Serviio Plugins
irhut
Post Mon Sep 03, 2012 8:04 pm
Serviio Plugins
I have installed Serviio on my Synology Diskstaion as shown at http://pcloadletter.co.uk/2012/01/25/se ... o-package/
I have previously managed to use online plugins without any problems such as being able to view previous Coronation Street episodes. I uninstalled Serviio and have not used it for a while. I now want to use it again almost exclusively for online content, however I can no longer get them to work.
I have added the plugins from - viewtopic.php?f=20&t=3820 and placed them in the /volume1/@appstore/Serviio/plugins folder. I have added the coronation street online source using the search facility in in the Serviio app. However nothing shows up in the online folder on my TV or phone anymore.
I have also tried some iplayer feeds and although the folders show such as the BBC HD folder there is no content within these folders. This is frustrating simply because I managed to get it to work so well before.
Clearing the Serviio log and then refreshing the Coronation Street feed I get the following in the log:
2012-09-03 20:46:53,515 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.itv.com/itvplayer/video/?Fil ... tionStreet. Message: No plugin for web resource http://www.itv.com/itvplayer/video/?Fil ... tionStreet has been found.
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:179)
Any help would be much appreciated.
Ian
Post Tue Sep 04, 2012 2:02 pm
Re: Serviio Plugins
Pretty clear. The plugin is not installed. The debug log just after a Serviio boot will list the plugins it has found.
irhut
Post Tue Sep 04, 2012 5:15 pm
Re: Serviio Plugins
The ITV Groovy is in the plugins folder as mentioned so I am unsure what else to do. I will reboot and see what log says.
irhut
Post Tue Sep 04, 2012 5:38 pm
Re: Serviio Plugins
Hello again. Here is debug log after boot. Sorry I have posted the whole thing as I am unsure where to look. Many thanks for any help you can give - Ian
2012-09-04 18:33:54,970 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2012-09-04 18:33:55,260 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-09-04 18:33:55,309 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:33:55,420 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-09-04 18:33:55,517 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-09-04 18:33:55,569 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2012-09-04 18:33:55,660 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-09-04 18:33:55,737 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2012-09-04 18:33:55,829 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-09-04 18:33:55,909 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-09-04 18:33:55,989 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:33:56,048 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:33:56,220 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2012-09-04 18:33:56,272 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2012-09-04 18:33:56,484 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=S, recursive=false, cacheRegion=local_default
2012-09-04 18:33:56,520 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-09-04 18:33:56,669 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-09-04 18:33:56,833 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:33:57,251 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-09-04 18:33:57,279 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2012-09-04 18:33:58,506 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:33:58,598 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2012-09-04 18:33:58,895 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-09-04 18:33:59,461 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-09-04 18:34:00,626 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:00,769 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2012-09-04 18:34:01,128 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2012-09-04 18:34:01,616 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-09-04 18:34:02,163 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:02,318 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagePlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2012-09-04 18:34:02,477 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForPlaylistCommand, containerClass=null, itemClass=PHOTO, idPrefix=S, recursive=false, cacheRegion=local_default
2012-09-04 18:34:02,858 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-09-04 18:34:03,018 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-09-04 18:34:03,267 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2012-09-04 18:34:03,390 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2012-09-04 18:34:03,579 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-09-04 18:34:03,666 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:03,840 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-09-04 18:34:04,028 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-09-04 18:34:04,276 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2012-09-04 18:34:04,317 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:04,725 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-09-04 18:34:04,786 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-04 18:34:05,235 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-09-04 18:34:05,363 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:05,612 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-04 18:34:05,764 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for OnlineRepository (id = 2)
2012-09-04 18:34:05,770 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2012-09-04 18:34:05,886 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2012-09-04 18:34:06,226 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2012-09-04 18:34:07,347 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:08,351 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2012-09-04 18:34:09,843 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2012-09-04 18:34:10,850 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-04 18:34:10,850 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-04 18:34:10,876 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-09-04 18:34:11,034 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2012-09-04 18:34:11,058 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-09-04 18:34:11,107 DEBUG [OnlineLibraryManager] Resource http://www.itv.com/itvplayer/video/?Filter=CoronationStreet not in cache yet, loading it
2012-09-04 18:34:11,108 DEBUG [WebResourceParser] Parsing web resource 'http://www.itv.com/itvplayer/video/?Filter=CoronationStreet'
2012-09-04 18:34:11,110 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Cannot parse resource from http://www.itv.com/itvplayer/video/?Filter=CoronationStreet. Message: No plugin for web resource http://www.itv.com/itvplayer/video/?Filter=CoronationStreet has been found.
