YouTube CacheKey
Post Thu Aug 23, 2012 4:47 am
YouTube CacheKey
Youtube videos result in the creation of a cachekey for every played video.
YouTube however has established format codes that define the attributes of each variation of a file that apply to all Youtube Videos. It seems to me therefore that the cachekey for a youtube video can simply be its format code and in that way the cache will only need to hold the dozen or so format code cache keys rather than one cachekey for every played youtube video.
Does this make sense and will it work?
Post Mon Aug 27, 2012 10:25 pm
Re: YouTube CacheKey
that would work for codec combination, but probably not for resolution, bitrate, fps, etc. Those might be needed for transcoding detection etc.
Post Mon Aug 27, 2012 10:31 pm
What do you actually cache. I don't see it documented. The format codes cover resolution as well, but I don't see fps or source bitrate used in your ffmpeg commands.
Post Mon Aug 27, 2012 11:07 pm
basically a lot from ffmpeg -i. I think the formats cover max resolution, not the actual resolution, right?
Post Mon Aug 27, 2012 11:28 pm
Good point, but again I don't see you providing ffmpeg with any of that detail in your generated commands. FFmpeg seems to "discover " what it needs.
Post Tue Aug 28, 2012 10:57 pm
some of them are used for transcode matchers, eg maxHeight, profile, level, etc.
