Xbox says NO! to this mp4
vancrack
Post Mon Mar 26, 2012 5:52 pm
C:\Users\paul>cd "\program files\serviio\lib"
C:\Program Files\Serviio\lib>ffmpeg.exe -i "c:users\paul\downloads\movies\the lo
rd of the rings the fellowship of the ring.mp4
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
c:users\paul\downloads\movies\the lord of the rings the fellowship of the ring.m
p4: No such file or directory
C:\Program Files\Serviio\lib>ffmpeg.exe -i "c:\users\paul\download\movies\the lo
nfig
c:\users\paul\download\movies\the lord of the rings the fellowship of the ring.m
C:\Program Files\Serviio\lib>ffmpeg -i "c:\Users\paul\Downloads\movies\The lord
nfig
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'c:\Users\paul\Downloads\movies\The lord
of the rings the fellowship of the ring.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isomavc1
creation_time : 2011-10-29 07:50:30
Duration: 03:48:10.84, start: 0.000000, bitrate: 3515 kb/s
Chapter #0.0: start 0.000000, end 300.000000
title : Chapter 1
Chapter #0.1: start 300.000000, end 600.000000
title : Chapter 2
Chapter #0.2: start 600.000000, end 900.000000
title : Chapter 3
Chapter #0.3: start 900.000000, end 1200.000000
title : Chapter 4
Chapter #0.4: start 1200.000000, end 1500.000000
title : Chapter 5
Chapter #0.5: start 1500.000000, end 1800.000000
title : Chapter 6
Chapter #0.6: start 1800.000000, end 2100.000000
title : Chapter 7
Chapter #0.7: start 2100.000000, end 2400.000000
title : Chapter 8
Chapter #0.8: start 2400.000000, end 2700.000000
title : Chapter 9
Chapter #0.9: start 2700.000000, end 3000.000000
title : Chapter 10
Chapter #0.10: start 3000.000000, end 3300.000000
title : Chapter 11
Chapter #0.11: start 3300.000000, end 3600.000000
title : Chapter 12
Chapter #0.12: start 3600.000000, end 3900.000000
title : Chapter 13
Chapter #0.13: start 3900.000000, end 4200.000000
title : Chapter 14
Chapter #0.14: start 4200.000000, end 4500.000000
title : Chapter 15
Chapter #0.15: start 4500.000000, end 4800.000000
title : Chapter 16
Chapter #0.16: start 4800.000000, end 5100.000000
title : Chapter 17
Chapter #0.17: start 5100.000000, end 5400.000000
title : Chapter 18
Chapter #0.18: start 5400.000000, end 5700.000000
title : Chapter 19
Chapter #0.19: start 5700.000000, end 6000.000000
title : Chapter 20
Chapter #0.20: start 6000.000000, end 6300.000000
title : Chapter 21
Chapter #0.21: start 6300.000000, end 6600.000000
title : Chapter 22
Chapter #0.22: start 6600.000000, end 6900.000000
title : Chapter 23
Chapter #0.23: start 6900.000000, end 7200.000000
title : Chapter 24
Chapter #0.24: start 7200.000000, end 7500.000000
title : Chapter 25
Chapter #0.25: start 7500.000000, end 7800.000000
title : Chapter 26
Chapter #0.26: start 7800.000000, end 8100.000000
title : Chapter 27
Chapter #0.27: start 8100.000000, end 8400.000000
title : Chapter 28
Chapter #0.28: start 8400.000000, end 8700.000000
title : Chapter 29
Chapter #0.29: start 8700.000000, end 9000.000000
title : Chapter 30
Chapter #0.30: start 9000.000000, end 9300.000000
title : Chapter 31
Chapter #0.31: start 9300.000000, end 9600.000000
title : Chapter 32
Chapter #0.32: start 9600.000000, end 9900.000000
title : Chapter 33
Chapter #0.33: start 9900.000000, end 10200.000000
title : Chapter 34
Chapter #0.34: start 10200.000000, end 10500.000000
title : Chapter 35
Chapter #0.35: start 10500.000000, end 10800.000000
title : Chapter 36
Chapter #0.36: start 10800.000000, end 11100.000000
title : Chapter 37
Chapter #0.37: start 11100.000000, end 11400.000000
title : Chapter 38
Chapter #0.38: start 11400.000000, end 11700.000000
title : Chapter 39
Chapter #0.39: start 11700.000000, end 12000.000000
title : Chapter 40
Chapter #0.40: start 12000.000000, end 12300.000000
title : Chapter 41
Chapter #0.41: start 12300.000000, end 12600.000000
title : Chapter 42
Chapter #0.42: start 12600.000000, end 12900.000000
title : Chapter 43
Chapter #0.43: start 12900.000000, end 13200.000000
title : Chapter 44
Chapter #0.44: start 13200.000000, end 13500.000000
title : Chapter 45
Chapter #0.45: start 13500.000000, end 13690.843834
title : Chapter 46
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x800
[SAR 1:1 DAR 12:5], 3194 kb/s, 23.98 fps, 23.98 tbr, 96k tbn, 47.95 tbc
handler_name : LOTR Ep 1
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, s16, 317 kb
/s
creation_time : 2011-10-29 07:59:19
handler_name :
Could it be because it's over 4GB and chapterised? or something? Like my bed is facing the wrong way maybe (noob).
