Serviio suddenly missing files
kdp99
Post Wed May 23, 2012 9:27 pm
Hi Folks
I have been using serviio for 16+months with great sucess. I am on XP with a Samsung 5500 and Servio0 0.6.2
In the last two days Serviio has not found all the files in various folders, I have auto re-fresh on and have also done various forced refreshes without sucess. I then removed and readded the shares and now it finds some files that it missed before and misses a lot of files it found before.
I know that the files are there and play OK, as I also have the Samsung DNLA program an it finds and plays them.
I am stumpped for an answer, but there have been a lots of windows updates installed recently, and suspect its related to this ?? but have no idea of any fix.
Any help most welcome, thanks in advance
Kdp99
Post Thu May 24, 2012 4:30 pm
Re: Serviio suddenly missing files
any errors in the log? possible user rights changes on your folders?
kdp99
Post Thu May 24, 2012 7:08 pm
Zip,
Thanks for the reply, it seems that each time I re-start serviio (or removed and redid the shares), I get less and less files, I've just done it again and now it find no files, although it finds the top level shared directories but no files or the sub-directories , (and I have checked that these have simple sharing enabled), I've also check and the Samsung DNLA manager finds them and plays them).
I stopped serviio, deleted the log file and started it again, log file copied below:
2012-05-24 19:58:10,750 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-24 19:58:10,750 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-05-24 19:58:10,750 INFO [MediaServer] Petr Nejedly 2009-2011
2012-05-24 19:58:10,750 INFO [MediaServer] http://www.serviio.org
2012-05-24 19:58:10,750 INFO [MediaServer] Java 1.6.0_07-Sun Microsystems Inc.
2012-05-24 19:58:10,750 INFO [MediaServer] OS Windows XP x86 5.1
2012-05-24 19:58:10,750 INFO [MediaServer] File encoding: windows-1252
2012-05-24 19:58:10,750 INFO [MediaServer] Headless mode enabled: true
2012-05-24 19:58:10,750 INFO [MediaServer] User home dir: C:\Documents and Settings\LocalService.NT AUTHORITY
2012-05-24 19:58:10,750 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2012-05-24 19:58:11,296 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-05-24 19:58:11,546 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-24 19:58:17,984 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-24 19:58:18,843 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-05-24 19:58:19,546 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-05-24 19:58:19,875 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-05-24 19:58:20,296 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-05-24 19:58:20,515 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-05-24 19:58:20,671 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-05-24 19:58:21,500 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-05-24 19:58:21,546 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-05-24 19:58:22,187 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-05-24 19:58:23,250 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-05-24 19:58:23,734 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-05-24 19:58:24,140 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-05-24 19:58:24,453 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-05-24 19:58:24,515 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-05-24 19:58:24,687 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-05-24 19:58:24,781 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-05-24 19:58:25,078 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-05-24 19:58:25,218 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-05-24 19:58:25,625 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-05-24 19:58:25,859 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-05-24 19:58:27,921 INFO [WebServer] Socket buffer set to 65535 bytes
2012-05-24 19:58:27,937 INFO [Device] Created UPnP Device with UUID: c41c5514-0d79-3774-967b-023b9e31d01f, bound address: 192.168.0.2
2012-05-24 19:58:28,265 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-05-24 19:58:28,265 INFO [PluginCompilerThread] Started looking for plugins
2012-05-24 19:58:28,718 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-24 19:58:29,000 INFO [WebServer] WebServer starting on port 8895
2012-05-24 19:58:29,062 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-24 19:58:29,062 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-24 19:58:29,062 INFO [EventDispatcher] Starting EventDispatcher
2012-05-24 19:58:29,093 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.0.2, timeout = 0
2012-05-24 19:58:29,093 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-24 19:58:29,093 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-24 19:58:36,718 INFO [ServiioConsole] Starting Serviio Console
2012-05-24 19:58:37,484 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-24 19:58:39,218 INFO [Messages] Loaded console message bundle for locale: en
2012-05-24 19:58:39,234 INFO [UpdateChecker] Checking if a new version is available
2012-05-24 19:58:42,359 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-05-24 19:58:43,281 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-05-24 19:58:52,953 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-24 19:58:52,968 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-24 19:58:55,156 INFO [FeedUpdaterThread] Started looking for information about online resources
kdp99
Post Thu May 24, 2012 7:13 pm
After another stop/start its now lost even the top level shared folders.
The log file looked a bit sparse, so I turned on detailed loggin and did the same, data below.
2012-05-24 20:10:45,953 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-05-24 20:10:45,968 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-24 20:10:45,968 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-05-24 20:10:45,968 INFO [MediaServer] Petr Nejedly 2009-2011
2012-05-24 20:10:45,968 INFO [MediaServer] http://www.serviio.org
2012-05-24 20:10:45,968 INFO [MediaServer] Java 1.6.0_07-Sun Microsystems Inc.
