 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2012-03-26 16:11:23,437 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-03-26 16:11:23,437 INFO [MediaServer] File encoding: windows-1252
2012-03-26 16:11:23,437 INFO [MediaServer] Headless mode enabled: true
2012-03-26 16:11:23,437 INFO [MediaServer] User home dir: C:\
2012-03-26 16:11:23,437 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-03-26 16:11:23,515 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-03-26 16:11:23,546 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-03-26 16:11:24,279 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-03-26 16:11:25,574 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-03-26 16:11:25,840 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-03-26 16:11:25,980 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-03-26 16:11:26,058 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-03-26 16:11:26,183 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-03-26 16:11:26,245 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-03-26 16:11:26,277 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-03-26 16:11:26,464 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-03-26 16:11:26,480 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-03-26 16:11:26,667 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-03-26 16:11:26,948 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-03-26 16:11:27,057 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-03-26 16:11:27,172 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-03-26 16:11:27,241 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-03-26 16:11:27,256 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-03-26 16:11:27,308 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-03-26 16:11:27,332 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-03-26 16:11:27,415 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-03-26 16:11:27,456 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-03-26 16:11:27,565 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-03-26 16:11:27,630 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-03-26 16:11:27,848 INFO [WebServer] Socket buffer set to 65535 bytes
2012-03-26 16:11:27,849 INFO [Device] Created UPnP Device with UUID: d7063ff3-5dd1-3528-8239-459a9dbec968, bound address: 192.168.50.200
2012-03-26 16:11:27,861 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-03-26 16:11:27,862 INFO [PluginCompilerThread] Started looking for plugins
2012-03-26 16:11:28,007 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-03-26 16:11:28,026 INFO [WebServer] WebServer starting on port 8895
2012-03-26 16:11:28,029 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 16:11:28,029 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 16:11:28,029 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 16:11:28,031 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 16:11:28,031 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-03-26 16:11:28,041 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.50.200, timeout = 0
2012-03-26 16:11:28,561 INFO [RendererManager] Stored a new renderer: uuid='rincon_000e5888d23801400_mr', name = 'Sonos PLAY:5', ipAddress='192.168.50.25', profile = '1'
2012-03-26 16:11:54,292 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-03-26 16:11:54,292 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-26 16:11:54,292 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-03-26 16:12:06,030 INFO [ServiioConsole] Starting Serviio Console
2012-03-26 16:12:06,160 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-03-26 16:12:06,444 INFO [Messages] Loaded console message bundle for locale: en
2012-03-26 16:12:06,483 INFO [UpdateChecker] Checking if a new version is available
2012-03-26 16:12:12,191 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-03-26 16:12:12,414 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-03-26 16:13:10,674 INFO [RendererManager] Stored a new renderer: uuid='7606f9d4-caa1-45e1-bbaa-eb715ebf9df5', name = 'tv', ipAddress='192.168.50.99', profile = '12'
2012-03-26 16:13:10,675 INFO [WebServer] WebServer shutting down
2012-03-26 16:13:10,675 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-26 16:13:10,675 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-26 16:13:10,678 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-26 16:13:10,865 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-26 16:13:10,865 INFO [WebServer] WebServer starting on port 8895
2012-03-26 16:13:10,865 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 16:13:10,865 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 16:13:10,865 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 16:13:10,865 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 16:13:10,865 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.50.200, timeout = 0
2012-03-26 16:13:13,133 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-03-26 16:13:43,499 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-26 16:13:43,499 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-26 16:13:43,501 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-26 16:13:43,501 INFO [WebServer] WebServer shutting down
2012-03-26 16:13:43,673 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-26 16:13:43,689 INFO [Device] Updated bound IP address of Device with UUID: d7063ff3-5dd1-3528-8239-459a9dbec968, bound address: 192.168.50.200
2012-03-26 16:13:43,689 INFO [WebServer] WebServer starting on port 8895
2012-03-26 16:13:43,689 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 16:13:43,689 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 16:13:43,689 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 16:13:43,689 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 16:13:43,689 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.50.200, timeout = 0
2012-03-26 16:14:05,192 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-03-26 16:14:05,302 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-03-26 16:14:05,411 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-03-26 16:14:05,411 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
CULLED LIBRARY DATA FROM FILMS ADDED TO LIBRARY HERE TO GET UNDER CHARACTER LIMIT
2012-03-26 16:30:58,389 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-26 16:30:58,389 INFO [WebServer] WebServer shutting down
2012-03-26 16:30:58,389 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-26 16:30:58,389 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-26 16:30:58,576 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-26 16:30:58,733 INFO [Device] Updated bound IP address of Device with UUID: d7063ff3-5dd1-3528-8239-459a9dbec968, bound address: 192.168.50.200
2012-03-26 16:30:58,733 INFO [WebServer] WebServer starting on port 8895
2012-03-26 16:30:58,733 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 16:30:58,733 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 16:30:58,733 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 16:30:58,733 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 16:30:58,734 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.50.200, timeout = 0
2012-03-26 16:31:56,202 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-26 16:31:56,202 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-26 16:31:56,202 INFO [WebServer] WebServer shutting down
2012-03-26 16:31:56,202 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-26 16:31:56,361 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-26 16:32:35,484 INFO [WebServer] WebServer starting on port 8895
2012-03-26 16:32:35,484 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 16:32:35,484 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 16:32:35,484 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 16:32:35,484 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 16:32:35,485 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.50.200, timeout = 0
2012-03-26 16:36:27,808 INFO [RendererManager] Stored a new renderer: uuid='a2032245-f286-4ee7-a306-7c1c9d160e68', name = 'Unrecognized device', ipAddress='192.168.50.200', profile = '1'
2012-03-26 16:37:32,709 INFO [WebServer] WebServer shutting down
2012-03-26 16:37:32,709 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-03-26 16:37:32,709 INFO [EventDispatcher] Leaving EventDispatcher
2012-03-26 16:37:32,725 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-03-26 16:37:32,896 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-03-26 16:37:42,787 INFO [WebServer] WebServer starting on port 8895
2012-03-26 16:37:42,787 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-03-26 16:37:42,787 INFO [RendererSearchSender] Searching for Renderer devices
2012-03-26 16:37:42,787 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-03-26 16:37:42,787 INFO [EventDispatcher] Starting EventDispatcher
2012-03-26 16:37:42,787 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.50.200, timeout = 0
NozzaC
Post Tue Mar 27, 2012 10:27 am
Re: Sonos conflict?
OK this is solved. Nothing to do with Sonos as such. It turned out to be a network issue. The cable linking the TV to the router had been chewed by the cat and had a very poor connection! For some reason i cannot fathom at all, this resulted in the TV being able to get the internet OK - including iplayer in HD, but messed up talking to any kind of media server on my computers. Replaced the cable and it all works AOK and Serviio is back up and running perfectly. Weird.
Post Tue Mar 27, 2012 12:06 pm
Re: Sonos conflict?
bloody cats :-D
NozzaC
Post Tue Mar 27, 2012 2:35 pm
Re: Sonos conflict?
I know. What is it about cats and ethernet cables?! I have to replace the ones in my lounge about 3 or 4 times a year.
Post Tue Mar 27, 2012 4:51 pm
Re: Sonos conflict?
Are you talking about cats? ;-) Get a dog, it'll deal with it.
Users browsing this forum: No registered users and 79 guests
