Mediabrowser and IE8,IE9
lanman
Post Wed Aug 15, 2012 9:35 pm
I am able to successfully connect and navigate through my media collection by connecting to mediabrowser from various IP addresses using various computers and the Chrome browser. However, anytime I attempt this with IE8 and/or IE9, the mediabrowser's serviio login dialog box won't dissapear from the screen and ends up covering the video thumbnails behind it which makes it impractical to navigate the media. I have tried various security and formatting options within IE but the problem still exists.
I was just wondering if anyone else was having a similar issue and may have suggestions as to how I might go about correcting this?
Post Wed Aug 15, 2012 9:55 pm
Re: Mediabrowser and IE8,IE9
Yes, I have this problem with ie8 but since it is not the current level a fix was denied. Now perhaps since you have it with ie9 as well it shows it is indeed not an ie level problem and should be fixed.
I suggest you report it in bitbucket as a bug.
lanman
Post Wed Aug 15, 2012 10:23 pm
I tried to signup for a Bitbucket account in order to post this issue as a bug but when I clicked Submit on the registration form I received the following error:
CSRF verification failed. Request aborted.
I then tried to post this issue to Bitbucket anonymously and received this same error:
Post Wed Aug 15, 2012 10:35 pm
IE9 should work - make sure you're not running it in the compatibility mode.
AvBeynum
Post Tue Jan 22, 2013 4:54 pm
Same problem here. With IE10 I cannot login at all. In older IE browsers the Login dialogbox does not disappear.
Chrome works perfectly...
AvBeynum
Post Tue Jan 22, 2013 7:46 pm
Strangely the Demonstration of Serviio Pro Online Media Browser works fine in all of my browsers, so somehow it's related to my server?!
http://serviidb.com/content/demonstration-serviio-pro-online-media-browser
Any ideas?
Running serviio-1.1-win on WHS2011...
Thx in advance!
Post Wed Jan 23, 2013 5:43 pm
try to clean your browser cache
AvBeynum
Post Wed Jan 23, 2013 9:04 pm
Thx for the suggestion Petr. I tried that but it didn't help.
Any other things I can try or logs I can check?
Cheers / A+