2012-05-24 20:10:45,968 INFO [MediaServer] OS Windows XP x86 5.1
2012-05-24 20:10:45,968 INFO [MediaServer] File encoding: windows-1252
2012-05-24 20:10:45,968 INFO [MediaServer] Headless mode enabled: true
2012-05-24 20:10:45,968 INFO [MediaServer] User home dir: C:\Documents and Settings\LocalService.NT AUTHORITY
2012-05-24 20:10:45,968 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2012-05-24 20:10:46,125 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-05-24 20:10:46,187 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-24 20:10:46,187 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-05-24 20:10:48,093 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-05-24 20:10:48,093 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-05-24 20:10:48,093 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-05-24 20:10:48,109 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-05-24 20:10:48,109 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-05-24 20:10:48,109 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-05-24 20:10:48,109 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-05-24 20:10:48,109 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-05-24 20:10:48,109 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-05-24 20:10:48,109 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-05-24 20:10:48,109 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-05-24 20:10:48,515 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-24 20:10:48,625 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-05-24 20:10:49,375 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-05-24 20:10:49,375 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-05-24 20:10:49,937 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-05-24 20:10:49,937 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-05-24 20:10:50,296 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-05-24 20:10:50,312 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-05-24 20:10:50,812 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-05-24 20:10:50,812 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-05-24 20:10:51,046 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-05-24 20:10:51,046 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-05-24 20:10:51,203 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-05-24 20:10:51,203 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-05-24 20:10:51,953 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-05-24 20:10:51,953 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-05-24 20:10:52,093 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-05-24 20:10:52,093 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2012-05-24 20:10:52,890 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-05-24 20:10:52,890 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-05-24 20:10:53,625 DEBUG [ServiioConsole] Initializing Serviio Console
2012-05-24 20:10:53,703 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2012-05-24 20:10:53,703 INFO [ServiioConsole] Starting Serviio Console
2012-05-24 20:10:53,875 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2012-05-24 20:10:54,000 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-24 20:10:54,484 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-05-24 20:10:54,500 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2012-05-24 20:10:55,390 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-05-24 20:10:55,406 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-05-24 20:10:55,984 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-05-24 20:10:56,000 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-05-24 20:10:56,234 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-05-24 20:10:56,250 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-05-24 20:10:56,296 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-05-24 20:10:56,296 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-05-24 20:10:56,500 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-05-24 20:10:56,515 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-05-24 20:10:56,609 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-05-24 20:10:56,609 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-05-24 20:10:56,921 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-05-24 20:10:56,921 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2012-05-24 20:10:57,187 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-05-24 20:10:57,187 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-05-24 20:10:57,640 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-05-24 20:10:57,640 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 21
2012-05-24 20:10:57,875 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-05-24 20:10:58,015 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-05-24 20:10:58,375 INFO [WebServer] Socket buffer set to 65535 bytes
2012-05-24 20:10:58,375 INFO [Device] Created UPnP Device with UUID: c41c5514-0d79-3774-967b-023b9e31d01f, bound address: 192.168.0.2
2012-05-24 20:10:58,421 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-05-24 20:10:58,437 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-05-24 20:10:58,437 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2012-05-24 20:10:58,578 INFO [PluginCompilerThread] Started looking for plugins
2012-05-24 20:10:58,812 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-24 20:10:58,812 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\WINDOWS\TEMP\Serviio
2012-05-24 20:10:58,859 INFO [WebServer] WebServer starting on port 8895
2012-05-24 20:10:58,875 DEBUG [DiscoveryManager] UPNP device c41c5514-0d79-3774-967b-023b9e31d01f (192.168.0.2) is available
2012-05-24 20:10:58,875 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-24 20:10:58,875 INFO [EventDispatcher] Starting EventDispatcher
2012-05-24 20:10:58,875 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-24 20:10:58,890 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.0.2, timeout = 0
2012-05-24 20:10:58,890 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-24 20:10:58,890 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-24 20:10:58,921 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.0.2, timeout = 0
2012-05-24 20:10:58,937 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.0.2, timeout = 0
2012-05-24 20:10:58,953 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-05-24 20:10:58,953 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-05-24 20:10:58,968 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.2:2963
2012-05-24 20:10:58,984 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.2:2963
2012-05-24 20:11:00,765 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-05-24 20:11:04,968 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-05-24 20:11:05,000 DEBUG [ServiioConsole] Retrieving preferred console language
2012-05-24 20:11:05,125 DEBUG [ServiioConsole] Setting console locale to be: en
2012-05-24 20:11:05,125 INFO [Messages] Loaded console message bundle for locale: en
2012-05-24 20:11:05,187 INFO [UpdateChecker] Checking if a new version is available
2012-05-24 20:11:05,390 DEBUG [ServiioFrameView] Initializing main frame
2012-05-24 20:11:05,406 DEBUG [ServiioFrameView] System tray is supported
