Any way to force a movie to be identified?
atguilmette
Post Mon Oct 29, 2012 2:01 pm
I have a few movies that I cannot get ID'd properly, and it is driving me crazy. I really like the product and just applied my license file the other day, so I was hoping to take advantage of some great support here. :-)
There are a handful of movies that I cannot get ID'd to save my life:
Mission Impossible - Ghost Protocol
Captain America: The First Avenger
Ghost Rider: Spirit of Vengeance
All of these get ID'd as "Action" (I'm not sure how it's doing that--I'm guessing because they're in a folder named 'Action'). I've tried all of the common naming techniques (obviously, can't have colons, so I've tried removing all punctuation, replacing : with -, adding dates, etc). If I just do "Captain America" for example, the metadata for a low-budget flick from the 70's is returned.
Additionally, I have a handful of other movies that are getting ID'd as the wrong movie altogether (at any point in time, I have 2 movies being identified as "Ghost in the Shell" even though I've only got one appearance of the word 'Ghost' in all 450+ of my ripped movies).
I do have maybe 10% of my movies with the wrong cover art (right movie, wrong language) as well, but I think the workaround has just been to move the artwork into the same folder as the movie itself (I also use PS3MS and have the artwork in a separate directory).
I've tried using MCM and a few other tools to generate the NFOs, but can't seem to get those to work either without doing it for all of my movies (which is a hassle, because I'm ripping 5 or 6 of my kids movies per day and am trying to get it done quickly).
So, my question woudl be--is there a way / guide / tool / method to determine what I need to name something to get at least the name recognized correctly? Or a way to specify which language cover art I would like? Like maybe some alternate front-end to themoviedb.org that I can test names against?
atguilmette
Post Mon Oct 29, 2012 2:15 pm
Re: Any way to force a movie to be identified?
For example, this is what I'm getting with Captain America:
Captain America The First Avenger.mkv - Unrecognized
Captain America The First Avenger (2011).mkv - Unrecognized
Captain America The First Avenger [2011].mkv - Unrecognized
1771-captain-america-the-first-avenger.mkv - Unrecognized
1771-captain-america-the-first-avenger-2011.mkv - Unrecognized
Captain America The First Avenger (2012).mkv - ID'd as "Truth or Die"
Captain America The First Avenger (2010).mkv - ID'd as "Jehovah's Witnesses - Faith In Action - Part 1: Out Of Darkness"
Help!
Post Mon Oct 29, 2012 8:29 pm
I tried your first file name in my tests and it worked.
Can you enable detailed log, rename the file to the first example from your list, force refresh and post the log.
atguilmette
Post Tue Oct 30, 2012 2:09 am
It became quite a huge log. I can PM it to you if you'd like ... I looked through the log file and came back with this ...
2012-10-29 21:58:35,649 DEBUG [LibraryAdditionsCheckerThread] Found file 'Captain America The First Avenger (2011).mkv', checking if it's already in the Library
2012-10-29 21:58:35,649 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Captain America The First Avenger (2011).mkv
2012-10-29 21:58:35,649 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv, ignore case: true
2012-10-29 21:58:35,650 DEBUG [MediaItemDAOImpl] Media item Captain America The First Avenger (2011).mkv doesn't exist in DB yet
2012-10-29 21:58:35,651 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-10-29 21:58:35,663 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-10-29 21:58:35,697 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2012-10-29 21:58:35,700 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2012-10-29 21:58:35,708 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv
2012-10-29 21:58:35,713 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv
2012-10-29 21:58:35,714 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv
2012-10-29 21:58:35,817 DEBUG [MediaItemDAOImpl] Getting file of media item 1438
2012-10-29 21:58:35,818 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv'
2012-10-29 21:58:35,819 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv
2012-10-29 21:58:35,819 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv -frames:v 1 -c:v copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-10-29 21:58:35,849 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1438) and extractor EMBEDDED
2012-10-29 21:58:35,892 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1438) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,904 DEBUG [MediaItemDAOImpl] Getting file of media item 1439
2012-10-29 21:58:35,905 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1439) and extractor EMBEDDED
2012-10-29 21:58:35,909 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1439) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,917 DEBUG [MediaItemDAOImpl] Getting file of media item 1440
2012-10-29 21:58:35,919 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1440) and extractor EMBEDDED
2012-10-29 21:58:35,921 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1440) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,931 DEBUG [MediaItemDAOImpl] Getting file of media item 1441
2012-10-29 21:58:35,933 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1441) and extractor EMBEDDED
2012-10-29 21:58:35,935 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1441) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,943 DEBUG [MediaItemDAOImpl] Getting file of media item 1442
2012-10-29 21:58:35,948 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1442) and extractor EMBEDDED
2012-10-29 21:58:35,952 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1442) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,959 DEBUG [MediaItemDAOImpl] Getting file of media item 1443
2012-10-29 21:58:35,960 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1443) and extractor EMBEDDED
2012-10-29 21:58:35,962 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1443) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,967 DEBUG [MediaItemDAOImpl] Getting file of media item 1444
2012-10-29 21:58:35,968 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1444) and extractor EMBEDDED
2012-10-29 21:58:35,970 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1444) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,973 DEBUG [FFmpegMetadataRetriever] H264 Level value stored in the AVC header (4.1) is different than one based on ref_frames value (4), the higher will be stored
2012-10-29 21:58:35,973 DEBUG [FFmpegMetadataRetriever] File 'E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv' has H264 profile HIGH, level 4.1 and 5 ref frames
2012-10-29 21:58:35,975 DEBUG [MediaItemDAOImpl] Getting file of media item 1445
2012-10-29 21:58:35,976 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1445) and extractor EMBEDDED
2012-10-29 21:58:35,978 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1445) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,983 DEBUG [MediaItemDAOImpl] Getting file of media item 1446
2012-10-29 21:58:35,985 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1446) and extractor EMBEDDED
2012-10-29 21:58:35,987 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1446) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,991 DEBUG [MediaItemDAOImpl] Getting file of media item 1447
2012-10-29 21:58:35,993 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1447) and extractor EMBEDDED
2012-10-29 21:58:35,994 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1447) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:35,999 DEBUG [MediaItemDAOImpl] Getting file of media item 1448
2012-10-29 21:58:36,001 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1448) and extractor EMBEDDED
2012-10-29 21:58:36,003 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1448) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,007 DEBUG [MediaItemDAOImpl] Getting file of media item 1449
2012-10-29 21:58:36,009 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1449) and extractor EMBEDDED
2012-10-29 21:58:36,011 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1449) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,015 DEBUG [MediaItemDAOImpl] Getting file of media item 1450
2012-10-29 21:58:36,017 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1450) and extractor EMBEDDED
2012-10-29 21:58:36,019 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1450) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,024 DEBUG [MediaItemDAOImpl] Getting file of media item 1452
2012-10-29 21:58:36,025 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv
2012-10-29 21:58:36,025 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -ss 120 -i E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv -an -frames:v 1 -f image2 pipe:
2012-10-29 21:58:36,026 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1452) and extractor EMBEDDED
2012-10-29 21:58:36,028 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1452) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,037 DEBUG [MediaItemDAOImpl] Getting file of media item 1453
2012-10-29 21:58:36,039 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1453) and extractor EMBEDDED
2012-10-29 21:58:36,041 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1453) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,045 DEBUG [MediaItemDAOImpl] Getting file of media item 1454
2012-10-29 21:58:36,048 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1454) and extractor EMBEDDED
2012-10-29 21:58:36,050 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1454) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,055 DEBUG [MediaItemDAOImpl] Getting file of media item 1455
2012-10-29 21:58:36,057 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1455) and extractor EMBEDDED
2012-10-29 21:58:36,059 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1455) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,064 DEBUG [MediaItemDAOImpl] Getting file of media item 1456
2012-10-29 21:58:36,066 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1456) and extractor EMBEDDED
2012-10-29 21:58:36,068 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1456) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,073 DEBUG [MediaItemDAOImpl] Getting file of media item 1457
2012-10-29 21:58:36,075 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1457) and extractor EMBEDDED
2012-10-29 21:58:36,077 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1457) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,082 DEBUG [MediaItemDAOImpl] Getting file of media item 1458
