stacktrace with person name 'Len Wiseman'
Elwell
Post Fri Sep 28, 2012 9:44 am
I'm guessing that something interpreted 'len' as a reserved word and failed ....
2012-09-27 20:36:39,871 WARN [LibraryAdditionsCheckerThread] Cannot add file Total Recall.avi because of an unexpected error. Message: Cannot read Person with name = Len Wiseman
org.serviio.db.dao.PersistenceException: Cannot read Person with name = Len Wiseman
at org.serviio.library.dao.PersonDAOImpl.findPersonByName(PersonDAOImpl.java:61)
at org.serviio.library.dao.PersonDAOImpl.addPersonToMedia(PersonDAOImpl.java:108)
at org.serviio.library.local.service.VideoService.addVideoToLibrary(VideoService.java:111)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:188)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:83)
Caused by: java.sql.SQLNonTransientConnectionException: Connection closed by unknown interrupt.
at org.apache.derby.impl.jdbc.EmbedResultSet.closeOnTransactionError(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedResultSet.movePosition(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedResultSet.next(Unknown Source)
at org.serviio.library.dao.PersonDAOImpl.mapSingleResult(PersonDAOImpl.java:747)
at org.serviio.library.dao.PersonDAOImpl.findPersonByName(PersonDAOImpl.java:59)
... 5 more
Caused by: java.sql.SQLException: Connection closed by unknown interrupt.
... 16 more
Caused by: ERROR 08000: Connection closed by unknown interrupt.
at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
at org.apache.derby.impl.sql.execute.BulkTableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.getNextRow(Unknown Source)
... 9 more
2012-09-27 20:36:39,889 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 1 as scanned
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:173)
at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:112)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:84)
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:171)
... 2 more
... 12 more
at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.collectAffectedRows(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.open(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
... 6 more
Post Sat Sep 29, 2012 10:21 am
Re: stacktrace with person name 'Len Wiseman'
Was Serviio being stopped at the same time? It passes my tests.
Elwell
Post Sun Sep 30, 2012 9:00 pm
not stopped, but I think I might have triggered a REST library refresh at the same time -- <action><name>forceLibraryRefresh</name></action>
as I spotted another stacktrace in the logs when adding a set of directories -- it could be that I added a new dir and forced a refresh while it was still indexing a previous run (I've just been moving a pile of video data between disks)