2012-09-04 18:34:11,280 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:11,400 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-09-04 18:34:11,697 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:12,709 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2012-09-04 18:34:12,793 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-09-04 18:34:13,129 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:13,217 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-09-04 18:34:13,309 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-09-04 18:34:13,507 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-09-04 18:34:13,614 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:14,211 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-09-04 18:34:14,344 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-09-04 18:34:14,491 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2012-09-04 18:34:14,594 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-09-04 18:34:15,042 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:15,430 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2012-09-04 18:34:15,706 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2012-09-04 18:34:15,895 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2012-09-04 18:34:16,405 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_PL, titleKey=playlists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2012-09-04 18:34:16,676 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoPlaylistsCommand, containerClass=PLAYLIST_CONTAINER, itemClass=null, idPrefix=PL, recursive=false, cacheRegion=local_default
2012-09-04 18:34:16,877 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForPlaylistCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=S, recursive=false, cacheRegion=local_default
2012-09-04 18:34:17,093 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2012-09-04 18:34:17,264 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineContentCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=no_cache
2012-09-04 18:34:18,085 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2012-09-04 18:34:18,324 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-04 18:34:18,416 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-09-04 18:34:18,455 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-04 18:34:18,462 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for OnlineRepository (id = 2)
2012-09-04 18:34:18,975 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-09-04 18:34:19,098 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2012-09-04 18:34:47,076 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.0.9, timeout = 0
2012-09-04 18:34:47,116 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2012-09-04 18:34:49,038 DEBUG [WebServer] Incoming connection from /192.168.0.9:36361
2012-09-04 18:34:49,097 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:42
2012-09-04 18:34:49,040 DEBUG [WebServer] Incoming connection from /192.168.0.9:36362
2012-09-04 18:34:49,279 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:49,281 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:49,350 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 17:34:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 18:34:49,351 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:49,356 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 17:34:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 18:34:49,357 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 17:34:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 18:34:49,579 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:49,584 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 17:34:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 18:34:49,587 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:49,593 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:50,864 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 18:34:50,870 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 18:34:51,149 DEBUG [WebServer] Incoming connection from /192.168.0.9:36363
2012-09-04 18:34:51,154 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:51,161 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 17:34:51 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 18:34:51,162 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:51,166 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 17:34:51 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 18:34:51,179 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 18:34:51,509 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
Post Tue Sep 04, 2012 6:31 pm
Re: Serviio Plugins
This isn't the whole thing, its missing the startup part which shows which profiles and plugins are loaded. Please stop the service, delete all the log files, then start the service and re-post.
irhut
Post Tue Sep 04, 2012 7:17 pm
Re: Serviio Plugins
OK I tried again - Once again any help you give is much appreciated.
2012-09-04 20:07:27,216 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-09-04 20:07:27,330 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-04 20:07:27,331 INFO [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-09-04 20:07:27,332 INFO [MediaServer] Petr Nejedly 2009-2012
2012-09-04 20:07:27,332 INFO [MediaServer] http://www.serviio.org
2012-09-04 20:07:27,333 INFO [MediaServer]
2012-09-04 20:07:27,333 INFO [MediaServer] Java 1.6.0_34-Sun Microsystems Inc.