2012-10-29 21:58:36,085 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1458) and extractor EMBEDDED
2012-10-29 21:58:36,087 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1458) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,092 DEBUG [MediaItemDAOImpl] Getting file of media item 1459
2012-10-29 21:58:36,095 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1459) and extractor EMBEDDED
2012-10-29 21:58:36,096 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1459) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,100 DEBUG [MediaItemDAOImpl] Getting file of media item 1460
2012-10-29 21:58:36,102 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1460) and extractor EMBEDDED
2012-10-29 21:58:36,103 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1460) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,107 DEBUG [MediaItemDAOImpl] Getting file of media item 1461
2012-10-29 21:58:36,108 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1461) and extractor EMBEDDED
2012-10-29 21:58:36,110 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1461) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,114 DEBUG [MediaItemDAOImpl] Getting file of media item 1462
2012-10-29 21:58:36,115 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1462) and extractor EMBEDDED
2012-10-29 21:58:36,117 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1462) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,121 DEBUG [MediaItemDAOImpl] Getting file of media item 1463
2012-10-29 21:58:36,123 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1463) and extractor EMBEDDED
2012-10-29 21:58:36,125 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1463) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,129 DEBUG [MediaItemDAOImpl] Getting file of media item 1464
2012-10-29 21:58:36,130 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1464) and extractor EMBEDDED
2012-10-29 21:58:36,132 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1464) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,136 DEBUG [MediaItemDAOImpl] Getting file of media item 1465
2012-10-29 21:58:36,138 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1465) and extractor EMBEDDED
2012-10-29 21:58:36,140 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1465) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,145 DEBUG [MediaItemDAOImpl] Getting file of media item 1466
2012-10-29 21:58:36,147 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1466) and extractor EMBEDDED
2012-10-29 21:58:36,149 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1466) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,152 DEBUG [MediaItemDAOImpl] Getting file of media item 1467
2012-10-29 21:58:36,154 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1467) and extractor EMBEDDED
2012-10-29 21:58:36,155 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1467) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,159 DEBUG [MediaItemDAOImpl] Getting file of media item 1468
2012-10-29 21:58:36,161 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1468) and extractor EMBEDDED
2012-10-29 21:58:36,162 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1468) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,166 DEBUG [MediaItemDAOImpl] Getting file of media item 1469
2012-10-29 21:58:36,168 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1469) and extractor EMBEDDED
2012-10-29 21:58:36,170 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1469) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,175 DEBUG [MediaItemDAOImpl] Getting file of media item 1470
2012-10-29 21:58:36,177 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1470) and extractor EMBEDDED
2012-10-29 21:58:36,179 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1470) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,183 DEBUG [MediaItemDAOImpl] Getting file of media item 1471
2012-10-29 21:58:36,185 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1471) and extractor EMBEDDED
2012-10-29 21:58:36,187 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1471) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,191 DEBUG [MediaItemDAOImpl] Getting file of media item 1472
2012-10-29 21:58:36,193 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1472) and extractor EMBEDDED
2012-10-29 21:58:36,195 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1472) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,199 DEBUG [MediaItemDAOImpl] Getting file of media item 1473
2012-10-29 21:58:36,201 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1473) and extractor EMBEDDED
2012-10-29 21:58:36,203 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1473) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,207 DEBUG [MediaItemDAOImpl] Getting file of media item 1474
2012-10-29 21:58:36,209 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1474) and extractor EMBEDDED
2012-10-29 21:58:36,211 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1474) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,215 DEBUG [MediaItemDAOImpl] Getting file of media item 1475
2012-10-29 21:58:36,217 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1475) and extractor EMBEDDED
2012-10-29 21:58:36,219 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1475) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,227 DEBUG [MediaItemDAOImpl] Getting file of media item 1476
2012-10-29 21:58:36,229 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1476) and extractor EMBEDDED
2012-10-29 21:58:36,233 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1476) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,252 DEBUG [MediaItemDAOImpl] Getting file of media item 1477
2012-10-29 21:58:36,254 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1477) and extractor EMBEDDED
2012-10-29 21:58:36,257 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1477) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,268 DEBUG [MediaItemDAOImpl] Getting file of media item 1478
2012-10-29 21:58:36,270 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1478) and extractor EMBEDDED
2012-10-29 21:58:36,272 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1478) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,277 DEBUG [MediaItemDAOImpl] Getting file of media item 1479
2012-10-29 21:58:36,279 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1479) and extractor EMBEDDED
2012-10-29 21:58:36,282 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1479) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,286 DEBUG [MediaItemDAOImpl] Getting file of media item 1480
2012-10-29 21:58:36,288 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1480) and extractor EMBEDDED
2012-10-29 21:58:36,290 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1480) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,295 DEBUG [MediaItemDAOImpl] Getting file of media item 1481
2012-10-29 21:58:36,297 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1481) and extractor EMBEDDED
2012-10-29 21:58:36,299 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1481) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,302 DEBUG [MediaItemDAOImpl] Getting file of media item 1482
2012-10-29 21:58:36,304 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1482) and extractor EMBEDDED
2012-10-29 21:58:36,306 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1482) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,310 DEBUG [MediaItemDAOImpl] Getting file of media item 1483
2012-10-29 21:58:36,312 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1483) and extractor EMBEDDED
2012-10-29 21:58:36,315 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1483) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,342 DEBUG [MediaItemDAOImpl] Getting file of media item 1484
2012-10-29 21:58:36,344 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1484) and extractor EMBEDDED
2012-10-29 21:58:36,346 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1484) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,350 DEBUG [MediaItemDAOImpl] Getting file of media item 1485
2012-10-29 21:58:36,351 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1485) and extractor EMBEDDED
2012-10-29 21:58:36,353 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1485) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,358 DEBUG [MediaItemDAOImpl] Getting file of media item 1486
2012-10-29 21:58:36,361 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1486) and extractor EMBEDDED
2012-10-29 21:58:36,364 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1486) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,370 DEBUG [MediaItemDAOImpl] Getting file of media item 1487
2012-10-29 21:58:36,372 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1487) and extractor EMBEDDED
2012-10-29 21:58:36,376 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1487) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,383 DEBUG [MediaItemDAOImpl] Getting file of media item 1488
2012-10-29 21:58:36,386 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1488) and extractor EMBEDDED
2012-10-29 21:58:36,386 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=Captain America The First Avenger (2011), filePath=E:\Media\Movies\Action\Captain America The First Avenger (2011).mkv, fileSize=10870479301, audioBitrate=1536, audioCodec=DTS, audioStreamIndex=1, bitrate=11670, channels=6, container=MATROSKA, contentType=UNKNOWN, coverImage=org.serviio.library.local.metadata.ImageDescriptor@23387751, duration=7451, episodeNumber=null, fps=23.976, frequency=48000, h264Level=4.1, h264Profile=HIGH, mkvHeaderCompression=false, ftyp=null, height=816, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=H264, videoStreamIndex=0, width=1920]
2012-10-29 21:58:36,388 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1488) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,397 DEBUG [MediaItemDAOImpl] Getting file of media item 1489
2012-10-29 21:58:36,399 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1489) and extractor EMBEDDED
2012-10-29 21:58:36,401 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1489) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,402 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'captain america the first avenger' 2011 (language: en)
2012-10-29 21:58:36,408 DEBUG [MediaItemDAOImpl] Getting file of media item 1490
2012-10-29 21:58:36,410 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1490) and extractor EMBEDDED
2012-10-29 21:58:36,412 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1490) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,418 DEBUG [MediaItemDAOImpl] Getting file of media item 1491
2012-10-29 21:58:36,419 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1491) and extractor EMBEDDED
