Serviio as online resource
Strupniveral
Post Wed Jul 11, 2012 8:36 pm
Hi All,
I have to admit this query is pretty weird, so I'd perfectly understand if this is not doable in any way :D
I have two Serviio instances, running on two different machines (let's say A and B) in two different networks, each of those perfectly working in the respective network.
So, I created a VPN to connect A & B, so they can see each other.
Point is, the TV connected in the same network as A cannot discovery the Serviio instance running on B, so I'm wondering if I can configure Serviio's instance on A to access the one on B as an online resource.
Is this something doable? :D
Thanks in advance and Regards,
Luca
Post Wed Jul 11, 2012 9:06 pm
Re: Serviio as online resource
That's not doable ATM. Do your virtual networks have the same subnet?
Strupniveral
Post Wed Jul 11, 2012 9:31 pm
Ok, I see...
No, they are on a different subnet: 192.168.0.0/24 & 192.168.1.0/24. The only point of contact is the machine running one of the two instances (A in previous example), since it's on both of them due to the VPN.
I'm going to play with port forwarding or something like that then.
Thanks!