2012-09-04 20:07:27,334 INFO [MediaServer] OS Linux arm 2.6.32.12
2012-09-04 20:07:27,334 INFO [MediaServer] File encoding: UTF-8
2012-09-04 20:07:27,357 INFO [MediaServer] Headless mode enabled: true
2012-09-04 20:07:27,358 INFO [MediaServer] User home dir: /var/services/homes/serviio
2012-09-04 20:07:27,358 INFO [MediaServer] Temp dir: /tmp
2012-09-04 20:07:27,359 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-04 20:07:28,639 INFO [WebServer] Socket buffer set to 65535 bytes
2012-09-04 20:07:28,653 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-09-04 20:07:28,998 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-09-04 20:07:29,002 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-09-04 20:07:29,219 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-09-04 20:07:29,486 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-09-04 20:07:43,159 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-09-04 20:07:43,172 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-09-04 20:07:43,177 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-09-04 20:07:43,192 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-09-04 20:07:43,200 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-09-04 20:07:43,205 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-09-04 20:07:43,210 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-09-04 20:07:43,216 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-09-04 20:07:43,221 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-09-04 20:07:43,226 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-09-04 20:07:43,234 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-09-04 20:07:43,239 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2012-09-04 20:07:43,406 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-09-04 20:07:44,432 WARN [prefs] java.io.IOException: Permission denied
2012-09-04 20:07:47,779 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-04 20:07:47,780 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2012-09-04 20:07:47,780 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-04 20:07:51,385 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-09-04 20:07:51,899 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-09-04 20:08:01,637 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-09-04 20:08:01,660 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-09-04 20:08:07,936 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-09-04 20:08:07,949 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-09-04 20:08:12,030 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-09-04 20:08:12,076 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-09-04 20:08:17,119 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-09-04 20:08:17,134 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-09-04 20:08:20,810 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-09-04 20:08:20,828 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-09-04 20:08:24,592 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-09-04 20:08:24,607 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-09-04 20:08:37,851 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-09-04 20:08:37,885 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-09-04 20:08:38,351 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-09-04 20:08:38,369 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2012-09-04 20:08:51,341 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-09-04 20:08:51,361 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-09-04 20:09:07,345 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-09-04 20:09:07,397 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-09-04 20:09:14,610 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-09-04 20:09:14,635 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-09-04 20:09:19,906 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-09-04 20:09:20,131 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-09-04 20:09:21,658 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-09-04 20:09:21,745 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-09-04 20:09:25,540 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-09-04 20:09:25,572 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-09-04 20:09:26,563 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-09-04 20:09:26,599 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-09-04 20:09:32,067 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-09-04 20:09:32,119 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2012-09-04 20:09:32,936 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-09-04 20:09:32,964 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2012-09-04 20:09:42,493 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-09-04 20:09:42,728 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-09-04 20:09:50,423 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-09-04 20:09:50,452 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2012-09-04 20:09:53,184 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-09-04 20:09:53,220 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2012-09-04 20:09:54,326 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-09-04 20:09:54,355 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2012-09-04 20:10:06,721 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2012-09-04 20:10:06,780 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2012-09-04 20:10:09,545 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2012-09-04 20:10:09,575 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2012-09-04 20:10:10,974 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-09-04 20:10:11,006 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2012-09-04 20:10:13,375 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2012-09-04 20:10:13,406 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2012-09-04 20:10:16,570 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2012-09-04 20:10:16,638 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 23
2012-09-04 20:10:22,066 INFO [ProfilesDefinitionParser] Added profile 'LG TV 2011' (id=23)
2012-09-04 20:10:22,452 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-09-04 20:10:22,483 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2012-09-04 20:10:26,635 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-09-04 20:10:26,646 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2012-09-04 20:10:29,722 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-09-04 20:10:31,986 INFO [Device] Created UPnP Device with UUID: 8eda6066-4ca3-3622-adc9-b1740bc8c845, bound address: 192.168.0.9
2012-09-04 20:10:32,404 INFO [PluginCompilerThread] Looking for plugins at /volume1/public/serviio/plugins
2012-09-04 20:10:32,417 INFO [UpdateChecker] Checking if a new version is available
2012-09-04 20:10:32,427 WARN [PluginCompilerThread] Plugins folder '/volume1/public/serviio/plugins' does not exist. No plugins will be compiled.
