Problem updating library 1.0.1
jhow
Post Mon Aug 13, 2012 3:05 am
Hello, I`ve upgraded my 0.62 version to the new one and now I am having problems updating my library.
I did the same thing I did on the 0.62 version but when I click on force refresh it starts checking but the green light stays on forever and only 2 video files appear (instead of the many I have). Then when I click on force refresh again, the console freezes...
What can I do to solve the problem?
Post Mon Aug 13, 2012 5:59 pm
Re: Problem updating library 1.0.1
the upgrade will remove and add again all your files so it may take a while. Check the log file for a list of added files.
jhow
Post Tue Aug 14, 2012 12:13 am
Ok, so i tested here and it looks like some videos when scanned are making serviio freeze.
Here's the log:
2012-08-13 21:06:02,867 DEBUG [ActionsServerResource] Action with name 'forceLibraryRefresh' was requested
2012-08-13 21:06:02,868 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-13 21:06:02,868 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-08-13 21:06:02,869 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-13 21:06:02,869 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-08-13 21:06:02,871 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: C:\Users\Daniel\Desktop\Anime
2012-08-13 21:06:02,872 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 1)
2012-08-13 21:06:02,923 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: C:\Users\Daniel\Desktop\Anime
2012-08-13 21:06:02,925 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2012-08-13 21:06:03,037 DEBUG [MediaItemDAOImpl] Getting file of media item 66
2012-08-13 21:06:03,057 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Users\Daniel\Desktop\Anime
2012-08-13 21:06:03,058 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ah_Megami_Sama_01_AnimeFuture_Animax-Anbient.mkv', checking if it's already in the Library
2012-08-13 21:06:03,059 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ah_Megami_Sama_01_AnimeFuture_Animax-Anbient.mkv
2012-08-13 21:06:03,059 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Users\Daniel\Desktop\Anime\Ah_Megami_Sama_01_AnimeFuture_Animax-Anbient.mkv, ignore case: true
2012-08-13 21:06:03,089 DEBUG [MediaItemDAOImpl] Media item Ah_Megami_Sama_01_AnimeFuture_Animax-Anbient.mkv already exists in DB
2012-08-13 21:06:03,124 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Users\Daniel\Desktop\Anime\Ano Hana
2012-08-13 21:06:03,164 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_01_Dollars-Anbient.mkv', checking if it's already in the Library
2012-08-13 21:06:03,164 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_01_Dollars-Anbient.mkv
2012-08-13 21:06:03,164 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Users\Daniel\Desktop\Anime\Ano Hana\Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_01_Dollars-Anbient.mkv, ignore case: true
2012-08-13 21:06:03,166 DEBUG [MediaItemDAOImpl] Media item Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_01_Dollars-Anbient.mkv already exists in DB
2012-08-13 21:06:03,278 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_02_Dollars-Anbient.mkv', checking if it's already in the Library
2012-08-13 21:06:03,278 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_02_Dollars-Anbient.mkv
2012-08-13 21:06:03,278 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Users\Daniel\Desktop\Anime\Ano Hana\Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_02_Dollars-Anbient.mkv, ignore case: true
2012-08-13 21:06:03,279 DEBUG [MediaItemDAOImpl] Media item Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_02_Dollars-Anbient.mkv already exists in DB
2012-08-13 21:06:03,292 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-08-13 21:06:03,366 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_03_Dollars-Anbient.mkv', checking if it's already in the Library
2012-08-13 21:06:03,366 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_03_Dollars-Anbient.mkv
2012-08-13 21:06:03,366 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Users\Daniel\Desktop\Anime\Ano Hana\Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_03_Dollars-Anbient.mkv, ignore case: true
2012-08-13 21:06:03,367 DEBUG [MediaItemDAOImpl] Media item Ano_Hi_Mita_Hana_no_Namae_wo_Bokutachi_wa_Mada_Shiranai_03_Dollars-Anbient.mkv already exists in DB
2012-08-13 21:06:03,434 DEBUG [LibraryAdditionsCheckerThread] Found file 'Bakemonogatari_01_Hatten-Kyun-Anbient.mkv', checking if it's already in the Library
2012-08-13 21:06:03,434 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Bakemonogatari_01_Hatten-Kyun-Anbient.mkv
2012-08-13 21:06:03,434 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Users\Daniel\Desktop\Anime\Bakemonogatari_01_Hatten-Kyun-Anbient.mkv, ignore case: true
2012-08-13 21:06:03,436 DEBUG [MediaItemDAOImpl] Media item Bakemonogatari_01_Hatten-Kyun-Anbient.mkv doesn't exist in DB yet
2012-08-13 21:06:03,437 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-08-13 21:06:03,437 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2012-08-13 21:06:03,481 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2012-08-13 21:06:03,483 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2012-08-13 21:06:03,485 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 66) and extractor EMBEDDED
2012-08-13 21:06:03,486 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: C:\Users\Daniel\Desktop\Anime\Bakemonogatari_01_Hatten-Kyun-Anbient.mkv
2012-08-13 21:06:03,509 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 66) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:03,509 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: C:\Users\Daniel\Desktop\Anime\Bakemonogatari_01_Hatten-Kyun-Anbient.mkv
