Invalid Media Format Exception with mpegts of mp2 only
kakker
Post Fri Apr 06, 2012 5:30 pm
First of all, thank you for everything you've put in to Serviio. I have set up a media server (WHS 2011) on my local network, which can now provide live streams (mpegts of mpeg2video/ac3) of our local TV stations (OTA/ATSC), from a Hauppauge HVR-2250 TV Tuner / WinTV with Extend, to DLNA devices, such as our Sony BDP-S580 Blu-Ray Player ... thanks to Serviio.
I would, however, like to be able to do the same with the live streams of our FM radio stations, but Serviio does not appear to like the mpegts of mp2 audio only, as I am encountering the following errors:
2012-04-06 12:02:02,900 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://192.168.1.25:7799/stream?channel=8970. It might not play.
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException: Unknown video codec.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
Caused by: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException: Unknown video codec.
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:347)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
... 2 more
and I am not able to see the FM radio stations on my Sony.
I have tried a number of fixes, including adding the following to the "Sony BD Player" section of the profiles.xml:
<!-- attempt to fix problem playing mpegts with mp2 audio coming from Hauppauge WinTV FM radio stations -->
<Video targetContainer="mpegts" targetACodec="mp2">
<Matches container="mpegts" ACodec="mp2" />
but have not had any luck. I would appreciate any advice you could provide. Thanks.
-kakker
ffmpeg output for FM radio live stream:
[mpegts @ 0x7f7f7c04ac00] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 0x7f7f7c04ac00] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://192.168.1.25:7799/stream?channel=8970':
Duration: N/A, start: 0.213011, bitrate: 384 kb/s
Program 1
Stream #0.0[0x3e9]: Audio: mp2, 48000 Hz, stereo, s16, 384 kb/s
ffmpeg output for TV live stream:
[mpeg2video @ 0x7fb8d2850800] mpeg_decode_postinit() failure
Last message repeated 13 times
[mpegts @ 0x7fb8d284ac00] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://192.168.1.25:7799/stream?channel=1041':
Duration: N/A, start: 79941.345378, bitrate: 13240 kb/s
Program 3
No Program
Stream #0.0[0x31]: Video: mpeg2video (Main), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 12856 kb/s, 34.64 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0.1[0x34]: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
Post Fri Apr 06, 2012 5:33 pm
Re: Invalid Media Format Exception with mpegts of mp2 only
if you look at the error code, it is saying unknown video codec.
run ffmpeg -i "http://192.168.1.25:7799/stream?channel=8970" in a console and post the results here.
kakker
Post Fri Apr 06, 2012 8:31 pm
Thanks, Mark. As I stated in my original post, the ffmpeg output was
Program 1
The complete output, if you need it, was
ffmpeg version 0.7.11, Copyright (c) 2000-2011 the FFmpeg developers
built on Mar 12 2012 18:57:46 with gcc 4.2.1 (Apple Inc. build 5666) (dot 3)
configuration: --prefix=/opt/local --enable-gpl --enable-postproc --enable-swscale --enable-avfilter --enable-libmp3lame --enable-libvorbis --enable-libtheora --enable-libdirac --enable-libschroedinger --enable-libopenjpeg --enable-libxvid --enable-libx264 --enable-libvpx --enable-libspeex --mandir=/opt/local/share/man --enable-shared --enable-pthreads --cc=/opt/local/bin/gcc-apple-4.2 --arch=x86_64 --enable-yasm
libavutil 50. 43. 0 / 50. 43. 0
libavcodec 52.123. 0 / 52.123. 0
libavformat 52.111. 0 / 52.111. 0
libavdevice 52. 5. 0 / 52. 5. 0
libavfilter 1. 80. 0 / 1. 80. 0
libswscale 0. 14. 1 / 0. 14. 1
Program 1
Post Fri Apr 06, 2012 8:44 pm
Do you have it selected as a video or audio stream in the serviio console?
Look at this group of audio streams.
http://forum.serviio.org/viewforum.php?f=42
I do not think it should not be streaming as a mpegts.
kakker
Post Fri Apr 06, 2012 8:57 pm
I've tried the streams as Video and as Audio, but have encountered basically the same exception for both. The exception for the Audio version is
2012-04-06 16:51:41,445 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://192.168.1.25:7799/stream?channel=8970. It might not play.
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException: Unknown audio file type.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:233)
Caused by: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException: Unknown audio file type.
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:359)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveAudioMetadata(FFmpegMetadataRetriever.java:111)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:257)
... 2 more
Post Fri Apr 06, 2012 9:05 pm
have you tried to listen to the stream using xbmc or any other program capable of listening to streams? A plugin might need to be created for it.
Check you stream url.
192.168.1.xxx is usually an internal lan at a company or home.
kakker
Post Fri Apr 06, 2012 9:35 pm
Mark, as I mentioned in my original post, I set up my own media server on my local network (at home). I have the Hauppauge card in the Windows Home Server 2011 system, and I am running WinTV with Extend. The IP address of the system is 192.168.1.25, and Extend is set up for port 7799. I am able to view/listen to the TV and radio live streams via the Extend client application on an iPad 2, and via VLC, etc.
If I had to guess, I would say that validateCodecsFound, retrieveMetadata, retrieveAudioMetadata, and/or retrieveAVMetadata is/are choking on the process of validating mpeg transport streams which don't contain a video stream.
-kakker
Post Fri Apr 06, 2012 9:56 pm
kakker
Post Sat Apr 07, 2012 3:46 pm
Thanks again, Mark, but VLC is not really an option for me, as such, and I've found nothing I can tweak with Serviio. Seems like Serviio should be able to handle an mpegts stream like this (no video stream, containing mp2 audio only), but that it's not set up to validate a video Online Resource which doesn't contain a video stream, or an audio Online Resource, which has an mpegts container.
Post Sat Apr 07, 2012 5:14 pm
Zip will be able to help you better with this than I can.
I found this, it might be able to help you with this.
http://forum.xbmc.org/showthread.php?tid=111366
Post Sun Apr 08, 2012 6:53 pm
http://www.serviio.org/index.php?option ... icle&id=24
Serviio does not support audio file with mpegts container:
Audio Matches Attributes:
container - compulsory; name of container; possible values: mp4, asf, mp3, lpcm, flac, ogg, flv, rtp, rtsp, adts
Post Tue Apr 10, 2012 12:00 pm
Yep, mpegts has to have a video track, it's considered a video container. Can't you wrap the stream in a mp2 / mp3 file?
kakker
Post Wed Apr 11, 2012 1:51 pm
Thanks, Illico and Petr. Whether or not an mpegts is supposed to always contain a video stream is rather pointless to me, right now, as the audio only stream is what I'm stuck with. I am attempting to write a remux plugin solution, but will be writing it for a different server application. If I'm going to have to write a plugin, there's no sense keeping Serviio in the mix that is my media center. The plugin support is much stronger for the other app, anyway.
Thank you for trying to help, gentlemen.
Users browsing this forum: No registered users and 49 guests
