Using 2 NICs possible?
Filip87
Post Sun Dec 30, 2012 4:56 pm
just one simpel question: Is it possible to use two network interfaces?
Reason is i have two subnets, now i want to stream in both using one serviio server. Is that possible?
Thanks and greets,
Filip
Post Mon Dec 31, 2012 12:07 am
Re: Using 2 NICs possible?
No, afaik
slyguy42o
Post Mon Dec 31, 2012 5:21 am
what if you ran two instances under separate login accounts, then bound each to a diff nic?
Filip87
Post Mon Dec 31, 2012 12:15 pm
Don't know, but i'll try later and tell you.
Post Mon Dec 31, 2012 1:57 pm
it won't work, you can only run 1 instance on one PC.
Users browsing this forum: No registered users and 51 guests
