Console windows does not refresh properly
rosahas
Post Tue Oct 02, 2012 4:45 am
Has anyone else had this issue? Everytime I open the console, it always shows up blank. I have to hover over my window / tabs to make them appear.
Here is an example of what I see after a few hover over..
the list never shows up, I have to guess and click on the center part of the windows to get it to show up one line at a time!
I am running Serviio 1.0.1 as you can see and it's on a Windows 7 Enterprise 64 bit laptop.
Post Tue Oct 02, 2012 7:09 am
Re: Console windows does not refresh properly
rosahas wrote:Has anyone else had this issue? Everytime I open the console, it always shows up blank.
Try to change the "Personalize" desktop to "Classic".
Post Tue Oct 02, 2012 4:27 pm
Might be due to Java version or maybe your graphics card drivers. Try to uninstall all Java and install the latest.
rosahas
Post Fri Oct 05, 2012 5:39 am
Changing it to "Classic" definitely fixes the problem..but, wow that looks quite old. Any way around this issue and staying with the modern "personalized" look?
rosahas
Post Fri Oct 05, 2012 5:41 am
zip wrote:Might be due to Java version or maybe your graphics card drivers. Try to uninstall all Java and install the latest.
Hi zip,
I have Java 7 update 5 and I think the latest one is Java 7 update 7... so, it's quite current. I will try to update it just in case anyway.
I will look into updating the video card drivers as well..
Users browsing this forum: Google [Bot] and 70 guests