2012-08-13 21:06:03,510 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Users\Daniel\Desktop\Anime\Bakemonogatari_01_Hatten-Kyun-Anbient.mkv
2012-08-13 21:06:03,788 DEBUG [MediaItemDAOImpl] Getting file of media item 67
2012-08-13 21:06:03,791 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 67) and extractor EMBEDDED
2012-08-13 21:06:03,792 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 67) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:03,795 DEBUG [MediaItemDAOImpl] Getting file of media item 68
2012-08-13 21:06:03,797 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 68) and extractor EMBEDDED
2012-08-13 21:06:03,799 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 68) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:03,801 DEBUG [MediaItemDAOImpl] Getting file of media item 69
2012-08-13 21:06:03,803 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 69) and extractor EMBEDDED
2012-08-13 21:06:03,804 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 69) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:03,807 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: C:\Users\Daniel\Downloads
2012-08-13 21:06:03,807 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 2)
2012-08-13 21:06:03,807 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: C:\Users\Daniel\Downloads
2012-08-13 21:06:03,807 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 2)
2012-08-13 21:06:03,848 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2012-08-13 21:06:03,881 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor EMBEDDED
2012-08-13 21:06:03,883 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:03,903 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2012-08-13 21:06:04,004 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor EMBEDDED
2012-08-13 21:06:04,006 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,423 DEBUG [MediaItemDAOImpl] Getting file of media item 8
2012-08-13 21:06:04,424 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 8) and extractor EMBEDDED
2012-08-13 21:06:04,426 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 8) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,431 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2012-08-13 21:06:04,432 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor EMBEDDED
2012-08-13 21:06:04,433 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,439 DEBUG [MediaItemDAOImpl] Getting file of media item 10
2012-08-13 21:06:04,440 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor EMBEDDED
2012-08-13 21:06:04,442 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,447 DEBUG [MediaItemDAOImpl] Getting file of media item 11
2012-08-13 21:06:04,448 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor EMBEDDED
2012-08-13 21:06:04,450 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,454 DEBUG [MediaItemDAOImpl] Getting file of media item 12
2012-08-13 21:06:04,456 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 12) and extractor EMBEDDED
2012-08-13 21:06:04,457 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 12) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,462 DEBUG [MediaItemDAOImpl] Getting file of media item 13
2012-08-13 21:06:04,463 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 13) and extractor EMBEDDED
2012-08-13 21:06:04,465 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 13) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,468 DEBUG [MediaItemDAOImpl] Getting file of media item 14
2012-08-13 21:06:04,469 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 14) and extractor EMBEDDED
2012-08-13 21:06:04,470 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 14) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,473 DEBUG [MediaItemDAOImpl] Getting file of media item 15
2012-08-13 21:06:04,474 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 15) and extractor EMBEDDED
2012-08-13 21:06:04,475 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 15) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,479 DEBUG [MediaItemDAOImpl] Getting file of media item 16
2012-08-13 21:06:04,480 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 16) and extractor EMBEDDED
2012-08-13 21:06:04,481 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 16) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,483 DEBUG [MediaItemDAOImpl] Getting file of media item 17
2012-08-13 21:06:04,485 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 17) and extractor EMBEDDED
2012-08-13 21:06:04,485 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 17) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,489 DEBUG [MediaItemDAOImpl] Getting file of media item 18
2012-08-13 21:06:04,490 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 18) and extractor EMBEDDED
2012-08-13 21:06:04,491 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 18) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,493 DEBUG [MediaItemDAOImpl] Getting file of media item 19
2012-08-13 21:06:04,494 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 19) and extractor EMBEDDED
2012-08-13 21:06:04,495 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 19) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,498 DEBUG [MediaItemDAOImpl] Getting file of media item 20
2012-08-13 21:06:04,656 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 20) and extractor EMBEDDED
2012-08-13 21:06:04,659 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 20) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,700 DEBUG [MediaItemDAOImpl] Getting file of media item 21
