Not visible all folders
Atilius
Post Sat Mar 24, 2012 7:18 pm
Hi, I use serviio 0.6.2. and I have a problem with folders visibility. I put to the library path and I can see only 49 folders instead of 67. I have tried forced refresh, to take out the path and put in again but no success. The folders are without specific letters. And always the same are missing but I dont know what is wrong...
Thanks for any help.
Martin
Post Sun Mar 25, 2012 7:20 pm
Re: Not visible all folders
are all folders on the same drive? check file permissions.
Atilius
Post Mon Mar 26, 2012 12:43 pm
I have found the reason.... I compared all the missing files and I have found that folders dont contain any special letters but the files inside do. When I corrected the file names all is OK.
I suppose that it is a feature of Serviio when empty folder is not visible. But not visible files with special letters seems to me a bug...
Thank you,
Martin
Post Tue Mar 27, 2012 5:02 pm
What OS?
Atilius
Post Wed Mar 28, 2012 5:00 pm
openSuse 11.3
Post Thu Mar 29, 2012 10:27 pm
Users browsing this forum: Google [Bot] and 22 guests
