Indexing Music not working
phiberosmosis
Post Tue Sep 04, 2012 7:56 pm
I am trying to get Serviio to index my music with no luck. Ive added the music folder and have it selected but it does nothing.
Im worried that it is possible that my folder structure is too deep. This is a how deep my folders go
D:\Music\HPlappie\iTunes\iTunes Music\3oh!3\Want
The D:\Music is what i have indexing and the Want folder is the folder with the MP3's
Post Tue Sep 04, 2012 8:15 pm
Re: Indexing Music not working
Turn on detailed logging (see my sig) and post the log file from C:\Program Files\Serviio\log\serviio.log
There is no limit on folder depth (well there could be but its would be so massive you don't have to worry about it)
phiberosmosis
Post Tue Sep 04, 2012 9:13 pm
will wrote:Turn on detailed logging (see my sig) and post the log file from C:\Program Files\Serviio\log\serviio.log
Here is my log
https://dl.dropbox.com/u/10919925/serviio.log
Post Wed Sep 05, 2012 7:36 am
[quote="phiberosmosis"Here is my log
https://dl.dropbox.com/u/10919925/serviio.log[/quote]
Lots of mp3 file were added to serviio library, for example :
2012-09-04 15:11:02,971 DEBUG [MediaItemDAOImpl] Media item 07 Dirrty [Video Edit] 1.m4a already exists in DB
2012-09-04 15:11:02,814 DEBUG [MediaItemDAOImpl] Media item 01 Me & U.mp3 already exists in DB
What is your renderer, a TV, a BlurayPlayer ?
Do you select Audio section on your renderer ?
phiberosmosis
Post Wed Sep 05, 2012 7:26 pm
Illico wrote:Lots of mp3 file were added to serviio library, for example :
I have several devices. A Logitech revue, a ps3, and an xbox 360. None work for music.
Attached is screenshots I hope answer your question.
My media
My Players
Post Wed Sep 05, 2012 7:40 pm
Illico wrote:Do you select Audio section on your renderer ?
For example with your PS3, on the sony XMB menu, do you select the Audio section?
phiberosmosis
Post Wed Sep 05, 2012 8:17 pm
Yep. I can see serviio but nothing under it.
When I sign onto mediabrowser remotely here is what i see
drilled into folders under video
Serviio Media Browser 2.png (444.34 KiB) Viewed 12538 times
When i first login
Serviio Media Browser1.png (324.19 KiB) Viewed 12538 times
Post Sun Sep 09, 2012 10:27 pm
Can you see the items in AV media Controller from Intel tools (see my signature)
phiberosmosis
Post Tue Sep 18, 2012 8:49 pm
zip wrote:Can you see the items in AV media Controller from Intel tools (see my signature)
Is there a guide on how to use this?
7h3ju57
Post Thu Sep 20, 2012 9:34 pm
Hey i'm having the same issue i can see in the log that it add the repository but then doesnt see anything in it
here's my log
https://docs.google.com/open?id=0B37yUu ... EtfQ2FZOEE
everything else works fine only music is affected
edit1 : ive also tried the av controller app from your sig and still comes up empty
Post Thu Sep 20, 2012 9:48 pm
7h3ju57 wrote:Hey i'm having the same issue i can see in the log that it add the repository but then doesnt see anything in it
here's my log
Probaby access rights issue. Is f: a remote drive?
7h3ju57
Post Thu Sep 20, 2012 10:06 pm
here's my log
no its a local drive on my computer i keep all my media on there movies, tv shows, music
does serviio create a user to access the files?
edit 1: ok i think i figured it out, looks like the file had full right for me to access the folder but once i added administrators serviio was able to access it, so im assuming serviio doesnt access the files as current user then?
Post Thu Sep 20, 2012 10:14 pm
no, it uses as Local System user - you can change that in the Services panel
7h3ju57
Post Thu Sep 20, 2012 10:17 pm
zip wrote:no, it uses as Local System user - you can change that in the Services panel
hey thanks a lot! your suggestion made me think of checking permissions is that user part of administrators?
Post Thu Sep 20, 2012 10:18 pm
probably not. ideally change the service's user to a normal user (like yourself or Administrator)
