MP4 with DTS audio not showing up in library
indybart
Post Thu Aug 16, 2012 10:35 am
I have recently started creating my MP4s with DTS audio (direct passthru with no transcoding to AC3 or other) and have noticed than none of these MP4/DTS movies are showing up in the available library. They play just fine with VLC, so I know the files are OK. All of the MP4s with audio other than DTS appear. Am I not selecting a needed Serviio option or is this a limitation of the program? Had this issue in 1.0 and still have it with a clean install of 1.0.1, on Windows 7 x64, SP1.
Post Thu Aug 16, 2012 1:19 pm
Re: MP4 with DTS audio not showing up in library
what is your renderer and what profile are you using? post ffmpeg -i of the file.
indybart
Post Thu Aug 16, 2012 2:54 pm
MMFPEG -i output:
FFmpeg version SVN-r21659-rdian06-1.02-win-x86_32, Copyright (c) 2000-2010 Fabri
ce Bellard, et al.
built on Aug 24 2010 20:46:16 with gcc 4.4.0
configuration: --enable-memalign-hack --disable-debug --enable-hardcoded-table
s --enable-runtime-cpudetect --enable-static --disable-shared --disable-ffserver
--disable-ffplay --enable-gpl --enable-pthreads --enable-libmp3lame --enable-li
bvorbis --enable-libtheora --enable-libspeex --enable-libgsm --enable-libx264 --
enable-libschroedinger --enable-libfaad --enable-libxvid --disable-decoder=aac -
-enable-avisynth --enable-postproc --enable-avfilter --enable-avfilter-lavf
libavutil 50. 8. 0 / 50. 8. 0
libavcodec 52.52. 0 / 52.52. 0
libavformat 52.50. 0 / 52.50. 0
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.17. 0 / 1.17. 0
libswscale 0.10. 0 / 0.10. 0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x1aebd70]max_analyze_duration reached
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'I:\Last_Night.mp4':
major_brand : mp42
minor_version : 0
encoder : HandBrake 0.9.8 2012071700
Duration: 01:32:43.06, start: 0.000000, bitrate: 3340 kb/s
Stream #0.0(und): Video: h264, yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 1828 k
b/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0.1(eng): Audio: mp4a / 0x6134706D, 48000 Hz, 6 channels, 1509 kb/s
Post Thu Aug 16, 2012 3:54 pm
update your ffmpeg (you have 2 year old version) and we will take it from there
indybart
Post Fri Aug 17, 2012 9:38 am
Sorry about that ... here is the output from my current FFMPEG version:
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'i:\last_night.mp4':
major_brand : mp42
minor_version : 0
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x816
[SAR 1:1 DAR 40:17], 1828 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0:1(eng): Audio: dts (DTS) (mp4a / 0x6134706D), 48000 Hz, 5.1(side),
s16, 1536 kb/s
Post Fri Aug 17, 2012 11:03 am
still not appearing? what is your renderer. And check the file is added to library by running MediaController from Intel tools (link in my signature)
indybart
Post Sun Aug 19, 2012 12:20 pm
I use Handbrake 0.98, x264 encoder. The DTS audio versions that do not appear in the library are created using the Handbrake "passthru" option, which I believe is a straight bit for bit copy of the audio track. If I transcode the audio to AC3 (using x264), the movie appears in the library.
Post Sun Aug 19, 2012 7:46 pm
You still haven't told me what is your renderer device?
brezuicabogdan
Post Thu Jan 17, 2013 1:01 pm
Same problem here. MP4 files do not show up in lybrary listings. However they do show up if I use the directory listing in deluge and not the Series or Movies folders and I can play them just fine.
Should I provide a FFmpeg listing?
Post Thu Jan 17, 2013 1:24 pm
That's because metadata have not been found for these to identify them as serie or movie.
brezuicabogdan
Post Thu Jan 17, 2013 1:30 pm
Thank you for your answer. Is there a way around that? I don`t really know how metadata is obtained, I suppose it`s from online sources but this only happens for mp4 files and not all of them, some work. So I think this lack of found metadata has something to do with the file format.
Post Thu Jan 17, 2013 2:06 pm
brezuicabogdan
Post Thu Jan 17, 2013 2:09 pm
Thank you very much!
Users browsing this forum: No registered users and 77 guests