2012-10-29 21:58:36,421 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1491) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,427 DEBUG [MediaItemDAOImpl] Getting file of media item 1492
2012-10-29 21:58:36,428 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1492) and extractor EMBEDDED
2012-10-29 21:58:36,430 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1492) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,436 DEBUG [MediaItemDAOImpl] Getting file of media item 1493
2012-10-29 21:58:36,437 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1493) and extractor EMBEDDED
2012-10-29 21:58:36,439 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1493) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,443 DEBUG [MediaItemDAOImpl] Getting file of media item 1494
2012-10-29 21:58:36,444 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1494) and extractor EMBEDDED
2012-10-29 21:58:36,446 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1494) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,450 DEBUG [MediaItemDAOImpl] Getting file of media item 1495
2012-10-29 21:58:36,451 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1495) and extractor EMBEDDED
2012-10-29 21:58:36,453 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1495) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,457 DEBUG [MediaItemDAOImpl] Getting file of media item 1496
2012-10-29 21:58:36,458 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1496) and extractor EMBEDDED
2012-10-29 21:58:36,460 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1496) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,464 DEBUG [MediaItemDAOImpl] Getting file of media item 1497
2012-10-29 21:58:36,466 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1497) and extractor EMBEDDED
2012-10-29 21:58:36,467 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1497) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,471 DEBUG [MediaItemDAOImpl] Getting file of media item 1498
2012-10-29 21:58:36,473 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1498) and extractor EMBEDDED
2012-10-29 21:58:36,475 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1498) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,478 DEBUG [MediaItemDAOImpl] Getting file of media item 1499
2012-10-29 21:58:36,480 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1499) and extractor EMBEDDED
2012-10-29 21:58:36,482 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1499) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,488 DEBUG [MediaItemDAOImpl] Getting file of media item 1500
2012-10-29 21:58:36,490 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1500) and extractor EMBEDDED
2012-10-29 21:58:36,492 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1500) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,495 DEBUG [MediaItemDAOImpl] Getting file of media item 1501
2012-10-29 21:58:36,497 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1501) and extractor EMBEDDED
2012-10-29 21:58:36,499 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1501) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,503 DEBUG [MediaItemDAOImpl] Getting file of media item 1502
2012-10-29 21:58:36,504 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1502) and extractor EMBEDDED
2012-10-29 21:58:36,505 DEBUG [TheMovieDBSourceAdaptor] Found 1 matches
2012-10-29 21:58:36,506 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1502) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,508 DEBUG [TheMovieDBSourceAdaptor] Searching for movie 'action' 2011 (language: en)
2012-10-29 21:58:36,510 DEBUG [MediaItemDAOImpl] Getting file of media item 1503
2012-10-29 21:58:36,512 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1503) and extractor EMBEDDED
2012-10-29 21:58:36,513 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1503) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,517 DEBUG [MediaItemDAOImpl] Getting file of media item 1504
2012-10-29 21:58:36,519 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1504) and extractor EMBEDDED
2012-10-29 21:58:36,520 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1504) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,524 DEBUG [MediaItemDAOImpl] Getting file of media item 1505
2012-10-29 21:58:36,526 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1505) and extractor EMBEDDED
2012-10-29 21:58:36,528 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1505) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,532 DEBUG [MediaItemDAOImpl] Getting file of media item 1506
2012-10-29 21:58:36,533 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1506) and extractor EMBEDDED
2012-10-29 21:58:36,535 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1506) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,539 DEBUG [MediaItemDAOImpl] Getting file of media item 1507
2012-10-29 21:58:36,541 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1507) and extractor EMBEDDED
2012-10-29 21:58:36,542 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1507) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,546 DEBUG [MediaItemDAOImpl] Getting file of media item 1508
2012-10-29 21:58:36,548 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1508) and extractor EMBEDDED
2012-10-29 21:58:36,549 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1508) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,553 DEBUG [MediaItemDAOImpl] Getting file of media item 1509
2012-10-29 21:58:36,555 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1509) and extractor EMBEDDED
2012-10-29 21:58:36,556 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1509) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,560 DEBUG [MediaItemDAOImpl] Getting file of media item 1510
2012-10-29 21:58:36,562 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1510) and extractor EMBEDDED
2012-10-29 21:58:36,564 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1510) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,567 DEBUG [MediaItemDAOImpl] Getting file of media item 1511
2012-10-29 21:58:36,569 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1511) and extractor EMBEDDED
2012-10-29 21:58:36,571 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1511) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,575 DEBUG [MediaItemDAOImpl] Getting file of media item 1512
2012-10-29 21:58:36,576 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1512) and extractor EMBEDDED
2012-10-29 21:58:36,578 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1512) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,582 DEBUG [MediaItemDAOImpl] Getting file of media item 1513
2012-10-29 21:58:36,583 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1513) and extractor EMBEDDED
2012-10-29 21:58:36,585 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1513) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,589 DEBUG [MediaItemDAOImpl] Getting file of media item 1514
2012-10-29 21:58:36,590 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1514) and extractor EMBEDDED
2012-10-29 21:58:36,592 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1514) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,596 DEBUG [MediaItemDAOImpl] Getting file of media item 1515
2012-10-29 21:58:36,597 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1515) and extractor EMBEDDED
2012-10-29 21:58:36,599 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1515) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,603 DEBUG [MediaItemDAOImpl] Getting file of media item 1516
2012-10-29 21:58:36,604 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1516) and extractor EMBEDDED
2012-10-29 21:58:36,606 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1516) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,609 DEBUG [MediaItemDAOImpl] Getting file of media item 1517
2012-10-29 21:58:36,611 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1517) and extractor EMBEDDED
2012-10-29 21:58:36,613 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1517) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,616 DEBUG [MediaItemDAOImpl] Getting file of media item 1518
2012-10-29 21:58:36,618 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1518) and extractor EMBEDDED
2012-10-29 21:58:36,620 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1518) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,623 DEBUG [MediaItemDAOImpl] Getting file of media item 1519
2012-10-29 21:58:36,625 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1519) and extractor EMBEDDED
2012-10-29 21:58:36,627 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1519) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,630 DEBUG [MediaItemDAOImpl] Getting file of media item 1520
2012-10-29 21:58:36,632 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1520) and extractor EMBEDDED
2012-10-29 21:58:36,633 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1520) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,639 DEBUG [MediaItemDAOImpl] Getting file of media item 1521
2012-10-29 21:58:36,641 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1521) and extractor EMBEDDED
2012-10-29 21:58:36,643 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1521) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,646 DEBUG [MediaItemDAOImpl] Getting file of media item 1522
2012-10-29 21:58:36,648 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1522) and extractor EMBEDDED
2012-10-29 21:58:36,649 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1522) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,653 DEBUG [MediaItemDAOImpl] Getting file of media item 1523
2012-10-29 21:58:36,654 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1523) and extractor EMBEDDED
2012-10-29 21:58:36,656 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1523) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,660 DEBUG [MediaItemDAOImpl] Getting file of media item 1524
2012-10-29 21:58:36,661 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1524) and extractor EMBEDDED
2012-10-29 21:58:36,663 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1524) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,667 DEBUG [MediaItemDAOImpl] Getting file of media item 1525
2012-10-29 21:58:36,668 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1525) and extractor EMBEDDED
2012-10-29 21:58:36,670 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1525) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,674 DEBUG [MediaItemDAOImpl] Getting file of media item 1526
2012-10-29 21:58:36,675 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1526) and extractor EMBEDDED
