Streaming no longer works. Worked a few weeks ago
wdprocks
Post Sat Nov 24, 2012 8:52 pm
I have had about 4 or 5 You Tube video's setup in Serviio and they have been streaming to my Panasonic Viera TV for 8-12 months. A few weeks ago, I tried to watch one and it would not work. I tried all of my saved Presets (that have worked for months) and none of them now work. I get a message about Unsupported Format. The URL I am using has not changed on any of the saved video's since the last time they worked. I even tried adding a new one as a test (http://gdata.youtube.com/feeds/api/vide ... ppbrYIcR80). The Preset name shows up on my TV but not the video itself. Typically, when I go into a saved Preset like this, I see a Thumbnail type of picture of the video. On the Presets I have had stored (and in use) for months, the video Thumbnail is still in place but I get the Unsupported Format error. On any new video's I add, the Thumbnail video does not show up. I even tried installing the latest version of Serviio today. The install was successfull. Shortly after the install, my computer wanted to do a JAVA update which I thought might be related and I allowed this install to occur as well. None of these actions solved this problem. Can anyone help? Thank you much
npuser
Post Sat Nov 24, 2012 8:56 pm
Re: Streaming no longer works. Worked a few weeks ago
Make sure u have updated version of YouTube plugin - http://forum.serviio.org/viewtopic.php?f=20&t=3276
Npuser
Users browsing this forum: No registered users and 49 guests
