MKV video file stutters a lot
xs2inattar
Post Tue Jun 26, 2012 9:43 pm
One video file on my system stutters a lot when other similar files with much higher resolutions and bitrate works fine.
I am using Synology DS212+ as server and PS3 is the rendered.
Please find the media file details as follows.
ffmpeg output
FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
  configuration: --enable-cross-compile --cross-prefix=/home/slug/optware/cs08q1armel/toolchain/arm-2008q1/bin/arm-none-linux-gnueabi- --arch=arm --disable-encoder=snow --disable-decoder=snow --enable-shared --disable-static --enable-gpl --enable-postproc --prefix=/opt
  libavutil version: 49.6.0
  libavcodec version: 51.54.0
  libavformat version: 52.13.0
  libavdevice version: 52.0.0
  built on Feb 14 2012 11:43:06, gcc: 4.2.3
[matroska @ 0x400afdf4]Ignoring seekhead entry for ID=0x114d9b74
[matroska @ 0x400afdf4]Ignoring seekhead entry for ID=0x1549a966
[matroska @ 0x400afdf4]Ignoring seekhead entry for ID=0x1654ae6b
[matroska @ 0x400afdf4]Unknown entry 0x73a4 in info header
Input #0, matroska, from 'No Entry (2005).mkv':
  Duration: 02:41:00.1, start: 0.000000, bitrate: N/A
    Stream #0.0(eng): Video: h264, yuv420p, 1280x544 [PAR 1:1 DAR 40:17], 24.00 tb(r)
    Stream #0.1: Audio: 0x0000, 48000 Hz, stereo
Must supply at least one output file
Mediainfo output
Unique ID                                : 25435730219733633055106457035411862775 (0x1322BE52A854D2E52F4D460178ACB4F7)
Complete name                            : \\RR-DS212PLUS\video\Movies\No Entry (2005)\No Entry (2005).mkv
File size                                : 846 MiB
Duration                                 : 2h 41mn
Overall bit rate                         : 734 Kbps
Writing application                      : HandBrake 0.9.6
Writing library                          : libmkv 0.6.5
Format profile                           : High@L3.1
Duration                                 : 2h 41mn
Nominal bit rate                         : 600 Kbps
Height                                   : 544 pixels
Display aspect ratio                     : 2.35:1
Frame rate mode                          : Variable / Variable
Frame rate                               : 24.000 fps
Bits/(Pixel*Frame)                       : 0.036
Writing library                          : x264 core 120
Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=2pass / mbtree=1 / bitrate=600 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Color primaries                          : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics                 : BT.709-5, BT.1361
Matrix coefficients                      : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Codec ID                                 : A_AAC
Duration                                 : 2h 41mn
Detailed log
2012-06-26 17:49:36,394 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 669
2012-06-26 17:49:36,479 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-06-26 17:49:36,581 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-06-26 17:49:36,707 DEBUG [WebServer] Incoming connection from /192.168.1.8:62790
2012-06-26 17:49:36,728 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.8:
2012-06-26 17:49:36,728 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:49:36,838 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R4$F614$F669, browseFlag = BrowseDirectChildren, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 10, sortCriteria =
2012-06-26 17:49:36,839 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 669
2012-06-26 17:49:37,232 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 669 (from=0, count=10)
2012-06-26 17:49:37,596 DEBUG [GenreDAOImpl] Reading a Genre (id = 2)
2012-06-26 17:49:37,734 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1233)
2012-06-26 17:49:37,814 DEBUG [MediaItemDAOImpl] Getting file of media item 1233
2012-06-26 17:49:38,670 DEBUG [VideoDAOImpl] Reading a Video (id = 1233)
2012-06-26 17:49:38,780 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1233 and profile Playstation 3
2012-06-26 17:49:38,802 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file No Entry (2005).mkv: AVC_TS_MP_HD_AC3_ISO
2012-06-26 17:49:38,843 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 804)
2012-06-26 17:49:39,121 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 669
2012-06-26 17:49:39,126 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-06-26 17:49:39,202 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-06-26 17:49:39,407 DEBUG [WebServer] Incoming connection from /192.168.1.8:62789
2012-06-26 17:49:39,408 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.8:
2012-06-26 17:49:39,408 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:49:39,446 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-06-26 17:49:39,487 DEBUG [WebServer] Incoming connection from /192.168.1.8:62788
2012-06-26 17:49:39,508 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.8:
2012-06-26 17:49:39,508 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:49:39,507 DEBUG [WebServer] Incoming connection from /192.168.1.8:62787
2012-06-26 17:49:39,522 DEBUG [ResourceTransportRequestHandler] GET /resource/804/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-06-26 17:49:39,523 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:49:39,548 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-06-26 17:49:39,553 DEBUG [ResourceTransportRequestHandler] Request for resource 804 and type 'COVER_IMAGE' received
2012-06-26 17:49:39,558 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R4$F614$F669, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-06-26 17:49:39,559 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-06-26 17:49:39,573 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-06-26 17:49:39,617 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 804)
