LG TV disconnects, event subscription errors
dreamlayers
Post Fri Jun 22, 2012 2:11 am
I'm using Serviio 0.6.2 and Java SE 7u5 on 32 bit Windows 7, with an LG 47LW5600 TV. The only thing that changed recently was Java, but I've watched some things since then without problems. Today, I first got a pause, and then several times the TV said the device disconnected. I can resume playback, but another disconnection happens in a few minutes.
The MKV file seems fine and this is not linked to specific points in the file. I can normally proceed past points which caused disconnection in the past. The bitrate isn't excessive, and transcoding is not in use. In the Serviio log I see these messages:
2012-06-21 21:37:01,983 WARN  [EventDispatcher] Couldn't send event message for subscription 9f0c1130-c01c-4395-8a8e-6f1112243969, will keep trying until subscription expires
2012-06-21 21:37:02,993 WARN  [EventDispatcher] Couldn't send event message for subscription ab3a5a2e-22e7-41d1-8a02-b81f7c7a1ec6, will keep trying until subscription expires
2012-06-21 21:41:21,004 WARN  [EventDispatcher] Couldn't send event message for subscription 9f0c1130-c01c-4395-8a8e-6f1112243969, will keep trying until subscription expires
2012-06-21 21:41:22,015 WARN  [EventDispatcher] Couldn't send event message for subscription ab3a5a2e-22e7-41d1-8a02-b81f7c7a1ec6, will keep trying until subscription expires
2012-06-21 21:53:10,594 WARN  [EventDispatcher] Error 412 received from event subscriber
2012-06-21 21:53:11,595 WARN  [EventDispatcher] Couldn't send event message for subscription f7190498-7a22-4e3f-827b-720e56deafd4, will keep trying until subscription expires
2012-06-21 21:54:30,612 WARN  [EventDispatcher] Error 412 received from event subscriber
2012-06-21 21:54:31,617 WARN  [EventDispatcher] Couldn't send event message for subscription f7190498-7a22-4e3f-827b-720e56deafd4, will keep trying until subscription expires
2012-06-21 22:00:01,647 WARN  [EventDispatcher] Couldn't send event message for subscription f7190498-7a22-4e3f-827b-720e56deafd4, will keep trying until subscription expires
This is all from tonight, and the times seem to approximately correspond to when the errors happened. I don't see any Error 412 messages in older logs. Those logs also have at most only one "Couldn't send event message for subscription" error over a much longer time period. I've stopped and restarted Serviio, and it didn't help. Turning the TV off and back on didn't help either.
Post Sat Jun 23, 2012 3:16 pm
Re: LG TV disconnects, event subscription errors
these error messages should not have any impact on playback. Are you connected wirelessly? If yes it might be high traffic on the channel.
dreamlayers
Post Sun Jun 24, 2012 4:59 pm
I'm using a wired 100Mbit Ethernet network. The network shouldn't have been congested during that time, and I didn't notice any other networking problems. I'll keep that in mind however, and do some network testing if I encounter the problem again.
Edit: Yes, it is a networking problem. Plex is also affected, though there I get more frequent short pauses instead of rare longer ones, and it doesn't disconnect. The problem happens if wireless is turned on at the router. It's kind of weird, because nobody should have been using the wireless, and it's secured via hidden SSID plus WPA2-AES.
Users browsing this forum: No registered users and 90 guests
