Humax Fox T2 and itv player
Rex
Post Mon Apr 08, 2013 12:21 pm
I am trying to get the ITV player working with Ubuntu 12.04
So far I have now successfully installed Serviio and can see it on the Humax plus the folders and the progs that I want to view.
However when I click on a programme there is a short message which says connecting and then it jumps back to the upper folder.
It kind of suggests that it cannot actually connect.
I have already had it working with an XP setup and copied the settings on the Serviio console. I am now trying to run it on a Dell Laptop and have just increased the ram by 512.
Would be grateful for any assistance but type slowly!!
Regards
Rex
slyguy42o
Post Mon Apr 08, 2013 3:36 pm
Re: Humax Fox T2 and itv player
what profile are you using for your device? also can you post detailed logs?
Rex
Post Mon Apr 08, 2013 3:50 pm
Hi slyguy
I afraid you've got me.......... I'm an linux/serviio newbie (but an old newbie!!)
Could you point me in the right direction?
Rex
slyguy42o
Post Mon Apr 08, 2013 3:53 pm
Here is how you enable logging
viewtopic.php?f=5&t=7
profile selection is done via the Status tab of the serviio console, depending on what profile is selected.. this will determine the behavior of how serviio pushes media to the client. Find the Humax device in your profile list and see what it is currently using. You can try switching to various profiles to see if it makes a difference.
Rex
Post Wed Apr 10, 2013 3:37 pm
I'm sorry for delay but "life" gets in the way of things sometimes....
The profile is Generic DNLA Profile. This works if I run it on my windows XP setup.
The log file is rather long so I have attached it rather tha cut and paste.
I tried to open a programme to view and left it running for a while in case it was just slow loading and it eventually locked up the system.
Rex
(245.77 KiB) Downloaded 406 times
slyguy42o
Post Wed Apr 10, 2013 5:19 pm
search the forums for "humax" there is another profile that you can use that should work for these devices but I can't remember which one it is.
Rex
Post Thu Apr 11, 2013 10:33 pm
The only reference I could find stated that the default config was OK.
As I previously said it works on my XP set-up.
Rex
Users browsing this forum: No registered users and 115 guests