2012-08-13 21:06:04,762 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 21) and extractor EMBEDDED
2012-08-13 21:06:04,764 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 21) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,802 DEBUG [MediaItemDAOImpl] Getting file of media item 22
2012-08-13 21:06:04,860 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22) and extractor EMBEDDED
2012-08-13 21:06:04,862 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 22) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:04,902 DEBUG [MediaItemDAOImpl] Getting file of media item 23
2012-08-13 21:06:04,951 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 23) and extractor EMBEDDED
2012-08-13 21:06:04,952 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 23) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:05,000 DEBUG [MediaItemDAOImpl] Getting file of media item 24
2012-08-13 21:06:05,105 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 24) and extractor EMBEDDED
2012-08-13 21:06:05,106 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 24) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:05,127 DEBUG [MediaItemDAOImpl] Getting file of media item 25
2012-08-13 21:06:05,128 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 25) and extractor EMBEDDED
2012-08-13 21:06:05,129 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 25) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:05,612 DEBUG [MediaItemDAOImpl] Getting file of media item 26
2012-08-13 21:06:05,717 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 26) and extractor EMBEDDED
2012-08-13 21:06:05,719 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 26) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:05,849 DEBUG [MediaItemDAOImpl] Getting file of media item 27
2012-08-13 21:06:05,975 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 27) and extractor EMBEDDED
2012-08-13 21:06:05,977 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 27) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,033 DEBUG [MediaItemDAOImpl] Getting file of media item 28
2012-08-13 21:06:06,034 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 28) and extractor EMBEDDED
2012-08-13 21:06:06,036 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 28) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,042 DEBUG [MediaItemDAOImpl] Getting file of media item 29
2012-08-13 21:06:06,158 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 29) and extractor EMBEDDED
2012-08-13 21:06:06,159 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 29) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,267 DEBUG [MediaItemDAOImpl] Getting file of media item 30
2012-08-13 21:06:06,269 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 30) and extractor EMBEDDED
2012-08-13 21:06:06,270 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 30) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,277 DEBUG [MediaItemDAOImpl] Getting file of media item 31
2012-08-13 21:06:06,343 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 31) and extractor EMBEDDED
2012-08-13 21:06:06,345 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 31) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,348 DEBUG [MediaItemDAOImpl] Getting file of media item 32
2012-08-13 21:06:06,439 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 32) and extractor EMBEDDED
2012-08-13 21:06:06,441 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 32) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,485 DEBUG [MediaItemDAOImpl] Getting file of media item 33
2012-08-13 21:06:06,486 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 33) and extractor EMBEDDED
2012-08-13 21:06:06,488 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 33) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,494 DEBUG [MediaItemDAOImpl] Getting file of media item 34
2012-08-13 21:06:06,564 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 34) and extractor EMBEDDED
2012-08-13 21:06:06,566 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 34) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,629 DEBUG [MediaItemDAOImpl] Getting file of media item 35
2012-08-13 21:06:06,691 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 35) and extractor EMBEDDED
2012-08-13 21:06:06,693 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 35) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,821 DEBUG [MediaItemDAOImpl] Getting file of media item 36
2012-08-13 21:06:06,857 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 36) and extractor EMBEDDED
2012-08-13 21:06:06,859 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 36) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,890 DEBUG [MediaItemDAOImpl] Getting file of media item 37
2012-08-13 21:06:06,919 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 37) and extractor EMBEDDED
2012-08-13 21:06:06,921 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 37) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:06,989 DEBUG [MediaItemDAOImpl] Getting file of media item 38
2012-08-13 21:06:07,025 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 38) and extractor EMBEDDED
2012-08-13 21:06:07,027 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 38) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:07,065 DEBUG [MediaItemDAOImpl] Getting file of media item 39
2012-08-13 21:06:07,214 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 39) and extractor EMBEDDED
2012-08-13 21:06:07,216 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 39) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:07,586 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'C:\Users\Daniel\Desktop\Anime\Bakemonogatari_01_Hatten-Kyun-Anbient.mkv'