2012-06-26 17:49:39,708 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 804
2012-06-26 17:49:39,727 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5997
2012-06-26 17:49:39,729 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-06-26 17:49:39,729 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5997,Date: Tue, 26 Jun 2012 21:49:39 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-06-26 17:49:41,928 INFO  [PluginCompilerThread] Added Web Resouce plugin Playlist extractor (Playlist.groovy)
2012-06-26 17:49:42,142 INFO  [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy)
2012-06-26 17:49:43,289 INFO  [PluginCompilerThread] Added Feed plugin AnOriantUrlExtractor (AnOriant.groovy)
2012-06-26 17:49:43,522 INFO  [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy)
2012-06-26 17:49:43,749 DEBUG [WebServer] Incoming connection from /192.168.1.8:62786
2012-06-26 17:49:43,750 DEBUG [ResourceTransportRequestHandler] GET /resource/1233/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2012-06-26 17:49:43,750 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:49:43,756 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-06-26 17:49:43,770 DEBUG [ResourceTransportRequestHandler] Request for resource 1233 and type 'MEDIA_ITEM' received
2012-06-26 17:49:43,771 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1233 (local)
2012-06-26 17:49:43,771 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1233)
2012-06-26 17:49:43,774 DEBUG [VideoDAOImpl] Reading a Video (id = 1233)
2012-06-26 17:49:43,789 DEBUG [VideoDeliveryEngine] Delivering item '1233' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-06-26 17:49:43,789 DEBUG [VideoDeliveryEngine] Delivering file 'No Entry (2005).mkv' using transcoding
2012-06-26 17:49:43,790 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-06-26 17:49:43,793 DEBUG [MediaItemDAOImpl] Getting file of media item 1233
2012-06-26 17:49:43,811 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /volume1/video/Movies/No Entry (2005)/No Entry (2005).mkv
2012-06-26 17:49:43,812 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg-wrapper.sh -i /volume1/video/Movies/No Entry (2005)/No Entry (2005).mkv -y -async 1 -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /.tmp/Serviio/transcoding-temp-1233-MPEG2TS.stf
2012-06-26 17:49:45,848 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-06-26 17:49:45,851 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file No Entry (2005).mkv: AVC_TS_MP_HD_AC3_ISO
2012-06-26 17:49:45,852 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1233) as read
2012-06-26 17:49:46,858 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-06-26 17:49:46,860 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-06-26 17:49:46,860 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-06-26 17:49:46,861 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-06-26 17:49:46,861 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-9660.0/9660,Date: Tue, 26 Jun 2012 21:49:46 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-06-26 17:49:53,047 DEBUG [WebServer] I/O error: Broken pipe
2012-06-26 17:49:53,057 DEBUG [WebServer] Incoming connection from /192.168.1.8:62784
2012-06-26 17:49:53,057 DEBUG [ResourceTransportRequestHandler] GET /resource/1233/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,TimeSeekRange.dlna.org: npt=0.000-,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-06-26 17:49:53,058 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:49:53,060 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-06-26 17:49:53,064 DEBUG [ResourceTransportRequestHandler] Request for resource 1233 and type 'MEDIA_ITEM' received
2012-06-26 17:49:53,064 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1233 (local)
2012-06-26 17:49:53,064 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1233)
2012-06-26 17:49:53,077 DEBUG [VideoDAOImpl] Reading a Video (id = 1233)
2012-06-26 17:49:53,081 DEBUG [VideoDeliveryEngine] Delivering item '1233' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-06-26 17:49:53,081 DEBUG [VideoDeliveryEngine] Delivering file 'No Entry (2005).mkv' using transcoding
2012-06-26 17:49:53,082 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-06-26 17:49:53,082 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-06-26 17:49:53,083 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file No Entry (2005).mkv: AVC_TS_MP_HD_AC3_ISO
2012-06-26 17:49:53,084 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1233) as read
2012-06-26 17:49:53,157 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-06-26 17:49:53,157 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-06-26 17:49:53,158 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-06-26 17:49:53,158 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-06-26 17:49:53,159 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-9660.0/9660,Date: Tue, 26 Jun 2012 21:49:53 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-06-26 17:50:15,408 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.11, timeout = 0
2012-06-26 17:50:15,411 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 61cd396e-1894-3da9-91a2-e8090bcf4e54
2012-06-26 17:50:16,187 DEBUG [WebServer] Incoming connection from /192.168.1.8:62783
2012-06-26 17:50:16,188 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:49:35 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:50:16,188 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:50:16,191 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:49:35 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:50:16,192 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:50:16,263 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-06-26 17:50:17,386 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:01