2012-10-29 21:58:36,677 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1526) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,681 DEBUG [MediaItemDAOImpl] Getting file of media item 1527
2012-10-29 21:58:36,682 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1527) and extractor EMBEDDED
2012-10-29 21:58:36,684 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1527) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,687 DEBUG [MediaItemDAOImpl] Getting file of media item 1528
2012-10-29 21:58:36,689 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1528) and extractor EMBEDDED
2012-10-29 21:58:36,691 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1528) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,694 DEBUG [MediaItemDAOImpl] Getting file of media item 1529
2012-10-29 21:58:36,696 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1529) and extractor EMBEDDED
2012-10-29 21:58:36,698 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1529) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,701 DEBUG [MediaItemDAOImpl] Getting file of media item 1530
2012-10-29 21:58:36,703 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1530) and extractor EMBEDDED
2012-10-29 21:58:36,704 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1530) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,708 DEBUG [MediaItemDAOImpl] Getting file of media item 1531
2012-10-29 21:58:36,710 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1531) and extractor EMBEDDED
2012-10-29 21:58:36,712 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1531) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,715 DEBUG [MediaItemDAOImpl] Getting file of media item 1532
2012-10-29 21:58:36,717 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1532) and extractor EMBEDDED
2012-10-29 21:58:36,719 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1532) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,723 DEBUG [MediaItemDAOImpl] Getting file of media item 1533
2012-10-29 21:58:36,724 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1533) and extractor EMBEDDED
2012-10-29 21:58:36,726 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1533) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,730 DEBUG [MediaItemDAOImpl] Getting file of media item 1534
2012-10-29 21:58:36,731 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1534) and extractor EMBEDDED
2012-10-29 21:58:36,733 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1534) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,736 DEBUG [MediaItemDAOImpl] Getting file of media item 1535
2012-10-29 21:58:36,738 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1535) and extractor EMBEDDED
2012-10-29 21:58:36,739 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1535) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,743 DEBUG [MediaItemDAOImpl] Getting file of media item 1536
2012-10-29 21:58:36,744 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1536) and extractor EMBEDDED
2012-10-29 21:58:36,746 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1536) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,750 DEBUG [MediaItemDAOImpl] Getting file of media item 1537
2012-10-29 21:58:36,752 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1537) and extractor EMBEDDED
2012-10-29 21:58:36,754 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1537) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,757 DEBUG [TheMovieDBSourceAdaptor] Found 3 matches
2012-10-29 21:58:36,758 DEBUG [MediaItemDAOImpl] Getting file of media item 1538
2012-10-29 21:58:36,759 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1538) and extractor EMBEDDED
2012-10-29 21:58:36,761 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1538) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,767 DEBUG [MediaItemDAOImpl] Getting file of media item 1539
2012-10-29 21:58:36,769 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1539) and extractor EMBEDDED
2012-10-29 21:58:36,772 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1539) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,776 DEBUG [MediaItemDAOImpl] Getting file of media item 1540
2012-10-29 21:58:36,778 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1540) and extractor EMBEDDED
2012-10-29 21:58:36,781 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1540) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,785 DEBUG [MediaItemDAOImpl] Getting file of media item 1541
2012-10-29 21:58:36,787 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1541) and extractor EMBEDDED
2012-10-29 21:58:36,787 DEBUG [TheMovieDBSourceAdaptor] Found a suitable movie match, id = 57318
2012-10-29 21:58:36,787 DEBUG [TheMovieDBSourceAdaptor] Retrieving details of movie (movieId = 57318, language = en)
2012-10-29 21:58:36,789 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1541) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,791 DEBUG [MediaItemDAOImpl] Getting file of media item 1542
2012-10-29 21:58:36,793 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1542) and extractor EMBEDDED
2012-10-29 21:58:36,795 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1542) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,797 DEBUG [MediaItemDAOImpl] Getting file of media item 1544
2012-10-29 21:58:36,798 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1544) and extractor EMBEDDED
2012-10-29 21:58:36,800 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1544) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,802 DEBUG [MediaItemDAOImpl] Getting file of media item 1545
2012-10-29 21:58:36,804 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1545) and extractor EMBEDDED
2012-10-29 21:58:36,805 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1545) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,808 DEBUG [MediaItemDAOImpl] Getting file of media item 1546
2012-10-29 21:58:36,809 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1546) and extractor EMBEDDED
2012-10-29 21:58:36,811 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1546) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,813 DEBUG [MediaItemDAOImpl] Getting file of media item 1547
2012-10-29 21:58:36,814 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1547) and extractor EMBEDDED
2012-10-29 21:58:36,817 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1547) and extractor COVER_IMAGE_IN_FOLDER
atguilmette
Post Tue Oct 30, 2012 2:16 am
2012-10-29 21:58:36,819 DEBUG [MediaItemDAOImpl] Getting file of media item 1548
2012-10-29 21:58:36,820 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1548) and extractor EMBEDDED
2012-10-29 21:58:36,822 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1548) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,824 DEBUG [MediaItemDAOImpl] Getting file of media item 1549
2012-10-29 21:58:36,826 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1549) and extractor EMBEDDED
2012-10-29 21:58:36,827 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1549) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,832 DEBUG [MediaItemDAOImpl] Getting file of media item 1550
2012-10-29 21:58:36,833 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1550) and extractor EMBEDDED
2012-10-29 21:58:36,835 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1550) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,838 DEBUG [MediaItemDAOImpl] Getting file of media item 1551
2012-10-29 21:58:36,839 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1551) and extractor EMBEDDED
2012-10-29 21:58:36,841 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1551) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,843 DEBUG [MediaItemDAOImpl] Getting file of media item 1552
2012-10-29 21:58:36,844 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1552) and extractor EMBEDDED
2012-10-29 21:58:36,846 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1552) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,848 DEBUG [MediaItemDAOImpl] Getting file of media item 1553
2012-10-29 21:58:36,850 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1553) and extractor EMBEDDED
2012-10-29 21:58:36,852 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1553) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,854 DEBUG [MediaItemDAOImpl] Getting file of media item 1554
2012-10-29 21:58:36,855 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1554) and extractor EMBEDDED
2012-10-29 21:58:36,857 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1554) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,859 DEBUG [MediaItemDAOImpl] Getting file of media item 1555
2012-10-29 21:58:36,861 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1555) and extractor EMBEDDED
2012-10-29 21:58:36,862 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1555) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,865 DEBUG [MediaItemDAOImpl] Getting file of media item 1556
2012-10-29 21:58:36,866 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1556) and extractor EMBEDDED
2012-10-29 21:58:36,868 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1556) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,870 DEBUG [MediaItemDAOImpl] Getting file of media item 1557
2012-10-29 21:58:36,871 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1557) and extractor EMBEDDED
2012-10-29 21:58:36,873 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1557) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,875 DEBUG [MediaItemDAOImpl] Getting file of media item 1558
2012-10-29 21:58:36,877 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1558) and extractor EMBEDDED
2012-10-29 21:58:36,879 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1558) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,881 DEBUG [MediaItemDAOImpl] Getting file of media item 1559
2012-10-29 21:58:36,882 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1559) and extractor EMBEDDED
2012-10-29 21:58:36,884 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1559) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,886 DEBUG [MediaItemDAOImpl] Getting file of media item 1560
2012-10-29 21:58:36,887 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1560) and extractor EMBEDDED
2012-10-29 21:58:36,889 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1560) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,891 DEBUG [MediaItemDAOImpl] Getting file of media item 1561
2012-10-29 21:58:36,893 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1561) and extractor EMBEDDED
2012-10-29 21:58:36,894 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1561) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,896 DEBUG [MediaItemDAOImpl] Getting file of media item 1562