2012-05-24 20:11:05,734 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-05-24 20:11:05,796 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-05-24 20:11:05,906 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-05-24 20:11:06,296 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-05-24 20:11:06,359 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2012-05-24 20:11:06,734 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-05-24 20:11:06,734 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2012-05-24 20:11:06,765 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-05-24 20:11:06,781 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:06,781 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,796 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,796 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,812 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,812 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:06,828 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,828 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,843 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,843 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,859 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:06,859 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2012-05-24 20:11:06,875 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:06,875 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,890 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,890 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:06,906 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,921 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,937 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:06,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:06,968 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-05-24 20:11:06,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2012-05-24 20:11:06,984 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-05-24 20:11:07,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-05-24 20:11:07,000 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-05-24 20:11:07,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,015 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-05-24 20:11:07,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,046 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-05-24 20:11:07,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,078 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-05-24 20:11:07,078 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,109 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2012-05-24 20:11:07,125 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,125 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,140 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,156 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,156 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,171 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,187 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,187 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-05-24 20:11:07,203 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-05-24 20:11:07,203 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-05-24 20:11:07,218 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,234 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-05-24 20:11:07,234 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,250 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,250 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,265 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,281 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,296 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,296 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2012-05-24 20:11:07,312 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2012-05-24 20:11:07,328 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2012-05-24 20:11:07,328 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,343 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2012-05-24 20:11:07,359 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2012-05-24 20:11:07,359 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2012-05-24 20:11:07,375 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,390 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,390 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,421 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,437 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,437 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,578 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,593 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,593 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,609 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,609 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,625 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-05-24 20:11:07,640 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,656 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,656 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-05-24 20:11:07,671 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-05-24 20:11:07,687 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-05-24 20:11:07,687 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-05-24 20:11:08,203 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-05-24 20:11:08,203 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-05-24 20:11:08,234 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2012-05-24 20:11:10,781 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.0.2, timeout = 0
2012-05-24 20:11:10,781 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-05-24 20:11:12,593 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-05-24 20:11:22,609 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.0.2, timeout = 0
2012-05-24 20:11:22,609 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-05-24 20:11:23,187 DEBUG [ActionsServerResource] Action with name 'forceLibraryRefresh' was requested
2012-05-24 20:11:23,187 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-24 20:11:23,187 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-05-24 20:11:23,187 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-24 20:11:23,203 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\bitlorddown
2012-05-24 20:11:23,203 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\bitlorddown
2012-05-24 20:11:23,203 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 11)
2012-05-24 20:11:23,218 DEBUG [RepositoryDAOImpl] Marking Repository 11 as scanned with current timestamp
2012-05-24 20:11:23,375 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\video
2012-05-24 20:11:23,375 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 12)
2012-05-24 20:11:23,375 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 11)
2012-05-24 20:11:23,406 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video
2012-05-24 20:11:23,406 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\borgias
2012-05-24 20:11:23,421 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\endeavour
2012-05-24 20:11:23,421 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\films
2012-05-24 20:11:23,468 DEBUG [RepositoryDAOImpl] Marking Repository 11 as scanned with current timestamp
2012-05-24 20:11:23,468 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\gameoft
2012-05-24 20:11:23,468 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\hell_on_wheels
2012-05-24 20:11:23,468 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\lewis
2012-05-24 20:11:23,484 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\nursej
2012-05-24 20:11:23,484 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\silk
2012-05-24 20:11:23,484 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\smash
2012-05-24 20:11:23,484 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\video\spartacus
2012-05-24 20:11:23,484 DEBUG [RepositoryDAOImpl] Marking Repository 12 as scanned with current timestamp
2012-05-24 20:11:23,484 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 12)
2012-05-24 20:11:24,421 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:26
2012-05-24 20:11:24,968 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-05-24 20:11:24,968 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-05-24 20:11:24,968 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Post Thu May 24, 2012 10:53 pm
It looks like access rights to your folders. Make sure the user that runs the Serviio service (probably System) has read access to the folders. Alternatively run the service under a different user (eg yourself)
kdp99
Post Fri May 25, 2012 6:33 pm
Hi Zip,
Thanks for the on-going help.
Firstly I looked at taskmanager
Serviio consul is run by user keith (me, only user, admin).
Serviio service is run by system.
Wiselinkpro (the samsung DNLA, that finds the files OK), is also run by system.
I then looked at the properties of the shared folder.
Under general its marked as read only (but I changed that and no joy).
