Can't create cache file!
ciaran75
Post Sun Jun 03, 2012 12:38 pm
Hi All,
I've installed serviio 061 on my Dlink 320 using the following instructions
http://wiki.serviio.org/doku.php?id=install_dlinkdns3xx
it is working fine but in the log file for every video i get the messages like below, tv shows, movies etc.
2012-06-03 01:07:58,240 INFO [LibraryAdditionsCheckerThread] Added file 'game.of.thrones.s01e05.hdtv.xvid-fqm.avi' (title: The Wolf and the Lion) to Library
2012-06-03 01:08:13,037 WARN [CoverImageService] Cannot convert/resize art to JPG. Message: Error reading image for resizing. Message: Can't create cache file!
i've tried the online metadata sources and mymovies but get the same for both.
is there anything i need to do to fix.
Thanks,
Ciaran
Post Sun Jun 03, 2012 1:17 pm
Re: Can't create cache file!
it seems to come from java itself, possibly not enough memory/disk space.
ciaran75
Post Sun Jun 03, 2012 7:20 pm
hi zip,
thanks so much for such a prompt reply
i have over 70Gb diskspace free on main drive and nearly 300Gb on second drive so shouldn't be disk space.
would i be able to update java? might that solve it?
thanks,
Post Tue Jun 05, 2012 4:27 pm
I think it's down to lack of memory. This will only fail to create thumbnails so you can live with it. You can also disable generating thumbnails in the console (boh local and DVD covers for online metadata)
Users browsing this forum: No registered users and 115 guests