2012-08-13 21:06:07,587 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: C:\Users\Daniel\Desktop\Anime\Bakemonogatari_01_Hatten-Kyun-Anbient.mkv
2012-08-13 21:06:07,587 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Users\Daniel\Desktop\Anime\Bakemonogatari_01_Hatten-Kyun-Anbient.mkv -frames:v 1 -c:v copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-08-13 21:06:08,292 DEBUG [MediaItemDAOImpl] Getting file of media item 40
2012-08-13 21:06:08,294 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 40) and extractor EMBEDDED
2012-08-13 21:06:08,295 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 40) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,298 DEBUG [MediaItemDAOImpl] Getting file of media item 41
2012-08-13 21:06:08,299 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 41) and extractor EMBEDDED
2012-08-13 21:06:08,300 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 41) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,303 DEBUG [MediaItemDAOImpl] Getting file of media item 42
2012-08-13 21:06:08,304 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 42) and extractor EMBEDDED
2012-08-13 21:06:08,306 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 42) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,308 DEBUG [MediaItemDAOImpl] Getting file of media item 43
2012-08-13 21:06:08,309 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 43) and extractor EMBEDDED
2012-08-13 21:06:08,310 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 43) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,313 DEBUG [MediaItemDAOImpl] Getting file of media item 44
2012-08-13 21:06:08,314 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 44) and extractor EMBEDDED
2012-08-13 21:06:08,316 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 44) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,318 DEBUG [MediaItemDAOImpl] Getting file of media item 45
2012-08-13 21:06:08,548 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 45) and extractor EMBEDDED
2012-08-13 21:06:08,550 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 45) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,629 DEBUG [MediaItemDAOImpl] Getting file of media item 46
2012-08-13 21:06:08,688 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 46) and extractor EMBEDDED
2012-08-13 21:06:08,689 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 46) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,905 DEBUG [MediaItemDAOImpl] Getting file of media item 47
2012-08-13 21:06:08,906 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 47) and extractor EMBEDDED
2012-08-13 21:06:08,908 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 47) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,911 DEBUG [MediaItemDAOImpl] Getting file of media item 48
2012-08-13 21:06:08,913 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 48) and extractor EMBEDDED
2012-08-13 21:06:08,915 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 48) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,918 DEBUG [MediaItemDAOImpl] Getting file of media item 49
2012-08-13 21:06:08,920 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 49) and extractor EMBEDDED
2012-08-13 21:06:08,922 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 49) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,925 DEBUG [MediaItemDAOImpl] Getting file of media item 50
2012-08-13 21:06:08,926 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 50) and extractor EMBEDDED
2012-08-13 21:06:08,928 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 50) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,932 DEBUG [MediaItemDAOImpl] Getting file of media item 51
2012-08-13 21:06:08,933 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 51) and extractor EMBEDDED
2012-08-13 21:06:08,934 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 51) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,937 DEBUG [MediaItemDAOImpl] Getting file of media item 52
2012-08-13 21:06:08,938 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 52) and extractor EMBEDDED
2012-08-13 21:06:08,939 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 52) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,941 DEBUG [MediaItemDAOImpl] Getting file of media item 53
2012-08-13 21:06:08,942 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 53) and extractor EMBEDDED
2012-08-13 21:06:08,943 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 53) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,945 DEBUG [MediaItemDAOImpl] Getting file of media item 54
2012-08-13 21:06:08,946 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 54) and extractor EMBEDDED
2012-08-13 21:06:08,947 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 54) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,949 DEBUG [MediaItemDAOImpl] Getting file of media item 55
2012-08-13 21:06:08,950 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 55) and extractor EMBEDDED
2012-08-13 21:06:08,951 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 55) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,953 DEBUG [MediaItemDAOImpl] Getting file of media item 56
2012-08-13 21:06:08,953 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 56) and extractor EMBEDDED
2012-08-13 21:06:08,954 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 56) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,957 DEBUG [MediaItemDAOImpl] Getting file of media item 57
2012-08-13 21:06:08,958 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 57) and extractor EMBEDDED