2012-09-04 20:10:32,506 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path /volume1/@appstore/Serviio/bin/ffmpeg
2012-09-04 20:10:32,547 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg
2012-09-04 20:10:33,710 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-09-04 20:10:34,142 INFO [WebServer] WebServer starting on port 8895
2012-09-04 20:10:34,187 DEBUG [DiscoveryManager] UPNP device 8eda6066-4ca3-3622-adc9-b1740bc8c845 (192.168.0.9) is available
2012-09-04 20:10:34,191 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-09-04 20:10:34,192 INFO [EventDispatcher] Starting EventDispatcher
2012-09-04 20:10:34,193 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-09-04 20:10:34,256 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.9, timeout = 0
2012-09-04 20:10:34,259 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.0.9, timeout = 0
2012-09-04 20:10:34,276 INFO [RendererSearchSender] Searching for Renderer devices
2012-09-04 20:10:34,281 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-09-04 20:10:34,334 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.0.9, timeout = 0
2012-09-04 20:10:34,470 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-09-04 20:10:34,483 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2012-09-04 20:10:34,578 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.9:46303
2012-09-04 20:10:34,579 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:34,991 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.9:46303
2012-09-04 20:10:35,018 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:35,028 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.9:46303
2012-09-04 20:10:35,029 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:35,560 DEBUG [RendererSearchSender] Received search response: location: http://192.168.0.14:37904/MediaRenderer1.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2012-09-04 20:10:35,583 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 1b5dc0be-1dd2-11b2-9d7b-fe3c98e86df3 from address /192.168.0.14:1900
2012-09-04 20:10:35,658 DEBUG [WebServer] Incoming connection from /192.168.0.14:41198
2012-09-04 20:10:35,712 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.14
2012-09-04 20:10:35,884 DEBUG [WebServer] Incoming connection from /192.168.0.9:43563
2012-09-04 20:10:35,895 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:35,996 DEBUG [WebServer] Incoming connection from /192.168.0.9:43564
2012-09-04 20:10:36,014 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:36,230 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.14 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:09:52 GMT,USER-AGENT: Linux/2.6.28.9 UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LGE_DLNA_SDK/1.5.0,friendlyName.dlna.org: LG DLNA DMC v0.1])
2012-09-04 20:10:36,231 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.14
2012-09-04 20:10:36,233 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:35 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:10:36,259 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:09:52 GMT,USER-AGENT: Linux/2.6.28.9 UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LGE_DLNA_SDK/1.5.0,friendlyName.dlna.org: LG DLNA DMC v0.1]
2012-09-04 20:10:36,293 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:35 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:10:36,319 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.14
2012-09-04 20:10:36,322 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:36,370 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:35 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:10:36,415 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:36,422 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:36,427 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:35 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:10:36,444 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:36,455 DEBUG [RendererManager] Adding renderer Renderer [uuid=1b5dc0be-1dd2-11b2-9d7b-fe3c98e86df3, ipAddress=192.168.0.14, name=MediaRenderer, profileId=23, manuallyAdded=true, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2012-09-04 20:10:36,503 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-09-04 20:10:36,514 DEBUG [RendererSearchSender] Received search response: location: http://192.168.0.14:37904/MediaRenderer1.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2012-09-04 20:10:36,516 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 1b5dc0be-1dd2-11b2-9d7b-fe3c98e86df3 from address /192.168.0.14:1900
2012-09-04 20:10:36,553 DEBUG [RendererSearchSender] Received search response: location: http://192.168.0.14:37904/MediaRenderer1.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2012-09-04 20:10:36,555 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 1b5dc0be-1dd2-11b2-9d7b-fe3c98e86df3 from address /192.168.0.14:1900
2012-09-04 20:10:38,179 DEBUG [WebServer] Incoming connection from /192.168.0.13:52143
2012-09-04 20:10:38,183 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2012-09-04 20:10:38,205 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.13 (headers = [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.0.9:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50])
2012-09-04 20:10:38,206 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2012-09-04 20:10:38,211 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.0.9:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50]
2012-09-04 20:10:38,222 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2012-09-04 20:10:40,719 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:10:40,723 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:10:40,722 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'LG TV 2011'
2012-09-04 20:10:40,721 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-09-04 20:10:40,721 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:10:40,847 DEBUG [WebServer] Incoming connection from /192.168.0.13:52144
2012-09-04 20:10:41,003 DEBUG [WebServer] Incoming connection from /192.168.0.14:41199
2012-09-04 20:10:41,006 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.14
2012-09-04 20:10:41,128 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2012-09-04 20:10:41,153 DEBUG [WebServer] Incoming connection from /192.168.0.9:43565
2012-09-04 20:10:41,159 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:41,217 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:41 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:10:41,218 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:41,229 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.13
2012-09-04 20:10:41,320 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-09-04 20:10:41,333 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:41 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:10:41,337 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:41,469 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:10:41,938 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-09-04 20:10:42,552 DEBUG [WebServer] Incoming connection from /192.168.0.14:41200
2012-09-04 20:10:42,778 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.14
2012-09-04 20:10:42,979 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2012-09-04 20:10:43,395 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-09-04 20:10:46,629 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.0.9, timeout = 0
2012-09-04 20:10:46,648 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2012-09-04 20:10:48,118 DEBUG [WebServer] Incoming connection from /192.168.0.9:43567
2012-09-04 20:10:48,124 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,234 DEBUG [WebServer] Incoming connection from /192.168.0.9:43568
