Can't connect to tvdb.
Sottle
Post Sat Mar 09, 2013 7:39 pm
Hi all, i'm having an issue with thetvdb retrieving metadata and covers. Basically, for some reason http://www.thetvdb.com is not reachable (503 error) for me, however http://thetvdb.com works perfectly fine. Looking on google this seems to be an issue for some other people as well.
Anyway, i'm guessing since serviio uses the former in it's lookup commands i can't retrieve any metadata for TV shows, movies are working fine. Can anyone tell me if there's a workaround?
Post Sat Mar 09, 2013 8:14 pm
Re: Can't connect to tvdb.
The same post 2 topics down. Search before posting pls.
Sottle
Post Sat Mar 09, 2013 8:29 pm
Thanks for your reply, I did search.
The topic you seem to be referring to seems to be describing an issue with missing files, not missing metadata. It seems to me my issue could be fixed by pointing the scrape to thetvdb.com instead of www.thetvdb.com however i can't find a config file to let me do this.
Post Sat Mar 09, 2013 8:55 pm
1.2.1 will address that
Users browsing this forum: No registered users and 108 guests
