Serviio Server hangs on the mac dock
francob
Post Sat Jan 21, 2012 1:03 am
Hi, I recently upgraded serviio 0.6.0 to 0.6.1.
Everything is working right, I followed step by step the instructions on this site to upgrade it.
When I start serviio server, it bounce on the mac dock, then after 50 seconds hangs. The program appear stucked, even if I right click the icon it seems that the app is not responding. But the server is running flawlessy.
What's the problem? Every time I have to shotdown the mac, I have to force the app to close it, otherwise the mac can power off.
2012-01-11 23:09:49,229 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-11 23:09:49,229 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-11 23:09:49,229 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-11 23:09:49,229 INFO [MediaServer] http://www.serviio.org
2012-01-11 23:09:49,229 INFO [MediaServer] Java 1.6.0_29-Apple Inc.
2012-01-11 23:09:49,229 INFO [MediaServer] OS Mac OS X x86_64 10.7.2
2012-01-11 23:09:49,230 INFO [MediaServer] File encoding: UTF-8
2012-01-11 23:09:49,230 INFO [MediaServer] Headless mode enabled: true
2012-01-11 23:09:49,230 INFO [MediaServer] User home dir: /Users/francob
2012-01-11 23:09:49,230 INFO [MediaServer] Temp dir: /var/folders/m1/62r335sj4gdbtxvhnqq1j98r0000gn/T/
2012-01-11 23:09:49,230 INFO [MediaServer] ------------------------------------------------------------------------
Post Sat Jan 21, 2012 8:14 am
Re: Serviio Server hangs on the mac dock
thats normal mac dont like headless applications, so it thinks its crashed when it actualy hasnt.
slaute
Post Tue Jan 22, 2013 10:19 pm
Cerberus wrote:thats normal mac dont like headless applications, so it thinks its crashed when it actualy hasnt.
Please... as if there weren't headless applications for Mac OS X (including many from the very same OS). It just has to be programmed appropriately. I'm not saying it's easy because I have not idea.
And I actually don't care much if I have to click "Force quit" or "Quit", anyway. It looks like Serviio is not actually killed because it writes more things to the log after a "Force Quit".
tcviper
Post Wed Jan 23, 2013 10:38 am
Really is that the reason? Then Serviio might wanna look at Plex and other applications that throw the app in the top menu on the Mac as a service :)
Cause an icon bumping like that in the dock over and over is extremely annoying, especially if you also want to do other things on that same mac.
Sony KDL-55W905A | KDL-32EX521 | 32W5500 | STR-DN1040 | MacMini | Synology 1511+ | Network Cisco
Users browsing this forum: Bing [Bot] and 23 guests
