IP Cam MJPEG cgo support?
hwmonkey
Post Sat Aug 04, 2012 3:50 am
I am attempting to understand live streams and serviio support. I have upgraded to serviio 1.0
I have an IP camera with a stream available at http://ip/livestream.cgi?user=user&pwd=pwd . When I try doing an ffmpeg -i, I get....
[loas @ 0x21851b0] Format loas detected only with low score of 1, misdetection possible!
[loas @ 0x21851b0] Stream #0: not enough frames to estimate rate; consider increasing probesize
[loas @ 0x21851b0] decoding for stream 0 failed
[loas @ 0x21851b0] Could not find codec parameters for stream 0 (Audio: aac_latm, 0 channels, s16): unspecified sample rate
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[loas @ 0x21851b0] Estimating duration from bitrate, this may be inaccurate
So the question is... are IP cameras supported now? I obviously have problems with the existing URL, but is there a way to make a plug in or something else to make it work?
Thanks!
Post Sat Aug 04, 2012 10:57 am
Re: IP Cam MJPEG cgo support?
is that all you get from the FFmpeg output?
hwmonkey
Post Sat Aug 04, 2012 12:15 pm
No. But this is....
ffmpeg version git-2012-07-23-7afd42d Copyright (c) 2000-2012 the FFmpeg developers
  built on Jul 23 2012 09:52:15 with gcc 4.6.1 (Ubuntu/Linaro 4.6.1-9ubuntu3)
  configuration: --enable-pthreads --disable-mmx --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-librtmp --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-x11grab --enable-libx264 --enable-nonfree --enable-version3 --enable-librtmp --pkg-config=pkg-config
  libavutil      51. 65.100 / 51. 65.100
  libavcodec     54. 44.100 / 54. 44.100
  libavformat    54. 19.100 / 54. 19.100
  libavdevice    54.  2.100 / 54.  2.100
  libavfilter     3.  3.100 /  3.  3.100
Thanks!
Post Sat Aug 04, 2012 1:05 pm
Looks like FFmpeg cannot detect what the stream is, so it won't work in Serviio
nranka
Post Sat Oct 06, 2012 8:03 pm
I'm trying to add the live feed of my IP Webcam android application.
ffmpeg for the stream provided the following output - not sure what this means?
C:\Program Files\Serviio\lib>ffmpeg -i "http://192.168.1.110:8081/videofeed
g-config
[loas @ 0037BC80] Format loas detected only with low score of 1, misdetection po
ssible!
Appreciate the guidance!
nranka
Post Sun Oct 07, 2012 12:54 pm
is that URL of the stream or a web site? FFmpeg doesn't understand it.
