I can't even see Serviio after installation
abrehaut
Post Mon Jan 21, 2013 6:04 am
I have been using Serviio for about eight months - best program out there!
However, I came home from holidays and it has disappeared from my computer. It is still in Program Files but is not showing up anywhere else. I have tried opening both of the application files - the Serviio Console and the Serviio service - both without success. I have uninstalled and reinstalled both versions 1.0.1 and 1.1. They both install absolutely fine but then there is nothing else. I have checked task manager and its not there either. I am using Windows 8 but have not had a problem up until now. Very confusing!
Please help, because I have had to resort to Universal Controller which is not much chop compared to Serviio.
Andrew
Post Mon Jan 21, 2013 1:06 pm
Re: I can't even see Serviio after installation
abrehaut
Post Thu Jan 24, 2013 7:03 am
sorry about the delay in answering. How do I post a log?
Post Thu Jan 24, 2013 1:46 pm
see link in my signature, then attach it here as a zip file
abrehaut
Post Sat Jan 26, 2013 8:07 am
I have followed your directions. I cannot stop the server because it has not even started. I have tried to start it again but with no avail.
There is not even a log file in there. As I mentioned, it does not even appear to be starting up after install or when I open the Serviio file. Just can't work out why this is happening when it was working perfectly five weeks ago.
Any other ideas??
Regards,
Andrew
Post Tue Jan 29, 2013 3:01 pm
try to uninstall all Java versions and install Serviio again
abrehaut
Post Sun Feb 03, 2013 7:57 am
Thanks you SOOOOOOO MUCHHHHHHHH!
Does this mean I cannot update Java anymore?
Post Mon Feb 04, 2013 1:47 pm
you can, but be careful. From my experience it doesn't do much good to run 2 Java versions, and sometimes Java updates introduce bugs or incompatibilities.
