Websource error
serivooftw
Post Wed Jul 11, 2012 11:30 pm
Websource error
I installed some plugins but i'm having problem with Channel4od.groovy plugin. This is the error i also attack the full log. It's mp4 file error? how can i fix it?
2012-07-11 18:26:29,128 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://ak.securestream.channel4.com:1935/4oD/?ovpfv=1.1&auth=da_dAbWdecpb6bTdUcpcHd4bAcPaMdsbycv-bp_F2w-eS-jyU-nbpWsWpWqVoenWqRqTlQsYsToUkepcreoSpTrcpUpfpXnTqUpak6rcrdoXkbpfsXn8o9s0pVp8ofnhq4&aifp=v002&slist=assets/CH4_08_02_16_48687005001004_001.mp4 playpath=mp4:assets/CH4_08_02_16_48687005001004_001.mp4?auth=da_dAbWdecpb6bTdUcpcHd4bAcPaMdsbycv-bp_F2w-eS-jyU-nbpWsWpWqVoenWqRqTlQsYsToUkepcreoSpTrcpUpfpXnTqUpak6rcrdoXkbpfsXn8o9s0pVp8ofnhq4&aifp=v002&slist=assets/CH4_08_02_16_48687005001004_001.mp4 swfurl=http://www.channel4.com/static/programmes/asset/flash/swf/4odplayer-11.27.3.swf swfVfy=1. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
   ... 2 more
serviio1.log
(63.02 KiB) Downloaded 557 times
Post Wed Jul 11, 2012 11:41 pm
Re: Websource error
You know you need to be in the UK to play those right?
serivooftw
Post Thu Jul 12, 2012 12:34 am
Re: Websource error
I can play them on the PC just fine including bbc iplayer
Post Thu Jul 12, 2012 1:11 am
Re: Websource error
Doesn't mean you are in the UK.
Post Thu Jul 12, 2012 8:53 am
Re: Websource error
Do the other plugins (eg BBC) work? It might be the plugin needs updating. Ask here: viewtopic.php?f=20&t=4624
Users browsing this forum: No registered users and 61 guests