2012-08-13 21:06:08,959 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 57) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,961 DEBUG [MediaItemDAOImpl] Getting file of media item 58
2012-08-13 21:06:08,962 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 58) and extractor EMBEDDED
2012-08-13 21:06:08,963 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 58) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,965 DEBUG [MediaItemDAOImpl] Getting file of media item 59
2012-08-13 21:06:08,974 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 59) and extractor EMBEDDED
2012-08-13 21:06:08,975 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 59) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,992 DEBUG [MediaItemDAOImpl] Getting file of media item 60
2012-08-13 21:06:08,993 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 60) and extractor EMBEDDED
2012-08-13 21:06:08,994 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 60) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,996 DEBUG [MediaItemDAOImpl] Getting file of media item 61
2012-08-13 21:06:08,996 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 61) and extractor EMBEDDED
2012-08-13 21:06:08,997 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 61) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:08,999 DEBUG [MediaItemDAOImpl] Getting file of media item 62
2012-08-13 21:06:09,000 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 62) and extractor EMBEDDED
2012-08-13 21:06:09,001 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 62) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:09,002 DEBUG [MediaItemDAOImpl] Getting file of media item 63
2012-08-13 21:06:09,003 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 63) and extractor EMBEDDED
2012-08-13 21:06:09,004 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 63) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:09,005 DEBUG [MediaItemDAOImpl] Getting file of media item 64
2012-08-13 21:06:09,006 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 64) and extractor EMBEDDED
2012-08-13 21:06:09,007 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 64) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:09,008 DEBUG [MediaItemDAOImpl] Getting file of media item 65
2012-08-13 21:06:09,027 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 65) and extractor EMBEDDED
2012-08-13 21:06:09,028 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 65) and extractor COVER_IMAGE_IN_FOLDER
2012-08-13 21:06:09,029 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2012-08-13 21:06:09,054 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2012-08-13 21:06:09,606 DEBUG [FFmpegMetadataRetriever] File 'C:\Users\Daniel\Desktop\Anime\Bakemonogatari_01_Hatten-Kyun-Anbient.mkv' has H264 profile HIGH, level 5 and 16 ref frames
2012-08-13 21:06:09,660 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 2)
2012-08-13 21:06:09,665 DEBUG [RepositoryDAOImpl] Marking Repository 2 as scanned with current timestamp
2012-08-13 21:06:09,671 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-13 21:06:15,026 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.0.2, timeout = 0
2012-08-13 21:06:15,026 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-08-13 21:06:16,991 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:39
2012-08-13 21:06:22,585 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-13 21:06:22,585 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-13 21:06:57,829 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.0.2, timeout = 0
2012-08-13 21:06:57,829 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-08-13 21:06:59,811 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:37
2012-08-13 21:07:22,587 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-13 21:07:22,587 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-13 21:07:38,236 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.0.2, timeout = 0
2012-08-13 21:07:38,236 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-08-13 21:07:40,201 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:53
2012-08-13 21:08:22,591 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-13 21:08:22,591 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-13 21:08:22,796 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-08-13 21:08:34,712 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.0.2, timeout = 0
2012-08-13 21:08:34,712 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-08-13 21:08:36,678 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:49
2012-08-13 21:09:22,592 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-13 21:09:22,592 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-13 21:09:27,148 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Intel(R) Centrino(R) Advanced-N 6200 AGN) and address 192.168.0.2, timeout = 0
2012-08-13 21:09:27,148 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c41c5514-0d79-3774-967b-023b9e31d01f
2012-08-13 21:09:29,114 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:48
Post Tue Aug 14, 2012 12:17 pm
looks like Bakemonogatari_01_Hatten-Kyun-Anbient.mkv is causing some problems. Try to remove it and restart Serviio.
jhow
Post Tue Aug 14, 2012 4:36 pm
hum it worked when i deleted the file. The weird thing is that on the older version that file worked fine...
tks
Post Wed Aug 15, 2012 10:55 pm
Tried your file, worked ok for me. Are you running on a NAS or with some memory restrictions?
jhow
Post Thu Aug 16, 2012 1:53 am
Im running on my laptop on a wireless router. What do you mean by memory restrictions? I`ve limited the processing of my laptop because it was overheating, does that have something do to with the problem?
