How can I...
retry32
Post Fri Jul 27, 2012 8:43 am
How can I...
Save the library of the online/offline folders?
If I reinstall serviio they are dead and gone.
Post Fri Jul 27, 2012 12:56 pm
Re: How can I...
you can either just reinstall by running the installer again (windows) or overriding the files (other OSes). Or install from scratch - you'd have to keep a copy of the library folder, which might break your new installation though. Currently there is no easy way to export online sources, but there is an open ticket.
retry32
Post Fri Jul 27, 2012 3:39 pm
Re: How can I...
This is the part where the jew pops out of the can!
The lib folder is protected by trusted installers
Users browsing this forum: Google [Bot] and 75 guests
