Serviio 1.1 on ubunut wont work
xroads42
Post Tue Jan 29, 2013 3:01 pm
I just installed serviio and it wont start.. (ubuntu 12.10)
here is my /etc/init/serviio.conf
[# Serviio - media server
# Serviio is a free media server. It allows you to stream your media files
# (music, video or images) to renderer devices (e.g. a TV set, Bluray player,
# games console or mobile phone) on your connected home network.
description     "serviio - media server"
author          "RafaÅ‚ SzkodziÅ„ski <uid@atnus.com>"
start on        (starting network-interface
                or starting network-manager
                or starting networking)
stop on         runlevel [!023456]
script
        exec    /opt/serviio-1.1/bin/serviio.sh
end script
staring serviio with sudo start serviio returns :
serviio start/running, process 11333
but checking with initctl list |grep servi* a few seconds later returns
serviio stop/waiting
i checked the serviio.log and there seam to be errors with the db and derby. serviio.log
2013-01-29 15:55:30,490 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-29 15:55:30,491 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-29 15:55:30,491 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-29 15:55:30,491 INFO  [MediaServer] http://www.serviio.org
2013-01-29 15:55:30,491 INFO  [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2013-01-29 15:55:30,491 INFO  [MediaServer] OS Linux i386 3.5.0-22-generic
2013-01-29 15:55:30,491 INFO  [MediaServer] File encoding: US-ASCII
2013-01-29 15:55:30,492 INFO  [MediaServer] Headless mode enabled: true
2013-01-29 15:55:30,492 INFO  [MediaServer] User: root
2013-01-29 15:55:30,492 INFO  [MediaServer] User home dir: /root
2013-01-29 15:55:30,492 INFO  [MediaServer] Temp dir: /tmp
2013-01-29 15:55:30,492 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-29 15:55:30,648 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-29 15:55:30,650 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-29 15:55:30,694 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-29 15:55:30,695 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-29 15:55:30,712 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-29 15:55:31,097 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to create database 'db', see the next exception for details.
   at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection30.<init>(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
   at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
   at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
   at java.sql.DriverManager.getConnection(DriverManager.java:620)
   at java.sql.DriverManager.getConnection(DriverManager.java:222)
   at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
   at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:57)
   at org.serviio.MediaServer.main(MediaServer.java:110)
Caused by: java.sql.SQLException: Failed to create database 'db', see the next exception for details.
   ... 20 more
Caused by: java.sql.SQLException: The database directory '/opt/serviio-1.1/library/db' exists. However, it does not contain the expected 'service.properties' file. Perhaps Derby was brought down in the middle of creating this database. You may want to delete this directory and try creating the database again.
   ... 17 more
Caused by: ERROR XBM0A: The database directory '/opt/serviio-1.1/library/db' exists. However, it does not contain the expected 'service.properties' file. Perhaps Derby was brought down in the middle of creating this database. You may want to delete this directory and try creating the database again.
   at org.apache.derby.impl.services.monitor.StorageFactoryService.vetService(Unknown Source)
   at org.apache.derby.impl.services.monitor.StorageFactoryService.access$900(Unknown Source)
   at org.apache.derby.impl.services.monitor.StorageFactoryService$9.run(Unknown Source)
   at org.apache.derby.impl.services.monitor.StorageFactoryService.createServiceRoot(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.createPersistentService(Unknown Source)
   at org.apache.derby.iapi.services.monitor.Monitor.createPersistentService(Unknown Source)
   ... 17 more
2013-01-29 15:55:33,103 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
derby.log:
Tue Jan 29 15:55:31 CET 2013 Thread[main,5,main] Cleanup action starting
Cleanup action completed
   ... 20 more
   ... 17 more
   ... 17 more
============= begin nested exception, level (1) ===========
   ... 22 more
   ... 17 more
============= end nested exception, level (1) ===========
============= begin nested exception, level (2) ===========
   ... 17 more
============= end nested exception, level (2) ===========
============= begin nested exception, level (3) ===========
============= end nested exception, level (3) ===========
i deleted the db dir and started servvio again and get the same log files...
my java version is (java --version ):
java version "1.6.0_24"
OpenJDK Runtime Environment (IcedTea6 1.11.5) (6b24-1.11.5-0ubuntu1~12.10.1)
OpenJDK Server VM (build 20.0-b12, mixed mode)
what can i do to get serviio running??
greetings,
xrods42
bspesq
Post Tue Jan 29, 2013 3:44 pm
Re: Serviio 1.1 on ubunut wont work
FWIW, I spent a long time trying to diagnose this exact same problem on Ubuntu. Eventually I just gave up and laid down a clean copy of the serviio distribution and it started up properly.
I think the errors are somehow related to not having the proper pieces in place (wrong java version, for me) before starting Serviio for the first time.
xroads42
Post Tue Jan 29, 2013 4:04 pm
hmm. removing serviio and downloading again did not work for me....
Post Tue Jan 29, 2013 5:40 pm
it the library folder writable?
xroads42
Post Tue Jan 29, 2013 6:37 pm
the library was and is writable.
I changed the owner from "me" to root; and now it works :)
but i have to start serviio-console as root... is that ok??
edit: did a "chmod 777 * -R "on serviio dir. now i am able to open serviio-console wiht normal user rights...
Users browsing this forum: No registered users and 143 guests
