User defined Genres
Dalilb
Post Sun Mar 03, 2013 3:34 am
User defined Genres
Is it possible to edit the different genres that Serviio automatically shows ?
For my use many of the build in Genres out of the box is pretty useless,
and I would like to create my own ones, eg.
If i just wanted to have 3 genres listed
-Family
-Work
-Kids
Is that possible ?
Post Sun Mar 03, 2013 4:33 am
Re: User defined Genres
You could make custom xbmc nfo files for each one. But you then could not use online metadata at the same time.
Dalilb
Post Sun Mar 03, 2013 6:40 am
What I was looking for is that Serviio would just read the standard Genre meta tag of the files, and create a new genre if it doesn't know it.
I get that the genres built in is pre configured, but would be nice if you could turn them on/off in the console.
and then if i have some home movie files tagged as eg "Kids", "Kids & Mom" etc.. it would just show those on the player :idea:
Post Sun Mar 03, 2013 12:01 pm
They are not preconfigured, they are read from the file metadata. Serviio doesn't support embedded video metadata though.
Users browsing this forum: No registered users and 178 guests
