[SOLVED] No suitable driver for jdbc:derby:db
slaute
Post Sun Jan 20, 2013 9:16 pm
See the SOLUTION to this problem in the second reply.
In a Mac OS X 10.8.2 system up to date, freshly booted and with Apple's Java 6 JDK installed plus Oracle's Java 7 plugin for web browsers:
$ java -version
java version "1.6.0_37"
Java(TM) SE Runtime Environment (build 1.6.0_37-b06-434-11M3909)
Java HotSpot(TM) 64-Bit Server VM (build 20.12-b01-434, mixed mode)
I'm getting An unexpected error that kills the server with a NullPointerException a few seconds after every time I try to start the Serviio 1.1 server.
I can see the following in the DEBUG log:
2013-01-20 21:28:39,602 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-01-20 21:28:39,607 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-20 21:28:39,607 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-20 21:28:39,608 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-20 21:28:39,608 INFO  [MediaServer] http://www.serviio.org
2013-01-20 21:28:39,608 INFO  [MediaServer] Java 1.6.0_37-Apple Inc.
2013-01-20 21:28:39,608 INFO  [MediaServer] OS Mac OS X x86_64 10.8.2
2013-01-20 21:28:39,608 INFO  [MediaServer] File encoding: UTF-8
2013-01-20 21:28:39,608 INFO  [MediaServer] Headless mode enabled: true
2013-01-20 21:28:39,608 INFO  [MediaServer] User: myuser
2013-01-20 21:28:39,608 INFO  [MediaServer] User home dir: /Users/myuser
2013-01-20 21:28:39,608 INFO  [MediaServer] Temp dir: /var/folders/lr/rnv4gjw52dz73c37m079rdg00000gn/T/
2013-01-20 21:28:39,608 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-20 21:28:39,695 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-20 21:28:39,697 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-20 21:28:39,723 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-20 21:28:39,724 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-20 21:28:39,732 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-20 21:28:39,737 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-01-20 21:28:39,740 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: No suitable driver found for jdbc:derby:db;create=true
   at java.sql.DriverManager.getConnection(DriverManager.java:602)
   at java.sql.DriverManager.getConnection(DriverManager.java:207)
   at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
   at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:57)
   at org.serviio.MediaServer.main(MediaServer.java:110)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
   at java.lang.reflect.Method.invoke(Method.java:597)
   at apple.launcher.LaunchRunner.run(LaunchRunner.java:116)
   at apple.launcher.LaunchRunner.callMain(LaunchRunner.java:51)
   at apple.launcher.JavaApplicationLauncher.launch(JavaApplicationLauncher.java:52)
2013-01-20 21:28:41,745 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
Maybe it's this: No suitable driver found for jdbc:derby:db;create=true ?
GateKeeper is set to allow applications downloaded from anywhere.
derby.jar is part of Serviio.app at Serviio.app/Contents/Resources/Java/derby.jar
The tarball from which I extracted Serviio.app has the correct MD5 checksum as per Serviio's Download webpage (93051e796b6428c7ca87194fe53e92bb). The MD5 checksum of Serviio.app/Contents/Resources/Java/derby.jar is 000702c96fa81afad91ba1be32ff0a08
Regarding permissions,
All directories and files inside Serviio.app are 755 and 644, respectively, with myuser:staff as owners. Being myuser the user I'm using to execute Serviio.app.
I also run the Repair Permissions procedure in the Disk Utility of Mac OS X just to be sure everything else is OK.
And I tried
$ sudo open /Applications/Serviio.app
which produced the same warning and error as always, so I'd really say it's not a permissions problem.
Any hint?
Miguel
slaute
Post Mon Jan 21, 2013 4:28 pm
Re: Serviio dies after "No suitable driver for jdbc:derby:db
I've tried the same on another Mac OS X 10.8.2 with the same Java version and it works well.
The problem is the No suitable driver found for jdbc:derby:db;create=true thing.
The question is. Why am I getting this error if I have derby.jar inside the Java folder and the checksum of the tarball used to install is correct (no corruption of files)????
How can I get more detailed logs of this? I'm already using the DEBUG log level as defined in log4j.xml
Any hint of what could be the reason for the failure??
slaute
Post Mon Jan 21, 2013 6:06 pm
Re: [SOLVED] No suitable driver for jdbc:derby:db
I solved the problem by removing fmjdbc.jar from ~/Library/Extensions/
Users browsing this forum: Google [Bot] and 35 guests