2012-09-04 20:10:48,236 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,417 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:47 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:10:48,418 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,440 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:10:48,459 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:47 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:10:48,473 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,523 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,530 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:10:48,563 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,675 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:10:48,680 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:10:48,762 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-09-04 20:10:48,830 DEBUG [WebServer] Incoming connection from /192.168.0.9:43569
2012-09-04 20:10:48,846 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,864 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:10:48,865 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,870 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:10:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:10:48,943 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:10:48,976 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:10:49,504 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2012-09-04 20:10:52,944 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-04 20:10:58,563 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-09-04 20:10:58,798 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.0.9, timeout = 0
2012-09-04 20:10:58,986 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2012-09-04 20:10:59,543 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-04 20:11:00,137 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for OnlineRepository (id = 2)
2012-09-04 20:11:00,799 DEBUG [WebServer] Incoming connection from /192.168.0.9:43570
2012-09-04 20:11:00,802 DEBUG [WebServer] Incoming connection from /192.168.0.9:43571
2012-09-04 20:11:00,804 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:00,815 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:11:00 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:11:00,816 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:00,826 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:11:00 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:11:00,829 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:00,842 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:00,935 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:11:00 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:11:00,936 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:00,942 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:11:00 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:11:00,945 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:00,962 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:44
2012-09-04 20:11:01,087 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:11:01,125 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:11:01,154 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-09-04 20:11:01,154 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-04 20:11:01,155 DEBUG [WebServer] Incoming connection from /192.168.0.9:43572
2012-09-04 20:11:01,157 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:01,175 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:11:01 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 20:11:01,176 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:01,154 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-04 20:11:01,190 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 19:11:01 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 20:11:01,193 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 20:11:01,203 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 20:11:01,449 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-09-04 20:11:01,450 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-09-04 20:11:01,483 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-09-04 20:11:01,483 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-09-04 20:11:01,552 INFO [PlaylistMaintainerThread] Started looking playlist changes
2012-09-04 20:11:01,698 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-09-04 20:11:01,833 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-09-04 20:11:02,571 DEBUG [OnlineLibraryManager] Resource http://www.itv.com/itvplayer/video/?Fil ... tionStreet not in cache yet, loading it
2012-09-04 20:11:02,572 DEBUG [WebResourceParser] Parsing web resource 'http://www.itv.com/itvplayer/video/?Filter=CoronationStreet'
2012-09-04 20:11:03,374 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2012-09-04 20:11:06,331 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2012-09-04 20:11:06,659 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-09-04 20:11:06,878 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-09-04 20:11:06,884 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-09-04 20:11:06,890 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for OnlineRepository (id = 2)
2012-09-04 20:11:07,481 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-09-04 20:11:07,518 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2012-09-04 20:11:07,832 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
Post Tue Sep 04, 2012 7:45 pm
Re: Serviio Plugins
Here is the information from the log
Serviio is looking in "/volume1/public/serviio/plugins". You are putting the plugins in "/volume1/@appstore/Serviio/plugins". Try creating the "/volume1/public/serviio/plugins" folder and put the plugin in the there.
Post Tue Sep 04, 2012 7:49 pm
Re: Serviio Plugins
It's looking in /volume1/public/serviio/plugins so copy them there.
Edit: just read the guide you used and it does say to copy plugins there, rather than the appstore folder that you were using.
irhut
Post Tue Sep 04, 2012 8:05 pm
Re: Serviio Plugins
I hang my head in shame. I completly missed that part of the guide. Many thanks to you both for your help.
Ian
Post Tue Sep 04, 2012 8:12 pm
Re: Serviio Plugins
I imagine it made setting up permissions easier and makes it easier to drop plugins in remotely without ssh inorder to move them to a presumably restricted area that isn't accessible via smb.
irhut
Post Tue Sep 04, 2012 8:20 pm
Re: Serviio Plugins
I think you are spot on. Interestingly the install guide I used says that that folder is created automatically during the install which did not happen for me. Currently things are still not working but I will give things time to update etc.
irhut
Post Tue Sep 04, 2012 9:02 pm
Re: Serviio Plugins
Things still not working. It looks as though it is finding plugins now. This is the log when I refresh the online feeds.
2012-09-04 21:56:36,256 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'Mon 13th August 7:30pm'
2012-09-04 21:56:36,279 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:56:36,595 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -i rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:56:37,675 DEBUG [PluginCompilerThread] Starting plugin NHLGameCenterPlugin.groovy compilation
2012-09-04 21:56:38,241 DEBUG [WebServer] Incoming connection from /192.168.0.9:36751
2012-09-04 21:56:38,319 DEBUG [WebServer] Incoming connection from /192.168.0.9:36752
2012-09-04 21:56:38,388 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:56:38,399 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:56:38,667 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-09-04 21:56:38,789 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:48
2012-09-04 21:56:38,965 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:56:38 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:56:38,966 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:21,361 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:56:38 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:57:21,362 DEBUG [FeedUpdaterThread] Cannot get information about the URL, it might have expired already. Trying again.
