I found problem in the log?
Scoty
Post Fri Mar 08, 2013 2:03 pm
I have look in the log file and i have see this problem:
2013-03-08 14:03:35,352 WARN [PortMapper] Could not add port mapping to the router: Connection refused: connect
2013-03-08 14:13:35,352 WARN [PortMapper] Could not add port mapping to the router: Connection refused: connect
2013-03-08 14:23:35,355 WARN [PortMapper] Could not add port mapping to the router: Connection refused: connect
2013-03-08 14:33:35,399 WARN [PortMapper] Could not add port mapping to the router: Connection refused: connect
2013-03-08 14:43:35,726 WARN [PortMapper] Could not add port mapping to the router: Connection refused: connect
2013-03-08 14:53:35,352 WARN [PortMapper] Could not add port mapping to the router: Connection refused: connect
But i can watch Video on my Samsung TV. Which problem is this and how can i solved? I have a Asus RT-N56U Router and use Firmware 3.0.0.4.318.
Post Fri Mar 08, 2013 3:38 pm
Re: I found problem in the log?
It's for the remote port forwarding. If you don't access the server remotely via internet, turn off Automatic port forwarding on the Remote tab
Users browsing this forum: Baidu [Spider] and 151 guests
