WTV and wma support for a noob (HELP!)
botcolon
Post Tue May 29, 2012 11:56 pm
Hi there,
I am impressed by serviio and just installed it on my Ubuntu headless server 12.04 LTS but need 3 things ironed out before I give it the go ahead (otherwise its back to mediatomb):
1. I can’t play wma music on my android xperia arc S, so I need to transcode this ‘on the fly’ to mp3 if possible?
2. I can play WTV tv recordings but they are choppy on my android. I would like to downsize so the bitrate doesn’t choke on my wifi (802.11g)/android cpu. (not sure which is causing it)
3. What would I need to do to enable access via the WAN. I wish to use SSH access via eth0.
From my understanding I need to build a profile for the android phone, but I am completely out of my depth. I have searched the wiki/forums for 2 days but I can’t seem to find a direct thread which shows me how. Any chance someone could help/show me how? I know how to edit the profiles.xml file, but it’s the content I struggle with. 
I am running a stock standard profiles.xml
and ffmpeg was obtained by ‘sudo apt-get install ffmpeg’ command.
Android is running bubbleupnp and vplayer (can also use mxplayer). I am using serviiodroid to manage.
Any help would be appreciated.
michael
Post Fri Jun 01, 2012 8:17 am
Re: WTV and wma support for a noob (HELP!)
Possible, look at Sony profiles (container="asf"), set target container to mp3. More info here: http://www.serviio.org/index.php?option ... icle&id=24
Will be possible in 1.0 via a profile
Will be built-in in 1.0
botcolon
Post Fri Jun 01, 2012 11:50 am
thanks zip,
'asf' hasn't helped. I applied it to all of the audo place in the sony profiles. restarted serviio, but still not being played by my arc'S'
when is 1.0 planned?
michael
Post Sat Jun 02, 2012 10:16 am
what I meant is you will need a trancoding section that will look something like this:
<Audio targetContainer="mp3">
  <Matches container="asf" />
</Audio>
Users browsing this forum: No registered users and 107 guests