2012-06-26 17:50:18,277 DEBUG [WebServer] Incoming connection from /192.168.1.8:62782
2012-06-26 17:50:18,278 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:49:37 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:50:18,278 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:50:18,280 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:49:37 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:50:18,281 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:50:18,297 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-06-26 17:50:28,936 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-26 17:50:28,936 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-26 17:50:28,981 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 25)
2012-06-26 17:50:28,984 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 30)
2012-06-26 17:50:29,118 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 34)
2012-06-26 17:50:29,120 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 35)
2012-06-26 17:50:29,122 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-06-26 17:50:29,124 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 37)
2012-06-26 17:50:29,146 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 38)
2012-06-26 17:50:29,149 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 39)
2012-06-26 17:50:42,164 DEBUG [WebServer] I/O error: Connection reset
2012-06-26 17:51:18,858 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.11, timeout = 0
2012-06-26 17:51:18,862 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 61cd396e-1894-3da9-91a2-e8090bcf4e54
2012-06-26 17:51:20,357 DEBUG [WebServer] Incoming connection from /192.168.1.8:62776
2012-06-26 17:51:20,358 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:50:39 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:51:20,358 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:51:20,360 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:50:39 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:51:20,361 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:51:20,389 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-06-26 17:51:20,836 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:27
2012-06-26 17:51:29,156 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-26 17:51:29,156 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-26 17:51:29,162 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 25)
2012-06-26 17:51:29,164 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 30)
2012-06-26 17:51:29,217 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 34)
2012-06-26 17:51:29,221 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 35)
2012-06-26 17:51:29,223 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-06-26 17:51:29,225 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 37)
2012-06-26 17:51:29,237 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 38)
2012-06-26 17:51:29,240 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 39)
2012-06-26 17:52:23,244 DEBUG [WebServer] I/O error: Broken pipe
2012-06-26 17:52:23,367 DEBUG [WebServer] Incoming connection from /192.168.1.8:62770
2012-06-26 17:52:23,368 DEBUG [ResourceTransportRequestHandler] GET /resource/804/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-06-26 17:52:23,368 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:52:23,370 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-06-26 17:52:23,371 DEBUG [ResourceTransportRequestHandler] Request for resource 804 and type 'COVER_IMAGE' received
2012-06-26 17:52:23,371 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 804)
2012-06-26 17:52:23,374 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 804
2012-06-26 17:52:23,374 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5997
2012-06-26 17:52:23,375 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-06-26 17:52:23,375 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5997,Date: Tue, 26 Jun 2012 21:52:23 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-06-26 17:52:29,246 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-26 17:52:29,246 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-26 17:52:29,252 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 25)
2012-06-26 17:52:29,254 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 30)
2012-06-26 17:52:29,292 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 34)
2012-06-26 17:52:29,294 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 35)
2012-06-26 17:52:29,307 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-06-26 17:52:29,309 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 37)
2012-06-26 17:52:29,311 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 38)
2012-06-26 17:52:29,313 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 39)
2012-06-26 17:52:29,917 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:61cd396e-1894-3da9-91a2-e8090bcf4e54 from address /192.168.1.9:8547
2012-06-26 17:52:29,928 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.9:8547
2012-06-26 17:52:47,927 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.11, timeout = 0
2012-06-26 17:52:47,930 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 61cd396e-1894-3da9-91a2-e8090bcf4e54
2012-06-26 17:52:49,907 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:21
2012-06-26 17:52:50,497 DEBUG [WebServer] Incoming connection from /192.168.1.8:62764