2012-10-29 21:58:36,898 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1562) and extractor EMBEDDED
2012-10-29 21:58:36,900 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1562) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,902 DEBUG [MediaItemDAOImpl] Getting file of media item 1563
2012-10-29 21:58:36,903 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1563) and extractor EMBEDDED
2012-10-29 21:58:36,905 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1563) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,907 DEBUG [MediaItemDAOImpl] Getting file of media item 1564
2012-10-29 21:58:36,908 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1564) and extractor EMBEDDED
2012-10-29 21:58:36,910 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1564) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,912 DEBUG [MediaItemDAOImpl] Getting file of media item 1565
2012-10-29 21:58:36,914 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1565) and extractor EMBEDDED
2012-10-29 21:58:36,916 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1565) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,918 DEBUG [MediaItemDAOImpl] Getting file of media item 1566
2012-10-29 21:58:36,919 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1566) and extractor EMBEDDED
2012-10-29 21:58:36,921 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1566) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,924 DEBUG [MediaItemDAOImpl] Getting file of media item 1567
2012-10-29 21:58:36,925 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1567) and extractor EMBEDDED
2012-10-29 21:58:36,927 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1567) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,929 DEBUG [MediaItemDAOImpl] Getting file of media item 1568
2012-10-29 21:58:36,930 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1568) and extractor EMBEDDED
2012-10-29 21:58:36,932 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1568) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,934 DEBUG [MediaItemDAOImpl] Getting file of media item 1569
2012-10-29 21:58:36,936 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1569) and extractor EMBEDDED
2012-10-29 21:58:36,937 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1569) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,939 DEBUG [MediaItemDAOImpl] Getting file of media item 1570
2012-10-29 21:58:36,941 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1570) and extractor EMBEDDED
2012-10-29 21:58:36,943 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1570) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,945 DEBUG [MediaItemDAOImpl] Getting file of media item 1571
2012-10-29 21:58:36,946 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1571) and extractor EMBEDDED
2012-10-29 21:58:36,948 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1571) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,950 DEBUG [MediaItemDAOImpl] Getting file of media item 1572
2012-10-29 21:58:36,952 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1572) and extractor EMBEDDED
2012-10-29 21:58:36,953 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1572) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,955 DEBUG [MediaItemDAOImpl] Getting file of media item 1573
2012-10-29 21:58:36,956 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1573) and extractor EMBEDDED
2012-10-29 21:58:36,958 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1573) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,960 DEBUG [MediaItemDAOImpl] Getting file of media item 1574
2012-10-29 21:58:36,961 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1574) and extractor EMBEDDED
2012-10-29 21:58:36,963 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1574) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,964 DEBUG [MediaItemDAOImpl] Getting file of media item 1575
2012-10-29 21:58:36,966 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1575) and extractor EMBEDDED
2012-10-29 21:58:36,968 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1575) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,969 DEBUG [MediaItemDAOImpl] Getting file of media item 1576
2012-10-29 21:58:36,971 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1576) and extractor EMBEDDED
2012-10-29 21:58:36,972 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1576) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,974 DEBUG [MediaItemDAOImpl] Getting file of media item 1577
2012-10-29 21:58:36,975 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1577) and extractor EMBEDDED
2012-10-29 21:58:36,977 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1577) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,981 DEBUG [MediaItemDAOImpl] Getting file of media item 1578
2012-10-29 21:58:36,983 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1578) and extractor EMBEDDED
2012-10-29 21:58:36,985 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1578) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,987 DEBUG [MediaItemDAOImpl] Getting file of media item 1579
2012-10-29 21:58:36,989 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1579) and extractor EMBEDDED
2012-10-29 21:58:36,991 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1579) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:36,994 DEBUG [MediaItemDAOImpl] Getting file of media item 1580
2012-10-29 21:58:36,995 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1580) and extractor EMBEDDED
2012-10-29 21:58:36,997 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1580) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,000 DEBUG [MediaItemDAOImpl] Getting file of media item 1581
2012-10-29 21:58:37,001 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1581) and extractor EMBEDDED
2012-10-29 21:58:37,003 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1581) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,006 DEBUG [MediaItemDAOImpl] Getting file of media item 1582
2012-10-29 21:58:37,008 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1582) and extractor EMBEDDED
2012-10-29 21:58:37,012 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1582) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,015 DEBUG [MediaItemDAOImpl] Getting file of media item 1583
2012-10-29 21:58:37,017 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1583) and extractor EMBEDDED
2012-10-29 21:58:37,018 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1583) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,021 DEBUG [MediaItemDAOImpl] Getting file of media item 1584
2012-10-29 21:58:37,023 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1584) and extractor EMBEDDED
2012-10-29 21:58:37,023 DEBUG [LibraryManager] Metadata found via extractor ONLINE_VIDEO_SOURCES: VideoMetadata [title=Action, filePath=null, fileSize=0, audioBitrate=null, audioCodec=null, audioStreamIndex=null, bitrate=null, channels=null, container=null, contentType=MOVIE, coverImage=null, duration=null, episodeNumber=null, fps=null, frequency=null, h264Level=null, h264Profile=null, mkvHeaderCompression=null, ftyp=null, height=null, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=null, videoStreamIndex=null, width=null]
2012-10-29 21:58:37,025 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1584) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,027 DEBUG [MediaItemDAOImpl] Getting file of media item 1585
2012-10-29 21:58:37,029 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1585) and extractor EMBEDDED
2012-10-29 21:58:37,029 DEBUG [VideoService] Adding video into database: Action
2012-10-29 21:58:37,031 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1585) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,033 DEBUG [MediaItemDAOImpl] Getting file of media item 1586
2012-10-29 21:58:37,034 DEBUG [FolderDAOImpl] Looking for folder hierarchy Action
2012-10-29 21:58:37,035 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1586) and extractor EMBEDDED
2012-10-29 21:58:37,037 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1586) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,039 DEBUG [MediaItemDAOImpl] Getting file of media item 1587
2012-10-29 21:58:37,041 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1587) and extractor EMBEDDED
2012-10-29 21:58:37,043 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1587) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,045 DEBUG [MediaItemDAOImpl] Getting file of media item 1588
2012-10-29 21:58:37,047 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1588) and extractor EMBEDDED
2012-10-29 21:58:37,049 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1588) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,051 DEBUG [MediaItemDAOImpl] Getting file of media item 1589
2012-10-29 21:58:37,053 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1589) and extractor EMBEDDED
2012-10-29 21:58:37,054 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1589) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,057 DEBUG [MediaItemDAOImpl] Getting file of media item 1590
2012-10-29 21:58:37,059 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1590) and extractor EMBEDDED
2012-10-29 21:58:37,060 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1590) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,063 DEBUG [MediaItemDAOImpl] Getting file of media item 1591
2012-10-29 21:58:37,065 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1591) and extractor EMBEDDED
2012-10-29 21:58:37,067 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1591) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,068 DEBUG [GenreDAOImpl] Reading a Genre (name = Unknown)
2012-10-29 21:58:37,069 DEBUG [MediaItemDAOImpl] Getting file of media item 1592
2012-10-29 21:58:37,071 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1592) and extractor EMBEDDED
2012-10-29 21:58:37,073 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1592) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,075 DEBUG [MediaItemDAOImpl] Getting file of media item 1593
2012-10-29 21:58:37,077 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1593) and extractor EMBEDDED
2012-10-29 21:58:37,078 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1593) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,081 DEBUG [MediaItemDAOImpl] Getting file of media item 1594
2012-10-29 21:58:37,083 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1594) and extractor EMBEDDED
2012-10-29 21:58:37,084 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1594) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,086 DEBUG [GenreService] Genre Unknown found
2012-10-29 21:58:37,087 DEBUG [MediaItemDAOImpl] Getting file of media item 1595
