[SOLVED] Downloading version 1.0.1
pingodoce
Post Thu Oct 25, 2012 1:26 pm
When I open Serviio I get a pop-up informing me that there is a newer version available (1.0.1), but after downloading it and trying to open it, I get a message saying the file is damaged. I have tried several times but with no luck.
I cannot believe that Serviio are offering a damaged file for download.
Can anyone help please.
I am using an iMac loaded with Mountain Lion.
Post Thu Oct 25, 2012 1:31 pm
Re: Downloading version 1.0.1
pingodoce
Post Fri Oct 26, 2012 9:39 am
Thank you for your response, however since receiving your advice I have once again downloaded Serviio 1.0.1, expanded it and when I select Control-click the same pop-up appears on the screen which states: -
"Serviio" is damaged and can't be opened. You should move it to trash.
I downloaded today 26th Oct. 10.19 BST using Google Chrome.
It doesn't seem to be that "Gatekeeper" is identifying it as a foreign program, it suggests that the file is damaged or being corrupted during download.
Is anyone else experiencing this?
Post Fri Oct 26, 2012 11:19 am
Try turning gatekeeper off (see the link to apple support), run Serviio and then ServiioConsole, then turn gatekeeper on again. That fixed it for other users that had a problem with it saying that the file is damaged.
pingodoce
Post Fri Oct 26, 2012 4:16 pm
You are absolutely right, thank you very much for your assistance. It worked first time!
Users browsing this forum: Baidu [Spider] and 38 guests
