re-compiling x264 under ubuntu 12.04
thenamelessthing
Post Mon Mar 04, 2013 3:02 am
Hi, when I follow the step to install x264g from the source. I obtain this warning under Ubuntu 12.04:
It is important or I can do what they suggest?
media@mediastation:~/src/x264$ make
Makefile:3: config.mak: No such file or directory
./configure
Found yasm 1.1.0.2352
Minimum version is yasm-1.2.0
If you really want to compile without asm, configure with --disable-asm.
make: *** [config.mak] Error 1
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Mon Mar 04, 2013 1:49 pm
Re: re-compiling x264 under ubuntu 12.04
you don't need x264 library for Serviio really.
khurram23
Post Tue Mar 05, 2013 7:08 pm
Download the tarball from http://www.tortall.net/projects/yasm/wiki/Download
./configure
make
sudo checkinstall
then rebuild x264
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
Users browsing this forum: No registered users and 142 guests