Post Thu Aug 16, 2012 1:05 pm
should not, unless it has less than 500 MB RAM. But you never know.
sunnyday
Post Thu Aug 30, 2012 6:59 pm
jhow wrote:Hello, I`ve upgraded my 0.62 version to the new one and now I am having problems updating my library.
It most definitely is a problem with the library refresh in Serviio 1.0.1. I have never had any problems prior to this upgrade.
Have the same symptoms as you describe above, I have tried both upgrade from 0.6.2 as well as clean install. The same media files as before upgrade.
The showstopper for me was one of the reference mkv:s in the package from http://sourceforge.net/projects/matrosk ... t_w1_1.zip
I had to remove one of the mkv files and restart host computer (service could not be stopped normally), before Serviio could complete the refresh.
Samsung UE46D5005XXE | Samsung BD-C6500
freeman
Post Sun Sep 02, 2012 9:43 pm
i've the same problem with 1.0.1 version (and not with the previous). I'm using Serviio with WHS2011 and it freeze when i force the library updating.
thx
Freeman
Strupniveral
Post Mon Sep 03, 2012 11:56 pm
Something similar is happening to me.
I have both 0.6.2 and 1.0.1 installed on my machine, pointing to the same shows tree.
When 0.6.2 is up and running, I can see all my shows organized properly under "Series" folder, when running 1.0.1 I can't see none. They don't appear under "Movies" either.
Note that in the second case the each and every episode is available under "Folders" and plays properly from there.
Then, I'd say the issue is not with the shows tree/naming on my drive or matching with the online resource.
I set the log level to debug, but I didn't manage to identify any attempt to fetch metadata from the web, just extracting them from file's metadata (since I haven't none there, it makes sense no one is retrieved).
So I'm wondering:
1. Should I be able to see something like "fetching details from http://www.thetvdb.com for episode X of show Y" in log files?
2. Do I have a way to check the proper setting for metadata extraction are defined other than using the console? I'm running serviio on an headless box without X, managing it via the PHP web ui. It shows the proper setting ("Online metadata sources"), but it might be worth double-check
3. Can I check something to verify the details are gathered? e.g. running a scan and check if a given file gets updated or so.
Thanks and Regards,
Luca
EDIT: After a few hours of sleep, I realized I didn't enabled the "metadata" flag in the "Shared Folder" list... Now it's running at it seems to organize them properly... ;)
altano
Post Mon Nov 26, 2012 7:02 am
I'm also seeing this. I upgraded from 0.6.2 to 1.0.1 and Serviio was crashing on startup. I upgraded Java to 7 Update 9 and that fixed the crash, but now Serviio consistently hangs. The service stays hitting the CPU at 13% and the console becomes unresponsive. If I kill the Serviio server process, restart the service, and restart the console, it becomes usable again, but as soon as I hit "force refresh" for the library it hangs again. I never had any of these issues before so I don't know what's going on.
