Wrong movie
Morbeas
Post Wed Jan 16, 2013 7:53 pm
Wrong movie
Hi there. I'm new to Serviio so I'd really appreciate your patience as I ask some newbie questions.
First off, Serviio is running on a Synology 1511+ (x86) NAS. The problem is that some of the movies are not being scraped accurately. I'm also an XBMC user so all my folders are setup properly (see screenshots). Is there a way I can manually correct the name Serviio scrapes? If not, I read on this board that I can have XBMC manage my library? How exactly can I accomplish that?
Thanks in advance.
slyguy42o
Post Thu Jan 17, 2013 2:39 am
Re: Wrong movie
you can use xbmc and a few other formats, check out the metadata tab of your serviio console for meta options.
Morbeas
Post Thu Jan 17, 2013 3:28 am
Re: Wrong movie
So there's no way to manually fix an incorrect match???
r-win
Post Thu Jan 17, 2013 5:06 am
Wrong movie
You can switch to use XBMC nfo files. Then you're in full control. Otherwise, no, you can't fix an incorrect match.
Linksys WRT320N | Samsung PS-50C7700 | Microsoft XBOX 360 | Windows 8.1 | Linux Ubuntu 13.04
Morbeas
Post Thu Jan 17, 2013 12:16 pm
Re: Wrong movie
This seems like a very simple but important feature missing. :(
Morbeas
Post Thu Jan 17, 2013 12:33 pm
Re: Wrong movie
Also, after almost a day, why are ffmpeg and java still using so much of my resources?
Post Thu Jan 17, 2013 1:26 pm
Re: Wrong movie
are you using any online sources? If so it might be getting the new information for the feeds.
Post Thu Jan 17, 2013 2:09 pm
Re: Wrong movie
all the java processes - it looks weird. try to restart.
What OS are you on?
Morbeas
Post Thu Jan 17, 2013 2:58 pm
Re: Wrong movie
I restarted already and the same thing. I'm running this on my Synology 1511+ NAS running Linux (x86).
Post Thu Jan 17, 2013 5:17 pm
Re: Wrong movie
Maybe ask in the NAS forum, they might be able to help.
Morbeas
Post Fri Jan 18, 2013 2:15 am
Re: Wrong movie
Does the flowplayer watermark disappear when I purchase a pro license?
Post Fri Jan 18, 2013 3:46 pm
Re: Wrong movie
No, but I'll try to remove it in future.
Morbeas
Post Fri Jan 18, 2013 3:51 pm
Re: Wrong movie
Can someone please explain why Serviio is confusing these two movies and how I can fix it? It's times like these that you REALLY need a manual way of fixing movies. Please please PLEASE put this in your next version release!
Morbeas
Post Fri Jan 18, 2013 3:52 pm
Re: Wrong movie
zip wrote:No, but I'll try to remove it in future.
Would really appreciate that. Thanks very much.
Post Sat Jan 19, 2013 1:07 am
Re: Wrong movie
Do you have online metadata of XBMC on?
Morbeas
Post Sat Jan 19, 2013 1:10 am
Re: Wrong movie
No, I do not.
patters
Post Thu Jan 31, 2013 10:58 am
Re: Wrong movie
1. Usually you can get the movie to identify properly by appending the year onto the filename.
2. As for the multiple Java processes - this seems to only occur on Intel Synology products, and happens with CrashPlan too. I'm unsure why since it definitely doesn't do this on ARM. The version of glibc is older on their Intel Linux distro so that could be responsible for some weirdness.
Users browsing this forum: No registered users and 160 guests