2012-10-29 21:58:37,088 DEBUG [CoverImageService] Resizing and storing cover art image
2012-10-29 21:58:37,088 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1595) and extractor EMBEDDED
2012-10-29 21:58:37,090 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1595) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,091 DEBUG [ImageUtils] Starting image resize, size = 42010 bytes
2012-10-29 21:58:37,093 DEBUG [MediaItemDAOImpl] Getting file of media item 1596
2012-10-29 21:58:37,094 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1596) and extractor EMBEDDED
2012-10-29 21:58:37,096 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1596) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,099 DEBUG [MediaItemDAOImpl] Getting file of media item 1597
2012-10-29 21:58:37,100 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1597) and extractor EMBEDDED
2012-10-29 21:58:37,102 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1597) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,318 DEBUG [MediaItemDAOImpl] Getting file of media item 1598
2012-10-29 21:58:37,320 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1598) and extractor EMBEDDED
2012-10-29 21:58:37,322 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1598) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,325 DEBUG [MediaItemDAOImpl] Getting file of media item 1599
2012-10-29 21:58:37,326 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1599) and extractor EMBEDDED
2012-10-29 21:58:37,328 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1599) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,331 DEBUG [MediaItemDAOImpl] Getting file of media item 1600
2012-10-29 21:58:37,332 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1600) and extractor EMBEDDED
2012-10-29 21:58:37,334 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1600) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,337 DEBUG [MediaItemDAOImpl] Getting file of media item 1601
2012-10-29 21:58:37,339 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1601) and extractor EMBEDDED
2012-10-29 21:58:37,340 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1601) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,343 DEBUG [MediaItemDAOImpl] Getting file of media item 1602
2012-10-29 21:58:37,345 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1602) and extractor EMBEDDED
2012-10-29 21:58:37,346 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1602) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,349 DEBUG [MediaItemDAOImpl] Getting file of media item 1603
2012-10-29 21:58:37,351 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1603) and extractor EMBEDDED
2012-10-29 21:58:37,353 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1603) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,356 DEBUG [MediaItemDAOImpl] Getting file of media item 1604
2012-10-29 21:58:37,358 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1604) and extractor EMBEDDED
2012-10-29 21:58:37,360 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1604) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,559 DEBUG [MediaItemDAOImpl] Getting file of media item 1605
2012-10-29 21:58:37,561 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1605) and extractor EMBEDDED
2012-10-29 21:58:37,564 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1605) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,567 DEBUG [MediaItemDAOImpl] Getting file of media item 1606
2012-10-29 21:58:37,569 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1606) and extractor EMBEDDED
2012-10-29 21:58:37,571 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1606) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,575 DEBUG [MediaItemDAOImpl] Getting file of media item 1607
2012-10-29 21:58:37,576 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1607) and extractor EMBEDDED
2012-10-29 21:58:37,579 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1607) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,582 DEBUG [MediaItemDAOImpl] Getting file of media item 1608
2012-10-29 21:58:37,584 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1608) and extractor EMBEDDED
2012-10-29 21:58:37,586 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1608) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,590 DEBUG [MediaItemDAOImpl] Getting file of media item 1609
2012-10-29 21:58:37,592 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1609) and extractor EMBEDDED
2012-10-29 21:58:37,594 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1609) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,597 DEBUG [MediaItemDAOImpl] Getting file of media item 1610
2012-10-29 21:58:37,599 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1610) and extractor EMBEDDED
2012-10-29 21:58:37,601 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1610) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,604 DEBUG [MediaItemDAOImpl] Getting file of media item 1611
2012-10-29 21:58:37,606 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1611) and extractor EMBEDDED
2012-10-29 21:58:37,608 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1611) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,612 DEBUG [MediaItemDAOImpl] Getting file of media item 1612
2012-10-29 21:58:37,614 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1612) and extractor EMBEDDED
2012-10-29 21:58:37,616 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1612) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,620 DEBUG [MediaItemDAOImpl] Getting file of media item 1613
2012-10-29 21:58:37,622 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1613) and extractor EMBEDDED
2012-10-29 21:58:37,624 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1613) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,627 DEBUG [MediaItemDAOImpl] Getting file of media item 1614
2012-10-29 21:58:37,629 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1614) and extractor EMBEDDED
2012-10-29 21:58:37,630 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1614) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,633 DEBUG [MediaItemDAOImpl] Getting file of media item 1615
2012-10-29 21:58:37,635 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1615) and extractor EMBEDDED
2012-10-29 21:58:37,636 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1615) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,639 DEBUG [MediaItemDAOImpl] Getting file of media item 1616
2012-10-29 21:58:37,640 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1616) and extractor EMBEDDED
2012-10-29 21:58:37,642 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1616) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,645 DEBUG [MediaItemDAOImpl] Getting file of media item 1617
2012-10-29 21:58:37,646 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1617) and extractor EMBEDDED
2012-10-29 21:58:37,648 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1617) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,651 DEBUG [MediaItemDAOImpl] Getting file of media item 1618
2012-10-29 21:58:37,652 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1618) and extractor EMBEDDED
2012-10-29 21:58:37,654 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1618) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,657 DEBUG [MediaItemDAOImpl] Getting file of media item 1619
2012-10-29 21:58:37,658 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1619) and extractor EMBEDDED
2012-10-29 21:58:37,660 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1619) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,665 DEBUG [MediaItemDAOImpl] Getting file of media item 1620
2012-10-29 21:58:37,666 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1620) and extractor EMBEDDED
2012-10-29 21:58:37,668 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1620) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,671 DEBUG [MediaItemDAOImpl] Getting file of media item 1621
2012-10-29 21:58:37,672 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1621) and extractor EMBEDDED
2012-10-29 21:58:37,674 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1621) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,677 DEBUG [MediaItemDAOImpl] Getting file of media item 1622
2012-10-29 21:58:37,678 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1622) and extractor EMBEDDED
2012-10-29 21:58:37,680 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1622) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,683 DEBUG [MediaItemDAOImpl] Getting file of media item 1623
2012-10-29 21:58:37,684 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1623) and extractor EMBEDDED
2012-10-29 21:58:37,686 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1623) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,689 DEBUG [MediaItemDAOImpl] Getting file of media item 1624
2012-10-29 21:58:37,690 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1624) and extractor EMBEDDED
2012-10-29 21:58:37,692 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1624) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,694 DEBUG [MediaItemDAOImpl] Getting file of media item 1625
2012-10-29 21:58:37,696 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1625) and extractor EMBEDDED
2012-10-29 21:58:37,698 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1625) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,700 DEBUG [MediaItemDAOImpl] Getting file of media item 1626
2012-10-29 21:58:37,702 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1626) and extractor EMBEDDED
2012-10-29 21:58:37,704 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1626) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,707 DEBUG [MediaItemDAOImpl] Getting file of media item 1627
2012-10-29 21:58:37,708 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1627) and extractor EMBEDDED
2012-10-29 21:58:37,710 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1627) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,713 DEBUG [MediaItemDAOImpl] Getting file of media item 1628
2012-10-29 21:58:37,714 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1628) and extractor EMBEDDED
2012-10-29 21:58:37,716 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1628) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,719 DEBUG [MediaItemDAOImpl] Getting file of media item 1629
2012-10-29 21:58:37,721 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1629) and extractor EMBEDDED
2012-10-29 21:58:37,722 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1629) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,725 DEBUG [MediaItemDAOImpl] Getting file of media item 1630