2012-09-04 21:57:21,470 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:56:38 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:57:21,832 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:21,831 DEBUG [FeedItemUrlExtractor] ITVPlayer (UK only): Starting extraction of url for item: Mon 13th August 7:30pm
2012-09-04 21:57:21,829 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:22,719 DEBUG [WebServer] Incoming connection from /192.168.0.9:36755
2012-09-04 21:57:22,754 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:22,719 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:56:38 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:57:22,761 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:22,764 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:57:08 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:57:22,764 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:23,384 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:57:08 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:57:23,422 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:23,611 DEBUG [WebServer] I/O error: Connection reset
2012-09-04 21:57:25,354 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:57:25,362 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:57:25,562 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:57:25,976 DEBUG [WebServer] I/O error: Broken pipe
2012-09-04 21:57:25,981 DEBUG [WebServer] I/O error: Broken pipe
2012-09-04 21:57:27,404 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.0.9, timeout = 0
2012-09-04 21:57:27,830 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2012-09-04 21:57:29,640 DEBUG [WebServer] Incoming connection from /192.168.0.9:36757
2012-09-04 21:57:29,642 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:29,665 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:57:29 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:57:29,691 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:29,709 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:57:29 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:57:29,713 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:29,725 DEBUG [WebServer] Incoming connection from /192.168.0.9:36758
2012-09-04 21:57:29,727 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:29,743 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:57:29 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:57:29,744 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:29,752 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:57:29 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:57:29,768 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:29,812 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:57:30,082 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:57:30,146 DEBUG [WebServer] Incoming connection from /192.168.0.9:36759
2012-09-04 21:57:30,165 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:30,175 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:52
2012-09-04 21:57:30,348 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:57:29 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:57:30,399 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:30,483 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:57:29 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:57:30,491 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:57:30,643 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:57:33,329 WARN [PluginCompilerThread] Plugin NHLGameCenterPlugin.groovy failed to compile: startup failed:
/volume1/public/serviio/plugins/NHLGameCenterPlugin.groovy: 9: unable to resolve class groovyx.net.http.ContentType
@ line 9, column 1.
import static groovyx.net.http.ContentType.*
@ line 9, column 1.
/volume1/public/serviio/plugins/NHLGameCenterPlugin.groovy: 52: unable to resolve class HTTPBuilder
@ line 52, column 16.
def tvHttp = new HTTPBuilder(tvAuthUrl);
/volume1/public/serviio/plugins/NHLGameCenterPlugin.groovy: 104: unable to resolve class HTTPBuilder
@ line 104, column 16.
def tvHttp = new HTTPBuilder(tvReqUrl);
/volume1/public/serviio/plugins/NHLGameCenterPlugin.groovy: 137: unable to resolve class HTTPBuilder
@ line 137, column 22.
def tvGameHttp = new HTTPBuilder('http://gamecenter.nhl.com');
/volume1/public/serviio/plugins/NHLGameCenterPlugin.groovy: 213: unable to resolve class HTTPBuilder
@ line 213, column 16.