Post Tue Mar 27, 2012 7:57 am
Re: Xbox says NO! to this mp4
Could you provide MediaInfo tool result (in text format) ?
vancrack
Post Tue Mar 27, 2012 12:46 pm
Is this what you're after? Thanks for taking the time to help by the way...
Complete name : C:\Users\paul\Downloads\movies\The lord of the rings the fellowship of the ring.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 5.60 GiB
Duration : 3h 48mn
Overall bit rate : 3 516 Kbps
Encoded date : UTC 2011-10-29 07:50:30
Tagged date : UTC 2011-10-29 07:50:30
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3h 48mn
Bit rate mode : Variable
Bit rate : 3 196 Kbps
Maximum bit rate : 25.0 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.087
Stream size : 5.09 GiB (91%)
Title : LOTR Ep 1
Writing library : x264 core 114 r1924 08d04a4
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3196 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2011-10-29 08:00:20
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 3h 48mn
Bit rate : 317 Kbps
Maximum bit rate : 336 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 518 MiB (9%)
Encoded date : UTC 2011-10-29 07:59:19
Menu
00:00:00.000 : Chapter 1
00:05:00.000 : Chapter 2
00:10:00.000 : Chapter 3
00:15:00.000 : Chapter 4
00:20:00.000 : Chapter 5
00:25:00.000 : Chapter 6
00:30:00.000 : Chapter 7
00:35:00.000 : Chapter 8
00:40:00.000 : Chapter 9
00:45:00.000 : Chapter 10
00:50:00.000 : Chapter 11
00:55:00.000 : Chapter 12
01:00:00.000 : Chapter 13
01:05:00.000 : Chapter 14
01:10:00.000 : Chapter 15
01:15:00.000 : Chapter 16
01:20:00.000 : Chapter 17
01:25:00.000 : Chapter 18
01:30:00.000 : Chapter 19
01:35:00.000 : Chapter 20
01:40:00.000 : Chapter 21
01:45:00.000 : Chapter 22
01:50:00.000 : Chapter 23
01:55:00.000 : Chapter 24
02:00:00.000 : Chapter 25
02:05:00.000 : Chapter 26
02:10:00.000 : Chapter 27
02:15:00.000 : Chapter 28
02:20:00.000 : Chapter 29
02:25:00.000 : Chapter 30
02:30:00.000 : Chapter 31
02:35:00.000 : Chapter 32
02:40:00.000 : Chapter 33
02:45:00.000 : Chapter 34
02:50:00.000 : Chapter 35
02:55:00.000 : Chapter 36
03:00:00.000 : Chapter 37
03:05:00.000 : Chapter 38
03:10:00.000 : Chapter 39
03:15:00.000 : Chapter 40
03:20:00.000 : Chapter 41
03:25:00.000 : Chapter 42
03:30:00.000 : Chapter 43
03:35:00.000 : Chapter 44
03:40:00.000 : Chapter 45
03:45:00.000 : Chapter 46
Post Tue Mar 27, 2012 2:03 pm
Seems good...
You could try with TsMuxer tool to remux file to mpeg2ts container.
vancrack
Post Tue Mar 27, 2012 3:56 pm
Cheers, I'll look into that. Once again, thanks for your time!
patters
Post Wed Apr 11, 2012 10:50 pm
The Xbox will only play two channel audio in MP4. The only exception is in WMV files with WMAPRO multichannel audio. The bummer is that you can't real-time encode an MP4 file. If you could, or if the Xbox could play MPEGTS we could downmix the audio on the fly. But we can't. The 360 is so nearly a viable media player, but not quite :(
This tool may help you convert the video before adding it to the Serviio library, though it may only be intended for MKV files:
http://xenonmkv.ev98.net/
vancrack
Post Wed Apr 18, 2012 10:32 am
I see now. I wasn't aware of the MP4 thing with encoding, i just thought Serviio would downmix to a stereo track. Not a biggie, there are plenty of tools out there to fix the files. Thanks muchly guys!
allenlook
Post Sun Jan 06, 2013 12:24 pm
Sorry to necro this thread, but I wanted to add a bit of detail for future noobs like myself on how to make MP4 files work when they won't play on the XBox 360 but they play just fine on the PC. At least, this is what just worked for me.
1. Open the MP4 file in Handbrake.
2. Verify the destination file name is what/where you want.
3. Click the Audio tab and select "AAC (ffmpeg)" or "MP3 (lame)" and downmix the audio to "Stereo".
4. Enqueue and process the file, and test on the PC.
5. Move the file back to the Video folder that Serviio monitors, then open Serviio Console and update the library.
6. Test the file on the XBox 360.
I'd note also that both files I just had that would not work, when viewed under "Properties" in Windows, showed that they already had a Stereo-2 channel audio track, but they refused to play on the XBox 360 until I did this. I don't know all the combinations and bifurcations of audio codecs, and the nice thing about Serviio is that generally I don't have to care, but every once in a while I get a file that won't play, and at least for the two MP4 files I tested today, this made them work.
Users browsing this forum: Google [Bot] and 25 guests