The folder is shared on the network, but network users are no allowed to change my files. Finally it says windows firewall will allow this folder to be shared with other computers on the network.
What to try next, fogive my ignorance but how in XP do I check if system has read access to the files ?
Many thanks again.
Post Fri May 25, 2012 11:40 pm
did you select file types to search for in the folders? post screenshot of the console's library tab
kdp99
Post Sat May 26, 2012 6:20 am
This is very odd, you were right zip I had forgoten to tick the video box, BUT As soon as I do I am back to the original problem of missing most of the files.
I have a folder D:\video with 10 or so folders in it each of which has video files in, as serviio finds just the first two, and no more, the samsung DNLA finds the lot.
I have now stopped serviio, deleted the shares, turned on the detailed log file, re-started serviio, added back in the shares and saved the log file. I have attached the log file and a word file of images form the folders and serviio.
Again Many thanks for the help.
Keith
kdp99serviio.log
detailed log
(85.81 KiB) Downloaded 806 times
kdp99serviio.doc
images from explorer etc
(458 KiB) Downloaded 753 times
kdp99
Post Sat May 26, 2012 7:34 am
I have found the cause of the problem, and a work around but its very odd.
I have removed the first two files form the first folder that is missed, and everything else returns to normal ! It was looking at the detailed log and noting which file it seemed to stop on that gave me the idea.
The offending files are just MKVs that play OK on the pc, and on the Samsung from either a memory stick or the Samsung DNLA.
I've attached medainfo data on the two files.
I'd love to know why these files cause serviio so much grief.
Thanks again zip for the help.
kp1.txt
(3.07 KiB) Downloaded 758 times
kp2.txt
(2.4 KiB) Downloaded 896 times
Post Sat May 26, 2012 11:01 am
can you post ffmpeg -i for the files?
And can you try this (it will probably hang and that would be the cause):
ffmpeg.exe -i D:\video\films\HAYWIRE (2011) 1080p .mkv -vframes 1 -vcodec copy -f h264 -vbsf h264_mp4toannexb -an d:\video\films\test.jpg
kdp99
Post Sat May 26, 2012 7:04 pm
I had to rename the file to get it into a command line (crap.mkv), it did not hang but did not give a useful jpeg, but gave a load off stuff, below.
Anything else I can do to help ?
C:\MediaI>ffmpeg.exe -i D:\video\zzz\crap.mkv -vframes 1 -vcodec copy -f h264 -v
bsf h264_mp4toannexb -an d:\video\zzz\test.jpg
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 015ed2e0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (959/20
) -> 23.98 (959/40)
Input #0, matroska,webm, from 'D:\video\zzz\crap.mkv':
title : HAYWIRE (2011) 1080p BRRip [MKV 6ch DTS][RoB]PR3DATOR RG
Duration: 01:32:52.33, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0: Video: h264, yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 2
3.98 tbr, 1k tbn, 47.95 tbc
Stream #0.1: Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
Output #0, h264, to 'd:\video\zzz\test.jpg':
encoder : Lavf52.92.0
Stream #0.0: Video: [0][0][0][0] / 0x0000, yuv420p, 1920x1080 [PAR 1:1 DAR 1
6:9], q=2-31, 90k tbn, 23.98 tbc
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
frame= 1 fps= 0 q=-1.0 Lsize= 1kB time=0.04 bitrate= 119.5kbits/s
video:1kB audio:0kB global headers:0kB muxing overhead 6.313993%
C:\MediaI>
tuxnician
Post Mon Jun 18, 2012 2:53 pm
I was running .62 for a few days on both my Mac and Linux boxes. They both worked fine and all my video files were showing up and I could watch them properly. After a few days the files were missing from the list on my dlna clients. I restarted both Mac and Linux but the files still would not show up.
I downgraded to .61 and it's been working fine ever since.
pcnet
Post Sun Jul 08, 2012 6:17 pm
I too was running the 0.62 build when I started seeing the same behavior. Files and entire folders that I could see via a console on my PC were not being presented to the various media devices on my network (2 Sony SMP-N100, 1 Sony SMP-N200, and my ASUS TF101 running various UPnP clients).
These files and folders were new to the library - either new episodes that had been grabbed via SickBeard or new shows I added for SickBeard to start grabbing. Anything that had already been presented was still working as usual.
All the files and folders that were not being presented were playable via the PC as well as the various media devices using a thumb-drive.
I tried various things; stopping/starting the service, file/folder ownership/permissions, even dumping the cache and db and allowing it to start fresh.
It wasn't until I found this post and rolled back to 0.61 that things started working as expected.
I've still got the 0.62 build in a directory, it's just a matter of re-symlinking to 'current' and starting up the service - is there anything you need me to grab that might be useful?
Best, :)
Users browsing this forum: No registered users and 61 guests
