serviio ffmpeg not compatible with Mint 13 Cinnamon
jonn67
Post Fri Jul 13, 2012 5:52 pm
The Serviio build of ffmpeg for Mint 13 Cinnamon 32 or 64 bit is not compatible.
sudo apt-get remove ffmpeg x264 libx264-dev libvpx-dev librtmp0 librtmp-dev
removes:
apt-transport-https aptdaemon apturl brasero brasero-cdrkit evolution-data-server ffmpeg gecko-mediaplayer gir1.2-totem-1.0 gir1.2-totem-plparser-1.0
gnome-mplayer gstreamer0.10-plugins-bad jockey-common jockey-gtk kerneloops-daemon language-selector-gnome libbrasero-media3-1 libcmis-0.2-0 libcurl3
libcurl3-gnutls libcurl3-nss libfolks-eds25 libgdata13 libmyth-python liboauth0 libquvi7 libraptor2-0 librasqal3 librdf0 libreoffice-base
libreoffice-base-core libreoffice-calc libreoffice-common libreoffice-core libreoffice-draw libreoffice-emailmerge libreoffice-gnome libreoffice-gtk
libreoffice-help-en-gb libreoffice-help-en-us libreoffice-impress libreoffice-java-common libreoffice-math libreoffice-style-human
libreoffice-style-tango libreoffice-writer librtmp-dev librtmp0 libslv2-9 libtotem-plparser17 libtotem0 libvpx-dev libx264-dev mint-meta-cinnamon
mint-meta-cinnamon-dvd mint-meta-codecs mintinstall mintwelcome mythtv mythtv-frontend nautilus-share python-aptdaemon python-aptdaemon.gtk3widgets
python-aptdaemon.pkcompat python-cupshelpers python-pycurl python-software-properties python-uno python-urlgrabber rtmpdump sessioninstaller
software-properties-gtk system-config-printer-common system-config-printer-gnome system-config-printer-udev totem totem-mozilla totem-plugins
totem-plugins-extra transmission-gtk whoopsie x264
On starting Serviio console the computer completely locks up causing hard reboot with the standard Mint 13 repos of above software.
To have to remove all the above software just to enable Serviio to work is ridiculous!
Anybody got any answers ?
Post Fri Jul 13, 2012 6:10 pm
Re: serviio ffmpeg not compatible with Mint 13 Cinnamon
First build and install over the current if you want to test it, but all that means is that that software is only needed by ffmpeg/the libs so if you don't use any of that software then you might as well remove it. If you are really unsure, keep a copy so that you can apt-get install xxxxx it later
Users browsing this forum: No registered users and 60 guests