2012-06-26 17:52:50,498 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:52:09 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:52:50,498 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:52:50,500 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:52:09 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:52:50,501 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:52:50,519 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-06-26 17:52:52,090 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:52:55,091 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:52:58,092 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:53:01,148 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:53:04,141 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:53:07,143 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:53:29,316 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-26 17:53:29,317 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-26 17:53:29,322 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 25)
2012-06-26 17:53:29,324 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 30)
2012-06-26 17:53:29,377 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 34)
2012-06-26 17:53:29,389 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 35)
2012-06-26 17:53:29,391 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-06-26 17:53:29,393 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 37)
2012-06-26 17:53:29,395 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 38)
2012-06-26 17:53:29,407 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 39)
2012-06-26 17:53:52,485 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:53:55,485 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:53:58,486 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:53:59,973 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:61cd396e-1894-3da9-91a2-e8090bcf4e54 from address /192.168.1.9:8547
2012-06-26 17:53:59,974 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.9:8547
2012-06-26 17:54:01,547 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:54:04,538 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:54:07,539 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:64474
2012-06-26 17:54:10,937 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.11, timeout = 0
2012-06-26 17:54:10,939 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 61cd396e-1894-3da9-91a2-e8090bcf4e54
2012-06-26 17:54:12,588 DEBUG [WebServer] Incoming connection from /192.168.1.8:62758
2012-06-26 17:54:12,589 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:53:31 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:54:12,589 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:54:12,591 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:53:31 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:54:12,592 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:54:12,609 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-06-26 17:54:12,917 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:24
2012-06-26 17:54:29,416 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-26 17:54:29,417 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-26 17:54:29,422 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 25)
2012-06-26 17:54:29,424 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 30)
2012-06-26 17:54:29,475 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 34)
2012-06-26 17:54:29,489 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 35)
2012-06-26 17:54:29,491 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-06-26 17:54:29,493 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 37)
2012-06-26 17:54:29,496 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 38)
2012-06-26 17:54:29,509 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 39)
2012-06-26 17:55:29,516 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-26 17:55:29,517 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-26 17:55:29,522 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 25)
2012-06-26 17:55:29,524 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 30)
2012-06-26 17:55:29,624 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 34)
2012-06-26 17:55:29,647 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 35)
2012-06-26 17:55:29,649 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-06-26 17:55:29,651 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 37)
2012-06-26 17:55:29,653 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 38)
2012-06-26 17:55:29,656 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 39)
2012-06-26 17:55:30,025 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:61cd396e-1894-3da9-91a2-e8090bcf4e54 from address /192.168.1.9:8547
2012-06-26 17:55:30,026 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.9:8547
2012-06-26 17:55:37,748 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.11, timeout = 0
2012-06-26 17:55:37,749 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 61cd396e-1894-3da9-91a2-e8090bcf4e54
2012-06-26 17:55:38,738 DEBUG [WebServer] Incoming connection from /192.168.1.8:62747
2012-06-26 17:55:38,739 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:54:58 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:55:38,740 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:55:38,742 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:54:58 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:55:38,742 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:55:38,769 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-06-26 17:55:39,727 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:14
2012-06-26 17:55:51,172 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.3:64474
2012-06-26 17:55:51,177 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.3:64474
2012-06-26 17:55:51,180 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.3:64474
2012-06-26 17:55:51,188 DEBUG [WebServer] Incoming connection from /192.168.1.3:21013