6 errors
2012-09-04 21:57:34,963 DEBUG [FeedItemUrlExtractor] ITVPlayer (UK only): Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEcBcKaFcSc.cpccbMbVcsbMaNcocBdAczaTdhbRbqaPabcabscaacaSc6bPaBaDdb-bqrMSs-eS-bzs1DCrlxtBr&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true, thumbnailUrl=http://www.itv.com/img/144x81/Coronation-Street-130812-1-906a00e0-9b1f-4385-8745-7c07ae8ae8c3.jpg, expiresOn=Wed Sep 12 23:59:00 IST 2012, expiresImmediately=true, cacheKey=ITV_PLAYER_323141_MEDIUM, live=false, ]
2012-09-04 21:57:34,964 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:57:35,053 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -i rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:57:45,496 DEBUG [PluginCompilerThread] Starting plugin NHLGameCenterPlugin.groovy compilation
2012-09-04 21:57:45,523 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEcBcKaFcSc.cpccbMbVcsbMaNcocBdAczaTdhbRbqaPabcabscaacaSc6bPaBaDdb-bqrMSs-eS-bzs1DCrlxtBr&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true'
2012-09-04 21:57:45,608 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:57:45,652 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -i rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true -frames:v 1 -c:v copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-09-04 21:57:51,784 DEBUG [FFmpegMetadataRetriever] H264 Level value stored in the AVC header (3) is different than one based on ref_frames value (2.2), the higher will be stored
2012-09-04 21:57:51,799 DEBUG [FFmpegMetadataRetriever] File 'rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEcBcKaFcSc.cpccbMbVcsbMaNcocBdAczaTdhbRbqaPabcabscaacaSc6bPaBaDdb-bqrMSs-eS-bzs1DCrlxtBr&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/58/1-0694-7931-001/1-0694-7931-001_coronation-street-(series-53)-2012_tx130812_itv800_16x9-reg.mp4 swfvfy=true' has H264 profile MAIN, level 3 and 6 ref frames
2012-09-04 21:57:51,897 DEBUG [TechnicalMetadataCacheDecorator] Stored technical metadata for online item 'ITV_PLAYER_323141_MEDIUM' in the cache (online_technical_metadata), returning it
2012-09-04 21:57:51,958 DEBUG [OnlineLibraryManager] Thumbnail http://www.itv.com/img/144x81/Coronatio ... 8ae8c3.jpg not in cache yet, loading it
2012-09-04 21:57:52,479 DEBUG [CoverImageService] Resizing and storing cover art image
2012-09-04 21:57:52,499 DEBUG [ImageUtils] Starting image resize, size = 3222 bytes
2012-09-04 21:57:54,092 WARN [PluginCompilerThread] Plugin NHLGameCenterPlugin.groovy failed to compile: startup failed:
@ line 9, column 1.
@ line 9, column 1.
6 errors
2012-09-04 21:57:54,306 DEBUG [ImageUtils] Returning resized image, size = 3223 bytes
2012-09-04 21:57:54,306 DEBUG [CoverImageService] Image successfully resized
2012-09-04 21:57:54,488 DEBUG [ThumbnailCacheDecorator] Stored entry in the cache (thumbnails), returning it
2012-09-04 21:57:54,635 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'Fri 10th August 8:30pm'
2012-09-04 21:57:54,636 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:57:54,649 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -i rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:57:56,367 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-09-04 21:58:00,991 DEBUG [FeedUpdaterThread] Cannot get information about the URL, it might have expired already. Trying again.
2012-09-04 21:58:01,485 DEBUG [FeedItemUrlExtractor] ITVPlayer (UK only): Starting extraction of url for item: Fri 10th August 8:30pm
2012-09-04 21:58:03,709 DEBUG [FeedItemUrlExtractor] ITVPlayer (UK only): Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEdyb6aNb6cidBdCbAcedDcgdecacgdwcMbudhbkcYbvaqceaoasasdRdob4dvcSdU-bqrMSX-eS-8yu1LBvlDuDs&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true, thumbnailUrl=http://www.itv.com/img/144x81/Coronation-Street-c0b1ab25-86bf-4d0c-a778-e17f195f2284.jpg, expiresOn=Sun Sep 09 23:59:00 IST 2012, expiresImmediately=true, cacheKey=ITV_PLAYER_322572_MEDIUM, live=false, ]
2012-09-04 21:58:03,710 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:58:03,712 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -i rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:58:04,563 DEBUG [PluginCompilerThread] Starting plugin NHLGameCenterPlugin.groovy compilation
2012-09-04 21:58:40,433 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.0.9, timeout = 0
2012-09-04 21:58:40,462 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEdyb6aNb6cidBdCbAcedDcgdecacgdwcMbudhbkcYbvaqceaoasasdRdob4dvcSdU-bqrMSX-eS-8yu1LBvlDuDs&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true'
2012-09-04 21:58:40,442 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-09-04 21:58:40,513 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true
2012-09-04 21:58:40,586 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.2:
2012-09-04 21:58:40,619 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-09-04 21:58:40,593 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8eda6066-4ca3-3622-adc9-b1740bc8c845
2012-09-04 21:58:40,759 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -i rtmpe://cp72511.edgefcs.net/ondemand?au ... roduction/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true -frames:v 1 -c:v copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-09-04 21:58:41,686 DEBUG [ContentDirectory] Browse() called for renderer BubbleUPnP Media Renderer (profile 1) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 16, sortCriteria =
2012-09-04 21:58:41,700 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-09-04 21:58:41,719 DEBUG [VideoDAOImpl] Retrieving number of video initials [No_Restriction]
2012-09-04 21:58:41,861 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2 [No_Restriction]
2012-09-04 21:58:41,871 DEBUG [SeriesDAOImpl] Retrieving number of series
2012-09-04 21:58:41,879 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO [No_Restriction]
2012-09-04 21:58:41,885 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos [No_Restriction]
2012-09-04 21:58:41,933 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2012-09-04 21:58:41,934 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0 [No_Restriction]
2012-09-04 21:58:42,202 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2012-09-04 21:58:42,211 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2012-09-04 21:58:43,438 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:49
2012-09-04 21:58:44,242 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2012-09-04 21:58:44,250 DEBUG [WebServer] Incoming connection from /192.168.0.9:45528
2012-09-04 21:58:44,253 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2012-09-04 21:58:44,265 WARN [PluginCompilerThread] Plugin NHLGameCenterPlugin.groovy failed to compile: startup failed:
@ line 9, column 1.
