Video won't play
abasel
Post Mon Apr 09, 2012 7:55 am
Video won't play
I am connecting to my SERVIIO (windows) server via a Panasonic DMP=BDT310.
My MP3 steam just fine but when I click on the videos (MPG), I am told that they can't play.
Post Mon Apr 09, 2012 8:00 am
Re: Video won't play
Can you follow this and post the info http://wiki.serviio.org/doku.php?id=file_np
Can you also confirm which profile you are using for your device (it is shown on the serviio console)
abasel
Post Tue Apr 10, 2012 6:15 am
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\abasel>cd "c:\Program Files\Serviio\lib"
c:\Program Files\Serviio\lib>ffmpeg.exe -i "d:\d-drive\Offline Private Work\vide
os\FunnyCats.mpg"
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 25.00 (25/1)
Input #0, asf, from 'd:\d-drive\Offline Private Work\videos\FunnyCats.mpg':
title : funny_cat_videos
artist : Trevor McGavin
copyright : ┬® Home
comment : funny cats, from Funny Home Videos, Dec 2002
WMFSDKVersion : 8.00.00.4477
WMFSDKNeeded : 0.0.0.0000
Duration: 00:01:39.18, start: 0.000000, bitrate: 229 kb/s
Stream #0:0: Audio: wmav2 (a[1][0][0] / 0x0161), 32000 Hz, 2 channels, s16,
32 kb/s
Stream #0:1: Video: msmpeg4 (MP43 / 0x3334504D), yuv420p, 320x240, 25 tbr, 1
k tbn, 1k tbc
I am using the Generic DLNA profile
Post Tue Apr 10, 2012 6:50 am
select the panasonic profile. You can also look in the panasonic folder here for customized profiles that have been made since the last serviio update.
The generic profile does not transcode anything.
the directTV profile transcodes everything.
The panasonic profiles only transcode what panasonic will not play normally.
Users browsing this forum: No registered users and 69 guests
