[SOLVED] Serviio Crashes on Ubuntu 12.04
sbec67
Post Thu Aug 16, 2012 5:49 am
Hi, Serviio run OK for some time..
but then, because of no particular reason it crashes: :(
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0xb6d8db69, pid=4450, tid=2325105472
# JRE version: 7.0_03-b147
# Java VM: OpenJDK Server VM (22.0-b10 mixed mode linux-x86 )
# Derivative: IcedTea7 2.1.1pre
# Distribution: Ubuntu 12.04 LTS, package 7~u3-2.1.1~pre1-1ubuntu3
# Problematic frame:
# V  [libjvm.so+0x519b69]  MarkSweep::follow_stack()+0x59
# Core dump written. Default location: /root/core or core.4450
# An error report file with more information is saved as:
# /root/hs_err_pid4450.log
# If you would like to submit a bug report, please include
# instructions on how to reproduce the bug and visit:
#   https://bugs.launchpad.net/ubuntu/+source/openjdk-7/
Aborted (core dumped)
root@MutliMedia:~# java -version
java version "1.7.0_03"
OpenJDK Runtime Environment (IcedTea7 2.1.1pre) (7~u3-2.1.1~pre1-1ubuntu3)
OpenJDK Server VM (build 22.0-b10, mixed mode)
i also attached the Detail Log...
Can someone help ? :?
Regards SImon
hs_err_pid3520.log
Detail Log
(43.91 KiB) Downloaded 635 times
Post Thu Aug 16, 2012 1:11 pm
Re: Serviio Crashes on Ubuntu 12.04
Try to upgrade Java.
It also mentions Apache Derby in the log, try to downgrade by replacing derby.jar in serviio's lib folder with one from here: http://db.apache.org/derby/releases/rel ... .8.2.2.cgi
sbec67
Post Thu Aug 16, 2012 6:34 pm
Hi
i did this... crashed again..... :cry:
could lt be, that there is a upper limit of Media Files to be in the Database ?
I have something like
50'000 Aufo
5'000 Images
1'000 Videos
Post Fri Aug 17, 2012 8:56 am
No, there is no limit. Unless you are running out of disk space.
sbec67
Post Fri Aug 17, 2012 11:23 am
sure... :lol:
hmm.. OK, what else to try ?.....
OpenJDK is on the most actual releae for Ubuntu
derby.jar is on the Level you posted above.
Regards
maltmoose
Post Fri Aug 17, 2012 8:58 pm
For what its worth im running 12.04 server and latest serviio and it works fine so far.
I notice my java version is different
java version "1.6.0_30"
Java(TM) SE Runtime Environment (build 1.6.0_30-b12)
Java HotSpot(TM) 64-Bit Server VM (build 20.5-b03, mixed mode)
sbec67
Post Sat Aug 18, 2012 2:14 pm
I have recompiled ffmpeg as described in
http://forum.serviio.org/viewtopic.php?f=5&t=6891&p=50493&hilit=ffmpeg+failed#p50493
since then i didnt had any crash jet....
Cross Thumbs that this was teh Solution....
I think Servii is one of the Best DLNA Server's ive seen... when it doesnt Crash :lol:
Regards
Simon
sbec67
Post Sun Aug 19, 2012 3:41 pm
it creashed again :(
sbec67
Post Mon Aug 20, 2012 3:52 am
i gave it a try and downgraded JAVA to Open JDK 6 ....
hope it will run like maltmoose say's :roll:
Regards
sbec67
Post Mon Aug 20, 2012 3:16 pm
OK, server is up for almost 12 Hours now... *crossThumbs* :mrgreen:
kappclark
Post Tue Aug 21, 2012 12:05 am
maltmoose wrote:For what its worth im running 12.04 server and latest serviio and it works fine so far.
I have been having 'issues' with 12.04 and Serviio on my Acer laptop ... need some help..I was able to get this to run in 10.04...the Logitech media server runs just fine on this same platform..