2012-10-29 21:58:37,727 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1630) and extractor EMBEDDED
2012-10-29 21:58:37,728 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1630) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,731 DEBUG [MediaItemDAOImpl] Getting file of media item 1631
2012-10-29 21:58:37,732 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1631) and extractor EMBEDDED
2012-10-29 21:58:37,734 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1631) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,736 DEBUG [MediaItemDAOImpl] Getting file of media item 1632
2012-10-29 21:58:37,737 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1632) and extractor EMBEDDED
2012-10-29 21:58:37,739 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1632) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,741 DEBUG [MediaItemDAOImpl] Getting file of media item 1633
2012-10-29 21:58:37,742 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1633) and extractor EMBEDDED
2012-10-29 21:58:37,744 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1633) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,746 DEBUG [MediaItemDAOImpl] Getting file of media item 1634
2012-10-29 21:58:37,748 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1634) and extractor EMBEDDED
2012-10-29 21:58:37,749 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1634) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,751 DEBUG [MediaItemDAOImpl] Getting file of media item 1635
2012-10-29 21:58:37,753 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1635) and extractor EMBEDDED
2012-10-29 21:58:37,755 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1635) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,757 DEBUG [MediaItemDAOImpl] Getting file of media item 1636
2012-10-29 21:58:37,758 DEBUG [ImageUtils] Returning resized image, size = 1854 bytes
2012-10-29 21:58:37,758 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1636) and extractor EMBEDDED
2012-10-29 21:58:37,759 DEBUG [CoverImageService] Image successfully resized
2012-10-29 21:58:37,761 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1636) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,762 DEBUG [CoverImageDAOImpl] Creating a new ImageCover (length = 1854)
2012-10-29 21:58:37,763 DEBUG [MediaItemDAOImpl] Getting file of media item 1637
2012-10-29 21:58:37,764 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1637) and extractor EMBEDDED
2012-10-29 21:58:37,766 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1637) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,768 DEBUG [MediaItemDAOImpl] Getting file of media item 1638
2012-10-29 21:58:37,770 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1638) and extractor EMBEDDED
2012-10-29 21:58:37,772 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1638) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,774 DEBUG [MediaItemDAOImpl] Getting file of media item 1639
2012-10-29 21:58:37,776 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1639) and extractor EMBEDDED
2012-10-29 21:58:37,778 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1639) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,780 DEBUG [MediaItemDAOImpl] Getting file of media item 1640
2012-10-29 21:58:37,782 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1640) and extractor EMBEDDED
2012-10-29 21:58:37,784 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1640) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,787 DEBUG [MediaItemDAOImpl] Getting file of media item 1641
2012-10-29 21:58:37,789 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1641) and extractor EMBEDDED
2012-10-29 21:58:37,791 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1641) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,796 DEBUG [MediaItemDAOImpl] Getting file of media item 1642
2012-10-29 21:58:37,798 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1642) and extractor EMBEDDED
2012-10-29 21:58:37,800 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1642) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,802 DEBUG [MediaItemDAOImpl] Getting file of media item 1643
2012-10-29 21:58:37,804 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1643) and extractor EMBEDDED
2012-10-29 21:58:37,806 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1643) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,808 DEBUG [MediaItemDAOImpl] Getting file of media item 1644
2012-10-29 21:58:37,818 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1644) and extractor EMBEDDED
2012-10-29 21:58:37,821 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1644) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,823 DEBUG [MediaItemDAOImpl] Getting file of media item 1645
2012-10-29 21:58:37,825 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1645) and extractor EMBEDDED
2012-10-29 21:58:37,827 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1645) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,829 DEBUG [MediaItemDAOImpl] Getting file of media item 1646
2012-10-29 21:58:37,831 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1646) and extractor EMBEDDED
2012-10-29 21:58:37,833 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1646) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,835 DEBUG [MediaItemDAOImpl] Getting file of media item 1647
2012-10-29 21:58:37,836 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1647) and extractor EMBEDDED
2012-10-29 21:58:37,838 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1647) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,840 DEBUG [MediaItemDAOImpl] Getting file of media item 1648
2012-10-29 21:58:37,842 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1648) and extractor EMBEDDED
2012-10-29 21:58:37,844 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1648) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,846 DEBUG [MediaItemDAOImpl] Getting file of media item 1649
2012-10-29 21:58:37,847 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1649) and extractor EMBEDDED
2012-10-29 21:58:37,849 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1649) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,851 DEBUG [MediaItemDAOImpl] Getting file of media item 1650
2012-10-29 21:58:37,852 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1650) and extractor EMBEDDED
2012-10-29 21:58:37,854 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1650) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,856 DEBUG [MediaItemDAOImpl] Getting file of media item 1651
2012-10-29 21:58:37,857 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1651) and extractor EMBEDDED
2012-10-29 21:58:37,859 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1651) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,867 DEBUG [MediaItemDAOImpl] Getting file of media item 1652
2012-10-29 21:58:37,870 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1652) and extractor EMBEDDED
2012-10-29 21:58:37,872 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1652) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,874 DEBUG [MediaItemDAOImpl] Getting file of media item 1653
2012-10-29 21:58:37,876 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1653) and extractor EMBEDDED
2012-10-29 21:58:37,877 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1653) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,880 DEBUG [MediaItemDAOImpl] Getting file of media item 1654
2012-10-29 21:58:37,881 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1654) and extractor EMBEDDED
2012-10-29 21:58:37,883 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1654) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,885 DEBUG [MediaItemDAOImpl] Getting file of media item 1655
2012-10-29 21:58:37,886 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1655) and extractor EMBEDDED
2012-10-29 21:58:37,888 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1655) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,890 DEBUG [MediaItemDAOImpl] Getting file of media item 1656
2012-10-29 21:58:37,891 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1656) and extractor EMBEDDED
2012-10-29 21:58:37,893 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1656) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,895 DEBUG [MediaItemDAOImpl] Getting file of media item 1657
2012-10-29 21:58:37,896 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1657) and extractor EMBEDDED
2012-10-29 21:58:37,898 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1657) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,900 DEBUG [MediaItemDAOImpl] Getting file of media item 1658
2012-10-29 21:58:37,901 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1658) and extractor EMBEDDED
2012-10-29 21:58:37,903 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1658) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,905 DEBUG [MediaItemDAOImpl] Getting file of media item 1659
2012-10-29 21:58:37,907 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1659) and extractor EMBEDDED
2012-10-29 21:58:37,908 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1659) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,910 DEBUG [MediaItemDAOImpl] Getting file of media item 1660
2012-10-29 21:58:37,914 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1660) and extractor EMBEDDED
2012-10-29 21:58:37,914 DEBUG [VideoDAOImpl] Creating a new Video (title = Action)
2012-10-29 21:58:37,916 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1660) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,918 DEBUG [MediaItemDAOImpl] Getting file of media item 1661
2012-10-29 21:58:37,919 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1661) and extractor EMBEDDED
2012-10-29 21:58:37,921 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1661) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,923 DEBUG [MediaItemDAOImpl] Getting file of media item 1662
2012-10-29 21:58:37,925 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1662) and extractor EMBEDDED
2012-10-29 21:58:37,927 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1662) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,929 DEBUG [MediaItemDAOImpl] Getting file of media item 1663
2012-10-29 21:58:37,930 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1663) and extractor EMBEDDED
2012-10-29 21:58:37,932 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1663) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,934 DEBUG [MediaItemDAOImpl] Getting file of media item 1664
2012-10-29 21:58:37,936 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1664) and extractor EMBEDDED
