Linux Setup on CentOS - "replacement" error
glassware
Post Thu May 31, 2012 7:42 pm
Hi all,
I set up ServIIO on CentOS following the instructions on the wiki: http://wiki.serviio.org/doku.php?id=howto:linux:install
After following these instructions, I noticed that ServIIO wasn't running. I checked the log files and saw this message:
2012-05-31 12:13:52,849 ERROR [ApplicationInstanceManager] themistocles: themistocles
java.net.UnknownHostException: themistocles: themistocles
        at java.net.InetAddress.getLocalHost(InetAddress.java:1426)
        at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:68)
        at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:242)
        at org.serviio.MediaServer.main(MediaServer.java:93)
2012-05-31 12:13:52,855 INFO  [MediaServer] ------------------------------------------------------------------------
2012-05-31 12:13:52,855 INFO  [MediaServer] Serviio DLNA media streaming serverv 0.6.2 (rev. 6a61243292ee)
2012-05-31 12:13:52,855 INFO  [MediaServer] Petr Nejedly 2009-2011
2012-05-31 12:13:52,855 INFO  [MediaServer] http://www.serviio.org
2012-05-31 12:13:52,855 INFO  [MediaServer] Java 1.6.0_22-Sun Microsystems Inc.
2012-05-31 12:13:52,855 INFO  [MediaServer] OS Linux amd64 2.6.32-220.13.1.el6.x86_64
2012-05-31 12:13:52,855 INFO  [MediaServer] File encoding: UTF-8
2012-05-31 12:13:52,856 INFO  [MediaServer] Headless mode enabled: true
2012-05-31 12:13:52,856 INFO  [MediaServer] User home dir: /opt/serviio
2012-05-31 12:13:52,856 INFO  [MediaServer] Temp dir: /tmp
2012-05-31 12:13:52,856 INFO  [MediaServer] ------------------------------------------------------------------------
2012-05-31 12:13:52,921 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2012-05-31 12:13:52,950 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-31 12:13:53,626 WARN  [ProfilesDefinitionParser] Cannot get name of thelocal computer: themistocles: themistocles
2012-05-31 12:13:53,780 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-31 12:13:54,062 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: replacement
java.lang.NullPointerException: replacement
        at java.util.regex.Matcher.replaceFirst(Matcher.java:867)
        at java.lang.String.replaceFirst(String.java:2158)
        at org.serviio.profile.ProfilesDefinitionParser.getDeviceDescription(ProfilesDefinitionParser.java:331)
        at org.serviio.profile.ProfilesDefinitionParser.processProfileNode(ProfilesDefinitionParser.java:194)
        at org.serviio.profile.ProfilesDefinitionParser.parseDefinition(ProfilesDefinitionParser.java:143)
        at org.serviio.profile.ProfileManager.loadProfiles(ProfileManager.java:156)
        at org.serviio.MediaServer.main(MediaServer.java:105)
2012-05-31 12:23:05,136 ERROR [ApplicationInstanceManager] themistocles: themistocles java.net.UnknownHostException: themistocles: themistocles
After a bit of debugging, I solved the issue. The problem was that ServIIO requires that your machine's hostname match a valid DNS entry. Unfortunately, the server didn't tell me that - I thought that maybe my "profiles.xml" file was damaged due to the way it said "replaceFirst" in a regex string was the error.
The solution was to fix my machine's "hostname" to match an entry in the "/etc/hosts" file. My hostname is "themistocles" and I have this line in "/etc/hosts":
127.0.0.1               localhost.localdomain localhost themistocles
After I made that minor change, ServIIO ran successfully. Perhaps this note will save someone else some trouble!
jabrown0604
Post Thu May 31, 2012 9:57 pm
Re: Linux Setup on CentOS - "replacement" error
Glad you fixed your issue. I experienced a similar issue last week with ubuntu 12.04 server at work. It is always good practice to have your hostname file and your hosts file show the same machine name if possible.
“Those who have succeeded at anything and don’t mention luck are kidding themselves.”
Server-Mac Mini / OS-WHS 2011 SP1 / TV/HTS-Sharp Aquos/Samsung HT-C6600
Users browsing this forum: Baidu [Spider] and 97 guests
