How do I add a profile?
mrkino
Post Fri Aug 24, 2012 9:05 pm
I have spent the last hour searching for a guide on how to actually add a profile to the serviio. I was only able to locate the following and its extremely confusing. http://www.serviio.org/index.php?option=com_content&view=article&id=16, I also found my device, Sony SMP-N200, and located it in the wiki, http://wiki.serviio.org/doku.php?id=devices_format_support.
I opened the profiles.xml in notepad++, and that is where i stopped. The guide seems to tell you to replace your info in place of the italics, but the device format support on the wiki, only gives a huge list, and each line on that list stats with: "http-get:*" I am at a loss on what to do. thank you.
Post Fri Aug 24, 2012 10:13 pm
Re: How do I add a profile?
Probably above your pay grade until you have way more experience with it. Also read http://www.serviio.org/index.php?option ... icle&id=24 and then look at profiles.xml and examine some of the transcoding rules for various devices, which is all you really need to use.
Then just use profile 10 which already exists for SMP's.
Users browsing this forum: No registered users and 74 guests