2012-06-26 17:55:51,189 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.3 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.11:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50])
2012-06-26 17:55:51,190 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.3
2012-06-26 17:55:51,195 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.11:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]
2012-06-26 17:55:51,207 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.3
2012-06-26 17:55:51,215 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-06-26 17:55:51,347 DEBUG [WebServer] Incoming connection from /192.168.1.3:21016
2012-06-26 17:55:51,347 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-06-26 17:55:54,173 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.3:64474
2012-06-26 17:55:54,178 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.3:64474
2012-06-26 17:55:54,179 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.3:64474
2012-06-26 17:55:57,175 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.3:64474
2012-06-26 17:55:57,177 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.3:64474
2012-06-26 17:55:57,178 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.3:64474
2012-06-26 17:56:29,686 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-26 17:56:29,687 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-26 17:56:29,692 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 25)
2012-06-26 17:56:29,694 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 30)
2012-06-26 17:56:29,734 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 34)
2012-06-26 17:56:29,736 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 35)
2012-06-26 17:56:29,748 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-06-26 17:56:29,750 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 37)
2012-06-26 17:56:29,752 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 38)
2012-06-26 17:56:29,754 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 39)
2012-06-26 17:56:54,238 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.11, timeout = 0
2012-06-26 17:56:54,240 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 61cd396e-1894-3da9-91a2-e8090bcf4e54
2012-06-26 17:56:54,957 DEBUG [WebServer] Incoming connection from /192.168.1.8:62735
2012-06-26 17:56:54,958 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:56:14 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:56:54,959 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:56:54,961 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:56:14 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:56:54,961 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:56:54,979 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-06-26 17:56:56,217 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:18
2012-06-26 17:56:56,998 DEBUG [WebServer] Incoming connection from /192.168.1.8:62734
2012-06-26 17:56:56,999 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:56:16 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:56:57,007 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:56:57,009 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:56:16 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:56:57,010 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:56:57,014 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-06-26 17:57:00,049 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:00113212-668a-0011-8a66-8a6612321100 from address /192.168.1.9:8547
2012-06-26 17:57:00,176 DEBUG [WebServer] I/O error: Connection reset
2012-06-26 17:57:29,756 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-06-26 17:57:29,757 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-06-26 17:57:29,762 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 25)
2012-06-26 17:57:29,764 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 30)
2012-06-26 17:57:29,802 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 34)
2012-06-26 17:57:29,807 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 35)
2012-06-26 17:57:29,809 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-06-26 17:57:29,811 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 37)
2012-06-26 17:57:29,813 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 38)
2012-06-26 17:57:29,815 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 39)
2012-06-26 17:58:00,115 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:61cd396e-1894-3da9-91a2-e8090bcf4e54 from address /192.168.1.9:8547
2012-06-26 17:58:00,126 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.9:8547
2012-06-26 17:58:14,707 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.11, timeout = 0
2012-06-26 17:58:14,709 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 61cd396e-1894-3da9-91a2-e8090bcf4e54
2012-06-26 17:58:16,687 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:18
2012-06-26 17:58:17,077 DEBUG [WebServer] Incoming connection from /192.168.1.8:62728
2012-06-26 17:58:17,078 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 61cd396e-1894-3da9-91a2-e8090bcf4e54 from 192.168.1.8 (headers = [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:57:36 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-06-26 17:58:17,078 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:58:17,081 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.11:8895,Date: Tue, 26 Jun 2012 21:57:36 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-06-26 17:58:17,082 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-06-26 17:58:17,099 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
Post Tue Jun 26, 2012 10:07 pm
Re: MKV video file stutters a lot
try upgrading your FFmpeg, it's 4 years old
xs2inattar
Post Tue Jun 26, 2012 10:27 pm
I just updated the ffmpeg version, but the problem still exists.
