FFMPEG not found. Serviio will not work properly
mmarauder
Post Fri Feb 22, 2013 2:15 am
I recently installed serviio on a secondary server, and I can not get it to recognize ffmpeg. I am getting the error:
2013-02-21 20:15:38,897 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "ffmpeg": java.io.IOException: error=2, No such file or directory
2013-02-21 20:15:38,897 ERROR [MediaServer] FFMPEG not found. Serviio will not work properly.
But I just installed ffmpeg from source.
ffmpeg version git-2013-02-21-29436c1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 21 2013 20:11:27 with gcc 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu4)
configuration: --enable-gpl --enable-libass --enable-libfaac --enable-libfdk-aac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libspeex --enable-librtmp --enable-libtheora --enable-libvorbis --enable-libvpx --enable-x11grab --enable-libx264 --enable-nonfree --enable-version3 --enable-libopus
libavutil 52. 17.102 / 52. 17.102
libavcodec 54. 92.100 / 54. 92.100
libavformat 54. 63.100 / 54. 63.100
libavdevice 54. 3.103 / 54. 3.103
libavfilter 3. 39.100 / 3. 39.100
libswscale 2. 2.100 / 2. 2.100
libpostproc 52. 2.100 / 52. 2.100
Use -h to get full help or, even better, run 'man ffmpeg'
:/usr/src/serviio$ dpkg -l | grep ffmpeg
ii ffmpeg 7:201302212011-git-1 Package created with checkinstall 1.6.2
ii ffmpegthumbnailer 2.0.2-1build1 fast and lightweight video thumbnailer
ii gstreamer0.10-ffmpeg 0.10.11-4 FFmpeg plugin for GStreamer
ii libffmpegthumbnailer4 2.0.2-1build1 the ffmpegthumbnailer library
ii usu-video-thumbnailer 5.0.1 Video thumbnailer for Nautilus/GNOME, using ffmpeg
uname -a
Linux 2.6.38-9-generic #43-Ubuntu SMP Thu Apr 28 15:23:06 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
Can someone help me out?
Post Fri Feb 22, 2013 4:17 pm
Re: FFMPEG not found. Serviio will not work properly
it can't find it on path (or the user that runs Serviio can't). You can specify ffmpeg location via a system variable (see the website support section) and search the forum
