Minimum requirement for PC
jean-francois
Post Sat Sep 15, 2012 11:55 pm
Hi, I have Serviio installed on my MAC and PC, for the PC what would be the minimum requirement for memory and CPU to plays high quality movies ?
The video stutters a lot on high quality HD video, and I have check the FAQ.
On lower quality video I have no issue.
My WIFI Router is a Cisco 4200 so I know it is OK.
Thank you.
kappclark
Post Sat Sep 29, 2012 2:29 pm
Re: Minimum requirement for PC
What kind of an Internet connection do you have ?
Switch to cat5 for connectivity - much more reliable than Wifi, or maybe reposition your wireless for a better signal...what % strength is the signal ? Any other users on the network ?
Wireless 803.11n @ 5ghz may be the answer (less interference and higher bandwidth) ... I have not made that change but I am considering ..
Spadge
Post Sat Sep 29, 2012 3:33 pm
"Minimum spec" is really hard to gauge for HD playback.
If you're using VLC you can improve performance dramatically with a simple changing of the x264 skip loop filter setting.
Or are you talking about running the Serviio server on your PC and another device is doing the rendering?
Users browsing this forum: Baidu [Spider] and 17 guests