Here is the out from the new ffmpeg.
ffmpeg version 0.9-Serviio, Copyright (c) 2000-2011 the FFmpeg developers
  built on Dec 19 2011 01:36:11 with gcc 4.2.3
  configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/tmp/lib --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-pthreads --enable-libmp3lame --enable-librtmp --extra-version=Serviio
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 24.00 (24/1)
Input #0, matroska,webm, from 'No Entry (2005).mkv':
  Duration: 02:41:00.12, start: 0.000000, bitrate: 734 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x544 [SAR 1:1 DAR 40:17], 24 fps, 24 tbr, 1k tbn, 180k tbc (default)
    Stream #0:1: Audio: aac, 48000 Hz, stereo, s16 (default)
Post Wed Jun 27, 2012 4:54 pm
enable detailed log and play the file, then post the log here
Post Thu Jun 28, 2012 6:58 am
xs2inattar wrote:One video file on my system stutters a lot when other similar files with much higher resolutions and bitrate works fine.
I noticed some problem with HandBrake 0.9.6 writing application, variable frame rate is used.
I used TsMuxer tool to force constant frame rate (24 fps) on video stream. You can also have a look at MkvMerge tools, you should probably change the video frame rate.
xs2inattar
Post Sat Jun 30, 2012 4:44 pm
zip wrote:enable detailed log and play the file, then post the log here
i am on Synology NAS DS212+
renderer: PS3
video lags a lot.
detailed log attached.
serviio-mkv-file-lag.log
(33.77 KiB) Downloaded 729 times
Post Mon Jul 02, 2012 6:39 pm
that should not have any problems in this case. Did you try Illico's suggestion? Might be just a dodgy file.
xs2inattar
Post Mon Jul 02, 2012 11:23 pm
Zip, i converted the file to .avi and it is working fine. I wanted to share the details, just to be sure if it was the file or some bug with Serviio.
Any news on my Android online sources play issue?? I haven't been able to play any online sources on my Acer Iconia A500.
Post Tue Jul 03, 2012 9:43 am
xs2inattar wrote:Zip, i converted the file to .avi and it is working fine. I wanted to share the details, just to be sure if it was the file or some bug with Serviio.
Ok, but, Could you try my suggestion? viewtopic.php?f=5&t=6536&p=47683#p47332
xs2inattar
Post Tue Jul 03, 2012 3:14 pm
Illico, I tried forcing the frame rate to 24fps using tsmuxer as well as mkvmerge, but media info still shows frame rate mode as variable.
Suggestions???
Post Tue Jul 03, 2012 3:41 pm
xs2inattar wrote:Illico, I tried forcing the frame rate to 24fps using tsmuxer as well as mkvmerge, but media info still shows frame rate mode as variable.
Suggestions???
No (what is the command option used with TsMuxer tools?)
xs2inattar
Post Tue Jul 03, 2012 4:29 pm
Illico wrote:????
I used the tsmuxer gui. below are the muxing options it is generating:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr  --vbv-len=500
V_MPEG4/ISO/AVC, "\\RR-DS212PLUS\video\Movies\No Entry (2005)\No Entry (2005).mkv", fps=24, insertSEI, contSPS, ar=As source, track=1, lang=eng
A_AAC, "\\RR-DS212PLUS\video\Movies\No Entry (2005)\No Entry (2005).mkv", track=2, lang=und
Users browsing this forum: No registered users and 56 guests