2012-10-29 21:58:37,938 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1664) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,940 DEBUG [MediaItemDAOImpl] Getting file of media item 1665
2012-10-29 21:58:37,942 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1665) and extractor EMBEDDED
2012-10-29 21:58:37,944 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1665) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,950 DEBUG [MediaItemDAOImpl] Getting file of media item 1666
2012-10-29 21:58:37,952 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1666) and extractor EMBEDDED
2012-10-29 21:58:37,954 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1666) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,958 DEBUG [MediaItemDAOImpl] Getting file of media item 1667
2012-10-29 21:58:37,959 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1667) and extractor EMBEDDED
2012-10-29 21:58:37,961 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1667) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,965 DEBUG [MediaItemDAOImpl] Getting file of media item 1668
2012-10-29 21:58:37,966 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1668) and extractor EMBEDDED
2012-10-29 21:58:37,968 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1668) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,972 DEBUG [MediaItemDAOImpl] Getting file of media item 1669
2012-10-29 21:58:37,973 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1669) and extractor EMBEDDED
2012-10-29 21:58:37,975 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1669) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,978 DEBUG [MediaItemDAOImpl] Getting file of media item 1670
2012-10-29 21:58:37,980 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1670) and extractor EMBEDDED
2012-10-29 21:58:37,982 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1670) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,985 DEBUG [MediaItemDAOImpl] Getting file of media item 1671
2012-10-29 21:58:37,988 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1671) and extractor EMBEDDED
2012-10-29 21:58:37,990 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1671) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:37,993 DEBUG [MediaItemDAOImpl] Getting file of media item 1672
2012-10-29 21:58:37,995 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1672) and extractor EMBEDDED
2012-10-29 21:58:37,997 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1672) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,001 DEBUG [MediaItemDAOImpl] Getting file of media item 1673
2012-10-29 21:58:38,002 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1673) and extractor EMBEDDED
2012-10-29 21:58:38,004 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1673) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,004 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 1889 as DIRECTOR
2012-10-29 21:58:38,004 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2012-10-29 21:58:38,008 DEBUG [MediaItemDAOImpl] Getting file of media item 1674
2012-10-29 21:58:38,010 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1674) and extractor EMBEDDED
2012-10-29 21:58:38,012 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1674) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,015 DEBUG [MediaItemDAOImpl] Getting file of media item 1675
2012-10-29 21:58:38,017 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1675) and extractor EMBEDDED
2012-10-29 21:58:38,019 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1675) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,023 DEBUG [MediaItemDAOImpl] Getting file of media item 1678
2012-10-29 21:58:38,025 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1678) and extractor EMBEDDED
2012-10-29 21:58:38,027 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1678) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,032 DEBUG [MediaItemDAOImpl] Getting file of media item 1679
2012-10-29 21:58:38,032 DEBUG [PersonDAOImpl] Checking if person 17567 has a role DIRECTOR for media item 1889
2012-10-29 21:58:38,033 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1679) and extractor EMBEDDED
2012-10-29 21:58:38,036 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1679) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,041 DEBUG [MediaItemDAOImpl] Getting file of media item 1680
2012-10-29 21:58:38,043 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1680) and extractor EMBEDDED
2012-10-29 21:58:38,045 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1680) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,049 DEBUG [MediaItemDAOImpl] Getting file of media item 1681
2012-10-29 21:58:38,059 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1681) and extractor EMBEDDED
2012-10-29 21:58:38,062 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1681) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,066 DEBUG [MediaItemDAOImpl] Getting file of media item 1682
2012-10-29 21:58:38,068 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1682) and extractor EMBEDDED
2012-10-29 21:58:38,070 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1682) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,074 DEBUG [MediaItemDAOImpl] Getting file of media item 1683
2012-10-29 21:58:38,075 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1683) and extractor EMBEDDED
2012-10-29 21:58:38,077 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1683) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,081 DEBUG [MediaItemDAOImpl] Getting file of media item 1684
2012-10-29 21:58:38,084 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1684) and extractor EMBEDDED
2012-10-29 21:58:38,086 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1684) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,090 DEBUG [MediaItemDAOImpl] Getting file of media item 1685
2012-10-29 21:58:38,091 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1685) and extractor EMBEDDED
2012-10-29 21:58:38,093 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1685) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,096 DEBUG [MediaItemDAOImpl] Getting file of media item 1686
2012-10-29 21:58:38,098 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1686) and extractor EMBEDDED
2012-10-29 21:58:38,100 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1686) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,103 DEBUG [MediaItemDAOImpl] Getting file of media item 1687
2012-10-29 21:58:38,105 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1687) and extractor EMBEDDED
2012-10-29 21:58:38,107 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1687) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,110 DEBUG [MediaItemDAOImpl] Getting file of media item 1688
2012-10-29 21:58:38,111 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1688) and extractor EMBEDDED
2012-10-29 21:58:38,113 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1688) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,117 DEBUG [MediaItemDAOImpl] Getting file of media item 1689
2012-10-29 21:58:38,118 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1689) and extractor EMBEDDED
2012-10-29 21:58:38,120 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 1889 as PRODUCER
2012-10-29 21:58:38,120 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1689) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,120 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2012-10-29 21:58:38,122 DEBUG [PersonDAOImpl] Checking if person 17567 has a role PRODUCER for media item 1889
2012-10-29 21:58:38,124 DEBUG [MediaItemDAOImpl] Getting file of media item 1690
2012-10-29 21:58:38,126 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1690) and extractor EMBEDDED
2012-10-29 21:58:38,128 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1690) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,131 DEBUG [MediaItemDAOImpl] Getting file of media item 1691
2012-10-29 21:58:38,132 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 1889 as ACTOR
2012-10-29 21:58:38,132 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2012-10-29 21:58:38,133 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1691) and extractor EMBEDDED
2012-10-29 21:58:38,133 DEBUG [PersonDAOImpl] Checking if person 17567 has a role ACTOR for media item 1889
2012-10-29 21:58:38,135 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1691) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,138 DEBUG [MediaItemDAOImpl] Getting file of media item 1692
2012-10-29 21:58:38,140 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1692) and extractor EMBEDDED
2012-10-29 21:58:38,142 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1692) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,143 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = ONLINE_VIDEO_SOURCES, mediaItemId = 1889)
2012-10-29 21:58:38,146 DEBUG [MediaItemDAOImpl] Getting file of media item 1693
2012-10-29 21:58:38,147 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1693) and extractor EMBEDDED
2012-10-29 21:58:38,149 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1693) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,153 DEBUG [MediaItemDAOImpl] Getting file of media item 1694
2012-10-29 21:58:38,154 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1694) and extractor EMBEDDED
2012-10-29 21:58:38,156 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1694) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,161 DEBUG [MediaItemDAOImpl] Getting file of media item 1695
2012-10-29 21:58:38,163 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1695) and extractor EMBEDDED
2012-10-29 21:58:38,163 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 1889)
2012-10-29 21:58:38,164 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1695) and extractor COVER_IMAGE_IN_FOLDER
2012-10-29 21:58:38,168 DEBUG [MediaItemDAOImpl] Getting file of media item 1696
2012-10-29 21:58:38,169 INFO [LibraryAdditionsCheckerThread] Added file 'Captain America The First Avenger (2011).mkv' (title: Action) to Library
If I look at the header of the file in mkvmerge GUI, I can see that it has a title of "Captain America: The First Avenger."
Post Tue Oct 30, 2012 10:37 am
Re: Any way to force a movie to be identified?
Ok, I know what's happening. Serviio uses both, the file name and folder name (Action) for the search. If an exact match can be found, it's used with the highest priority, otherwise file name has priority.
There is a dodgy record in the database (http://www.themoviedb.org/movie/57318) with name Action, which is picked up instead of the movie metadata. I reported this record, but before it's removed, you could fix it by renaming the folder (e.g. to Action movies).
Users browsing this forum: Baidu [Spider] and 32 guests
