Setting Permissions on Ubuntu 12.10
eekfonky
Post Mon Oct 22, 2012 1:13 pm
Hello
After upgrading to Ubuntu 12.10 I seem to be getting "Temporarily cannot access the server. Please retry"
I have been informed it may be a permissions issue? Problem is I don't know what that is or how to solve it? Am I running as root? don't know?
Please help a newbie
Post Mon Oct 22, 2012 1:41 pm
Re: Setting Permissions on Ubuntu 12.10
-- topic moved to general support&help ---
Could you enable detailed logging an post log here ? (see signatures links)
eekfonky
Post Mon Oct 22, 2012 2:04 pm
If you can explain how I'd be more than happy to do so.
Post Mon Oct 22, 2012 3:37 pm
I'm not an Ubuntu user, but for windows, you can look at my signature links. http://wiki.serviio.org/doku.php?id=detail_logging
michael
Post Wed Oct 24, 2012 4:35 am
I believe I may have the same problem. I can get it to work for 2 minutes and 30 seconds(ish) and then playback stops. The device no longer sees my Serviio. I am using a few WD Live devices for playback. Both of them stop at the same instant.
What's weird as the Xbox 360 still works just fine. The file is being re-encoded with the Xbox, but I believe the WD Live is just receiving the raw stream. The WD Live devices are the only devices I really use with Serviio because it supports more functionality than my TVs or the Xbox.
Here is an excerpt from my log file with one file playing:
https://www.dropbox.com/s/f8m2kaii0ws8z90/serviio.log.txt
The device quits playback at the same time this line is logged:
serviio.log:2012-10-23 20:37:03,561 DEBUG [WebServer] I/O error: Broken pipe
My syslog shows nothing during the time frame. Everything is hard wired gigabit. This worked great prior to upgrading to Ubuntu 12.10. I can't really downgrade or reinstall. I'd be happy to help debug this issue. Is anyone else having issues with the WDTV Live after upgrading to Ubuntu 12.10?
Linux vegas 3.5.0-17-generic #28-Ubuntu SMP Tue Oct 9 19:31:23 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
Any help is appreciated.
Thank you,
Michael
eekfonky
Post Thu Nov 08, 2012 7:57 am
*Bump* anyone able to help me? The 'Temporailily cannot access server' is driving me crazy!!! I'm a Pro user if that helps?
Post Thu Nov 08, 2012 10:19 am
eekfonky wrote:I can get it to work for 2 minutes and 30 seconds(ish) and then playback stops. The device no longer sees my Serviio?
Is it always at the same time ?
If yes, it's something weird with your source file.
Could you check the video bitrate of your source at this time-point ? (A windows tool : http://wiki.serviio.org/doku.php?id=vbitrate )
eekfonky
Post Mon Nov 12, 2012 12:38 pm
Sorry but I didn't write that is was 'michael'
Still no response to my permissions issue. I will try to contact the makers instead
Post Mon Nov 12, 2012 5:00 pm
No, it won't be access rights. DOes this happen whenever you access the server or only after some time?
eekfonky
Post Mon Nov 12, 2012 5:04 pm
It happens whenever I try to access the server for all online content and some media files
Sent from my GT-I9100P using Tapatalk 2
Post Mon Nov 12, 2012 5:20 pm
@Michael:
your logs shows the server advertises on these 4 NICs:
2012-10-23 20:36:13,078 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface br0 (br0) and address 172.16.1.10, timeout = 0
2012-10-23 20:36:13,079 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7305fe9e-fc44-3b9a-a6fe-394be9c5fea3
2012-10-23 20:36:14,882 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface ham0 (ham0) and address 5.23.156.244, timeout = 0
2012-10-23 20:36:14,883 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7305fe9e-fc44-3b9a-a6fe-394be9c5fea3
2012-10-23 20:36:16,686 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface vmnet1 (vmnet1) and address 172.16.113.1, timeout = 0
2012-10-23 20:36:16,687 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 7305fe9e-fc44-3b9a-a6fe-394be9c5fea3
2012-10-23 20:36:18,491 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface vmnet8 (vmnet8) and address 192.168.15.1, timeout = 0
Do you run Serviio on one of them? If not, can you run this and post the results? viewtopic.php?f=3&t=3923&hilit=ListNic#p26629
Users browsing this forum: Google [Bot] and 34 guests
