Some files won't show
Romfrosk
Post Wed Feb 27, 2013 4:30 pm
Hi.
I'm a happy user of Serviio 1.1
(Soon a paying one, as fast as my new fiber connection is here)
I've recently noticed that some files wont show up under "Series", But they show and play fine from "Folders"
i Cant find anything related to the specific file in the logfiles.* See Edit *
I've seen it on 9-10 different files, no specific show, or folder. just random.
Is it a way to do a full refresh of the library, without deleting "watched" status?
Here's the MediaInfo
Can't see any difference between them.
Not Showing up
Unique ID                                : 196696473556435778755268848883316973473 (0x93FA5CE2EFA8F51A833DB1207D8A5FA1)
Complete name                            : E:\Serier\Criminal Minds\Season 2\Criminal Minds - S02E18 - Jones - 720p WEB-DL.mkv
File size                                : 1.37 GiB
Duration                                 : 42mn 33s
Overall bit rate                         : 4 594 Kbps
Encoded date                             : UTC 2010-03-25 11:01:34
Writing application                      : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format profile                           : High@L3.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 2 frames
Duration                                 : 42mn 33s
Bit rate                                 : 4 119 Kbps
Bits/(Pixel*Frame)                       : 0.186
Stream size                              : 1.22 GiB (90%)
Duration                                 : 42mn 33s
Bit rate                                 : 384 Kbps
Stream size                              : 117 MiB (8%)
Working Fine:
Unique ID                                : 176779655077039110922556425336124380778 (0x84FE85EBA8E22918AB756740BDA0966A)
Complete name                            : E:\Serier\Criminal Minds\Season 2\Criminal Minds - S02E17 - Distress - 720p WEB-DL.mkv
File size                                : 1.28 GiB
Duration                                 : 42mn 9s
Overall bit rate                         : 4 332 Kbps
Encoded date                             : UTC 2010-03-25 10:57:21
Duration                                 : 42mn 9s
Bit rate                                 : 3 862 Kbps
Bits/(Pixel*Frame)                       : 0.175
Stream size                              : 1.14 GiB (89%)
Duration                                 : 42mn 9s
Bit rate                                 : 384 Kbps
Stream size                              : 116 MiB (9%)
Edit:
I see this in the Serviio.log.1
2013-02-12 04:46:14,851 WARN  [LibraryManager] Cannot read metadata of file E:\Serier\Criminal Minds\Season 2\Criminal Minds - S02E18 - Jones - 720p WEB-DL.mkv via extractor ONLINE_VIDEO_SOURCES. Message: Cannot retrieve series search results for tvdb.com: Read timed out
2013-02-12 04:46:15,148 INFO  [LibraryUpdatesCheckerThread] Updated 'Jones' (E:\Serier\Criminal Minds\Season 2\Criminal Minds - S02E18 - Jones - 720p WEB-DL.mkv) in Library
Post Thu Feb 28, 2013 2:18 pm
Re: Some files won't show
If the metadata cannot be read (in your case the site was probably down), it won't appear under Series.
Romfrosk
Post Thu Feb 28, 2013 3:19 pm
Ofcourse.. i should have thought of that.
Doing a "Rescan Metadata" now.
I see that a bunch of files gets "updated", Also the missing ones.
Perfect.
Is it a way to set up a full refresh now and then?
Without pushing the button?
Post Thu Feb 28, 2013 5:40 pm
not for the video files, unless you invoke the API call from a bat file or similar
Users browsing this forum: Google [Bot] and 76 guests