I don't think the service is actually deadlocked because it continues to log output (I have DEBUG output turned on). It's just the console can't communicate with it anymore and the Service Control Manager can't contact it either. Here's a random sampling from the end of the log, while it's hung:
2012-11-26 01:54:27,454 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-11-26 01:54:27,454 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Close,Pragma: no-cache,Accept: text/xml, application/xml,Host: 192.168.1.110:8895,User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50]
2012-11-26 01:54:27,454 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-11-26 01:54:28,015 DEBUG [WebServer] Incoming connection from /192.168.1.8:55238
2012-11-26 01:54:28,015 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-11-26 01:54:28,015 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-11-26 01:55:22,710 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-11-26 01:55:22,710 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-11-26 01:55:32,289 DEBUG [WebServer] I/O error: Connection reset
2012-11-26 01:56:04,223 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:56:04,223 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:07,218 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:56:07,218 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:10,229 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:56:10,229 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:13,271 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:56:13,271 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:16,266 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:56:16,266 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:19,261 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:56:19,261 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:22,537 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-11-26 01:56:22,724 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-11-26 01:56:22,724 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-11-26 01:56:26,437 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.115:52467
2012-11-26 01:56:26,437 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:26,437 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.115:52467
2012-11-26 01:56:26,437 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.115:52467
2012-11-26 01:56:29,446 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.115:52467
2012-11-26 01:56:29,446 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:29,446 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.115:52467
2012-11-26 01:56:29,446 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.115:52467
2012-11-26 01:56:32,437 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.115:52467
2012-11-26 01:56:32,437 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:32,437 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.115:52467
2012-11-26 01:56:32,453 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.115:52467
2012-11-26 01:56:32,453 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:56:39,457 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:56
2012-11-26 01:57:04,419 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:57:04,419 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:57:07,209 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:57:07,210 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:57:10,209 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:57:10,209 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:57:13,234 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:57:13,234 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:57:16,235 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:57:16,235 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:57:19,239 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.115:52467
2012-11-26 01:57:19,240 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.115
2012-11-26 01:57:22,698 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-11-26 01:57:22,698 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-11-26 01:57:35,833 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Intel(R) 82574L Gigabit Network Connection) and address 192.168.1.25, timeout = 0
2012-11-26 01:57:35,833 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 00f06443-398c-3d99-ae1a-d31c171b4221
2012-11-26 01:57:36,208 DEBUG [WebServer] Incoming connection from /192.168.1.8:55313
2012-11-26 01:57:36,223 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-11-26 01:57:36,223 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 00f06443-398c-3d99-ae1a-d31c171b4221 from 192.168.1.8 (headers = [X-AV-Physical-Unit-Info: pa="vbook",X-AV-Client-Info: av=5.0;hn="vbook";cn="Sony Corporation";mn="Sony HomeNetwork SDK";mv="2.0.00";,host: 192.168.1.110:8895,content-length: 0])
2012-11-26 01:57:36,223 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [X-AV-Physical-Unit-Info: pa="vbook",X-AV-Client-Info: av=5.0;hn="vbook";cn="Sony Corporation";mn="Sony HomeNetwork SDK";mv="2.0.00";,host: 192.168.1.110:8895,content-length: 0]
2012-11-26 01:57:36,223 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-11-26 01:57:36,239 DEBUG [WebServer] Incoming connection from /192.168.1.8:55314
2012-11-26 01:57:36,254 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-11-26 01:57:36,254 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2012-11-26 01:57:36,254 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-11-26 01:57:36,254 DEBUG [WebServer] Incoming connection from /192.168.1.8:55315
2012-11-26 01:57:36,270 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-11-26 01:57:36,270 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2012-11-26 01:57:36,270 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-11-26 01:57:36,286 DEBUG [WebServer] Incoming connection from /192.168.1.8:55316
2012-11-26 01:57:36,286 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-11-26 01:57:36,286 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2012-11-26 01:57:36,286 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-11-26 01:57:36,317 DEBUG [WebServer] Incoming connection from /192.168.1.8:55317
2012-11-26 01:57:36,317 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-11-26 01:57:36,317 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.8:
2012-11-26 01:57:36,317 DEBUG [ConnectionManager] Sending protocol info using profile 'Generic DLNA profile'
2012-11-26 01:57:36,332 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-11-26 01:58:05,209 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription 02a660a9-946d-41da-aebf-1a5586aba2d8 from service urn:upnp-org:serviceId:ConnectionManager
2012-11-26 01:58:05,209 DEBUG [EventSubscriptionExpirationChecker] Removed expired subscription e14f8bae-71c9-4b8e-be96-ebb70491de7f from service urn:upnp-org:serviceId:ContentDirectory
2012-11-26 01:58:22,743 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-11-26 01:58:22,743 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Does any of this output indicate why the console is hung? Why is this happening on library refreshes? Why does the log output not actually say anything about the library refresh?
altano
Post Mon Nov 26, 2012 7:18 am
I just downgraded to 0.6.2 and my library is refreshing as we speak, several hundred videos are already added (much further than I got with 1.0.1) and it's adding them very quickly. The hang is gone.
Hmmm.
Post Mon Nov 26, 2012 3:16 pm
It's probably a bug in FFmpeg. You could try 1.0.1 with the latest FFmpeg.
Users browsing this forum: Baidu [Spider] and 13 guests