Is there a guide somewhere that can walk me through the correct way to make this happen ?? Obviously Java is critical to Serviio..I did the update to Java, but not sure it is really done properly .. meanwhile, the XP netbook is running Serviio just fine..
sbec67
Post Tue Aug 21, 2012 3:43 am
OK; now after 24 Hours, it still runs... so it seems to be a Problem with OpenJDK 7 :shock:
Greetz
sbec67
Post Fri Aug 24, 2012 5:35 pm
after 3 Day's it crashed again :-(
2012-08-22 05:44:32,500 INFO [UpdateChecker] Checking if a new version is avail
able
2012-08-23 05:44:32,500 INFO [UpdateChecker] Checking if a new version is avail
able
2012-08-23 12:43:05,983 INFO [RendererManager] Stored a new renderer: uuid='c53
746e9-8c0d-49c8-8fc8-3b033545a65c', name = 'Unrecognized device', ipAddress='192
.168.67.33', profile = '1'
2012-08-24 19:27:25,635 INFO [MediaServer] ------------------------------------
I realy like serviio.. would like to get PRO version.. but it's to unstable :-(
Post Mon Aug 27, 2012 10:40 pm
It looks like it just stopped and attempted to start again. I don't know what your problem is, mate. Might be Java, might be FFmpeg, memory .... I have it running for 3 years without a single crash, so I woudln't say it's unstable ;-)
sbec67
Post Tue Aug 28, 2012 5:53 am
;-) .. OK, i beleve, that we get this running in a stable Way... so, you've just sold a PRO Licence ;-)
i didn't see any crash in the meantime..
Still investigating my Transcoding Problem.....
Regards
sbec67
Post Wed Aug 29, 2012 5:00 am
crashed again :-(
sbec@MutliMedia:/usr/share/serviio/bin$ sudo ./serviio.sh
#  SIGSEGV (0xb) at pc=0xb6b8cd45, pid=30370, tid=2326281024
# JRE version: 6.0_24-b24
# Java VM: OpenJDK Server VM (20.0-b12 mixed mode linux-x86 )
# Derivative: IcedTea6 1.11.3
# Distribution: Ubuntu 12.04 LTS, package 6b24-1.11.3-1ubuntu0.12.04.1
# V  [libjvm.so+0x2aed45]  ScanClosure::do_oop(oopDesc**)+0x25
# /usr/share/serviio/bin/hs_err_pid30370.log
# instructions how to reproduce the bug and visit:
#   https://bugs.launchpad.net/ubuntu/+source/openjdk-6/
Find the Err Log attached.....
Regards
Simon
hs_err_pid30370.log
(36.05 KiB) Downloaded 584 times
dekips
Post Sat Sep 01, 2012 3:14 pm
You may consider installing the Oracle version of Java and follow https://sites.google.com/site/easylinuxtipsproject/java. I have not had any issues and I've been running Serviio on Ubuntu 12.04, Debian 6.0 and Linux Mint 12 and 13. I always go with Oracle/Sun Java for compatibility sake :D
EDIT:
I found a link I use, http://www.webupd8.org/2012/01/install- ... u-via.html which walks you through adding the repository for an oracle java install. Make sure you remove all of the openjdk packages first. I think by default that is openjdk-6-jre-headless.
sbec67
Post Mon Sep 03, 2012 7:15 pm
hmmm.. OK i give it a Try with Opracle (Sun) Java...
i instaleld it like described here: http://www.ubuntugeek.com/how-to-install-oracle-java-7-in-ubuntu-12-04.html
worked better for me ;-)
Serviio run again.. hope 4 ever now ;-)
Regards
Simon
sbec67
Post Mon Sep 10, 2012 11:30 am
Re: [SOLVED] Serviio Crashes on Ubuntu 12.04
seems, this was the thing....
didn't have any Crash, since going to Sun(Java) :mrgreen:
Greetz
Post Mon Sep 10, 2012 9:53 pm
cool, fingers crossed :-)
Users browsing this forum: No registered users and 75 guests
