[Solved] Cannot seem to get filename correct on three files
rdl7890
Post Thu Apr 26, 2012 4:00 am
I have three files that I cannot seem to get the name right so Serviio will recognize them correctly. TMDb does not have a problem finding them.
I have tried a couple of variations of the filenames, but am not sure where to go next. The log file entries for all three are below.
Anybody have any thoughts?
Thanks for any help in advance.
2012-04-22 21:47:18,576 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Mouse Hunt (1997).m4v [VideoDescription [type=FILM, names=[mouse hunt, pg], year=1997, season=null, episode=null]]
2012-04-22 21:47:18,641 INFO  [LibraryAdditionsCheckerThread] Added file 'Mouse Hunt (1997).m4v' (title: Mouse Hunt (1997)) to Library
2012-04-22 21:48:35,334 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Gold Finger (1964).m4v [VideoDescription [type=FILM, names=[gold finger, pg], year=1964, season=null, episode=null]]
2012-04-22 21:48:35,378 INFO  [LibraryAdditionsCheckerThread] Added file 'Gold Finger (1964).m4v' (title: Gold Finger (1964)) to Library
2012-04-22 21:49:04,333 WARN  [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Murder at 1600 (1997).m4v [VideoDescription [type=EPISODE, names=[murder at, r], year=1997, season=16, episode=0]]
2012-04-22 21:49:04,381 INFO  [LibraryAdditionsCheckerThread] Added file 'Murder at 1600 (1997).m4v' (title: Murder at 1600 (1997)) to Library
Post Thu Apr 26, 2012 5:45 am
Re: Cannot seem to get filename correct on three files
Post Thu Apr 26, 2012 4:45 pm
use themoviedb.org for checking. For example Gold Finger should be 'Goldfinger'
rdl7890
Post Fri Apr 27, 2012 1:54 am
Thanks, that got two of them (Mousehunt and Goldfinger). It still does not like "Murder at 1600". All three Databases came back with the exact same name as I already have.
Thanks for the assist.
rdl7890
Post Sun Apr 29, 2012 5:48 pm
If I am reading the log file correctly, Serviio is thinking that "Murder at 1600" is a series titled "Murder at", season 16 episode 0. Is there any way to convince it that 1600 is part of the title?
Post Sun Apr 29, 2012 10:37 pm
ok.. the 1600 matches a episodic pattern, so it thinks it's a series. you could try to give it a name that doesn't include the number, try some of the alternative titles here http://www.themoviedb.org/movie/9415-mu ... lease-info
rdl7890
Post Tue May 01, 2012 1:23 am
Ok.. Changed the title to simply "Murder at (1997)", and it magically found it.
Thanks for the help, I figured the solution was pretty simple, but for some reason, I simply could not figure these three out. Figured out a couple dozen others out over time, but...
Users browsing this forum: Google [Bot] and 23 guests
