Transcode is too fast/skips, like pressing fast forward
hard5ter
Post Tue Nov 20, 2012 8:27 pm
file i am trying to play is going too fast for a few seconds, like playing fast forward briefly..
its a web DL, DD5.1 i says..
any help editing my profile is appreciated to make it run correctly.
samsung B series. le40b650
Windows 8
Latest 64 bit FFmpeg
P>S log says sony bravia, i have previously used other profiles to get troublesome files playing,
it does same on every profile.
FFmpeg details
ffmpeg version N-46469-gc995644 Copyright (c) 2000-2012 the FFmpeg developers
built on Nov 5 2012 17:58:15 with gcc 4.7.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runt
ime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass -
-enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enab
le-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-libo
pus --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo
ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena
ble-zlib
libavutil 52. 5.100 / 52. 5.100
libavcodec 54. 71.100 / 54. 71.100
libavformat 54. 36.100 / 54. 36.100
libavdevice 54. 3.100 / 54. 3.100
libavfilter 3. 21.106 / 3. 21.106
libswscale 2. 1.102 / 2. 1.102
libswresample 0. 16.100 / 0. 16.100
libpostproc 52. 1.100 / 52. 1.100
Input #0, matroska,webm, from 'C:\mf08.mkv':
creation_time : 2012-11-15 15:04:56
Duration: 00:21:38.14, start: 0.000000, bitrate: 4556 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x718 [SAR 1:1 DAR 640:359
], 23.98 fps, 23.98 tbr, 1k tbn, 2k tbc (default)
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
C:\Program Files\Serviio\lib>
and a detailed log.
2012-11-20 19:48:55,052 DEBUG [ResourceDeliveryProcessor] Request for resource 519 and type 'MEDIA_ITEM' received
2012-11-20 19:48:55,052 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 519 (local)
2012-11-20 19:48:55,052 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 519)
2012-11-20 19:48:55,052 DEBUG [VideoDAOImpl] Reading a Video (id = 519)
2012-11-20 19:48:55,053 DEBUG [VideoDeliveryEngine] Delivering item '519' for client 'IPAddress=/192.168.0.3, Profile=Sony Bravia TV (2012)'
2012-11-20 19:48:55,053 DEBUG [VideoDeliveryEngine] Delivering file 'mf08.mkv' using transcoding
2012-11-20 19:48:55,053 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.0.3, Profile=Sony Bravia TV (2012)'
2012-11-20 19:48:55,053 DEBUG [MediaItemDAOImpl] Getting file of media item 519
2012-11-20 19:48:55,054 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\TempShit\binz\Modern Family S04E08\mf08.mkv
2012-11-20 19:48:55,054 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i C:\TempShit\binz\Modern Family S04E08\mf08.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-519-sony2012-ORIGINAL.stf
2012-11-20 19:48:55,554 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-11-20 19:48:55,554 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mf08.mkv: AVC_TS_MP_HD_AC3_ISO
2012-11-20 19:48:55,554 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 519) as read
2012-11-20 19:48:55,555 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-20 19:48:55,555 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-11-20 19:48:55,555 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-20 19:48:55,555 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-1298.0/1298,Content-Length: 50000000000,Date: Tue, 20 Nov 2012 19:48:55 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-11-20 19:48:55,928 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-20 19:48:56,329 DEBUG [WebServer] Incoming connection from /192.168.0.3:1959
2012-11-20 19:48:56,329 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.3
2012-11-20 19:48:56,329 DEBUG [ResourceTransportRequestHandler] HEAD /resource/519/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.6:8895]]
2012-11-20 19:48:56,329 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.3, Profile=Sony Bravia TV (2012)'
2012-11-20 19:48:56,330 DEBUG [ResourceDeliveryProcessor] Request for resource 519 and type 'MEDIA_ITEM' received
2012-11-20 19:48:56,330 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 519 (local)
2012-11-20 19:48:56,330 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 519)
2012-11-20 19:48:56,330 DEBUG [VideoDAOImpl] Reading a Video (id = 519)
2012-11-20 19:48:56,330 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 519, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2012-11-20 19:48:56,330 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mf08.mkv
2012-11-20 19:48:56,330 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mf08.mkv: AVC_TS_MP_HD_AC3_ISO
2012-11-20 19:48:56,330 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-11-20 19:48:56,331 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Tue, 20 Nov 2012 19:48:56 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-11-20 19:48:56,344 DEBUG [WebServer] Incoming connection from /192.168.0.3:4727
2012-11-20 19:48:56,345 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.3
2012-11-20 19:48:56,345 DEBUG [ResourceTransportRequestHandler] GET /resource/519/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.0.6:8895]]
2012-11-20 19:48:56,345 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.0.3, Profile=Sony Bravia TV (2012)'
2012-11-20 19:48:56,345 DEBUG [ResourceDeliveryProcessor] Request for resource 519 and type 'MEDIA_ITEM' received
2012-11-20 19:48:56,345 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 519 (local)
2012-11-20 19:48:56,345 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 519)
2012-11-20 19:48:56,346 DEBUG [VideoDAOImpl] Reading a Video (id = 519)
2012-11-20 19:48:56,346 DEBUG [VideoDeliveryEngine] Delivering item '519' for client 'IPAddress=/192.168.0.3, Profile=Sony Bravia TV (2012)'
2012-11-20 19:48:56,346 DEBUG [VideoDeliveryEngine] Delivering file 'mf08.mkv' using transcoding
2012-11-20 19:48:56,346 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.3, Profile=Sony Bravia TV (2012)'
2012-11-20 19:48:56,439 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-11-20 19:48:56,439 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mf08.mkv: AVC_TS_MP_HD_AC3_ISO
2012-11-20 19:48:56,440 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 519) as read
2012-11-20 19:48:56,455 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-20 19:48:56,456 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-11-20 19:48:56,456 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-20 19:48:56,456 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-1298.0/1298,Content-Length: 50000000000,Date: Tue, 20 Nov 2012 19:48:56 GMT,Server: Windows NT (unknown), UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-11-20 19:49:04,239 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
Post Wed Nov 21, 2012 4:06 pm
Re: Transcode is too fast/skips
If you use Samsung B profile it won't transcode the file, most likely.
hard5ter
Post Wed Nov 21, 2012 6:00 pm
sorry should have mentioned,
ive turned transcoding off and on, tried every profile,
same results.
does not play via usb also, unsupported video data. same with turning transcoding off
thing is, other transcodes dont have this issue.
it speeds up and down..
this has exact same issue too..
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 42mn 3s
Bit rate : 4 932 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.099
Stream size : 1.45 GiB (91%)
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 42mn 3s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 116 MiB (7%)
Language : English
Default : Yes
Forced : No
Post Thu Nov 22, 2012 5:03 pm
Re: Transcode is too fast/skips, like pressing fast forward
are you running the latest TV firmware?
Users browsing this forum: Google [Bot] and 69 guests
