last viewed is throwing an error
slyguy42o
Post Thu Jan 17, 2013 2:34 am
I am getting this error when trying to browse into last viewed list. Seems like something funky happened in the db.. do I need to clear out my library and let it rebuild?
2013-01-16 18:22:48,725 WARN [ContentDirectory] Browse for object id V_LV failed with exception: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot read list of 30 last viewed videos
java.lang.RuntimeException: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot read list of 30 last viewed videos
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:245)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.findContainerItems(ContainerNode.java:182)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.retrieveContainerItems(ContainerNode.java:83)
at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.browse(ContentDirectoryEngine.java:102)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:152)
at sun.reflect.GeneratedMethodAccessor79.invoke(Unknown Source)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:66)
Caused by: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot read list of 30 last viewed videos
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:135)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:242)
... 15 more
Caused by: org.serviio.db.dao.PersistenceException: Cannot read list of 30 last viewed videos
at org.serviio.library.dao.VideoDAOImpl.retrieveLastViewedVideos(VideoDAOImpl.java:842)
at org.serviio.library.local.service.VideoService.getListOfLastViewedVideos(VideoService.java:486)
at org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand.retrieveEntityList(ListLastViewedVideosCommand.java:41)
at org.serviio.upnp.service.contentdirectory.command.AbstractEntityItemCommand.retrieveList(AbstractEntityItemCommand.java:51)
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:129)
... 16 more
Caused by: java.sql.SQLDataException: Row count for FIRST/NEXT must be >= 1 and row count for LIMIT must be >= 0.
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement20.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement30.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.newEmbedPreparedStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.prepareStatement(Unknown Source)
at org.serviio.library.dao.VideoDAOImpl.retrieveLastViewedVideos(VideoDAOImpl.java:826)
... 20 more
Caused by: java.sql.SQLException: Row count for FIRST/NEXT must be >= 1 and row count for LIMIT must be >= 0.
... 34 more
Caused by: ERROR 2201W: Row count for FIRST/NEXT must be >= 1 and row count for LIMIT must be >= 0.
at org.apache.derby.impl.sql.compile.QueryTreeNode.bindOffsetFetch(Unknown Source)
at org.apache.derby.impl.sql.compile.CursorNode.bindStatement(Unknown Source)
at org.apache.derby.impl.sql.GenericStatement.prepMinion(Unknown Source)
at org.apache.derby.impl.sql.GenericStatement.prepare(Unknown Source)
at org.apache.derby.impl.sql.conn.GenericLanguageConnectionContext.prepareInternalStatement(Unknown Source)
... 28 more
2013-01-16 18:22:53,011 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: Cannot read list of 30 last viewed videos
... 16 more
... 20 more
... 34 more
... 28 more
Post Thu Jan 17, 2013 1:32 pm
Re: last viewed is throwing an error
I fixed this for 1.2
Users browsing this forum: Baidu [Spider] and 41 guests