@ line 9, column 1.
6 errors
2012-09-04 21:58:44,386 DEBUG [WebServer] Incoming connection from /192.168.0.9:45529
2012-09-04 21:58:44,389 DEBUG [PlaylistDAOImpl] Retrieving number of playlists for VIDEO [No_Restriction]
2012-09-04 21:58:44,694 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:44,693 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:44,711 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:58:42 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:58:44,712 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:44,716 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:58:42 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:58:44,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:44,793 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-09-04 21:58:44,844 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:58:42 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:58:44,845 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:44,849 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:58:42 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:58:44,851 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:47,581 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
2012-09-04 21:58:47,630 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:58:47,661 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:58:48,249 DEBUG [WebServer] Incoming connection from /192.168.0.9:45531
2012-09-04 21:58:48,259 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:48,369 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 8eda6066-4ca3-3622-adc9-b1740bc8c845 from 192.168.0.9 (headers = [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:58:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6])
2012-09-04 21:58:48,412 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:48,417 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.0.9:8895,DATE: Tue, 04 Sep 2012 20:58:48 GMT,CONNECTION: close,USER-AGENT: Linux/2.6.32.12, UPnP/1.0, Portable SDK for UPnP devices/1.6.6]
2012-09-04 21:58:48,419 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.9
2012-09-04 21:58:48,438 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-09-04 21:58:48,939 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-09-04 21:58:53,302 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-09-04 21:58:54,041 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.2:
2012-09-04 21:58:54,088 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.2
2012-09-04 21:58:56,782 DEBUG [PluginCompilerThread] Starting plugin NHLGameCenterPlugin.groovy compilation
2012-09-04 21:59:00,490 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-09-04 21:59:00,504 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-09-04 21:59:01,169 DEBUG [ContentDirectory] Browse() called for renderer BubbleUPnP Media Renderer (profile 1) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 16, sortCriteria =
2012-09-04 21:59:01,708 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-09-04 21:59:01,938 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-09-04 21:59:01,963 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [No_Restriction]
2012-09-04 21:59:02,357 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 8)
2012-09-04 21:59:10,224 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 9)
2012-09-04 21:59:10,321 DEBUG [FFmpegMetadataRetriever] H264 Level value stored in the AVC header (3) is different than one based on ref_frames value (2.2), the higher will be stored
2012-09-04 21:59:10,378 DEBUG [FFmpegMetadataRetriever] File 'rtmpe://cp72511.edgefcs.net/ondemand?auth=eaEdyb6aNb6cidBdCbAcedDcgdecacgdwcMbudhbkcYbvaqceaoasasdRdob4dvcSdU-bqrMSX-eS-8yu1LBvlDuDs&aifp=v002&slist=production/ swfurl=http://www.itv.com/mercury/Mercury_VideoPlayer.swf playpath=mp4:production/priority/rtmpecatchup/800/AC/1-0694-7930-001/1-0694-7930-001_coronation-street-(series-53)-2012_tx100812_itv800_16x9-reg.mp4 swfvfy=true' has H264 profile MAIN, level 3 and 6 ref frames
2012-09-04 21:59:10,400 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [No_Restriction]
Post Tue Sep 04, 2012 9:58 pm
Re: Serviio Plugins
Things??
Post Wed Sep 05, 2012 6:51 am
Re: Serviio Plugins
NHL plugin was not added to serviio.
irhut
Post Wed Sep 05, 2012 9:03 am
Re: Serviio Plugins
I was just being impatient. This morning the Coronation Street feeds and others are now working. Many thanks for all the help.
Ian
